Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
86 registered members (55hambone, 1978elcamino, 2015_PSD, 64bawagon, 97prizm, alchargo, 12 invisible), 2,101 guests, and 92 spiders.
Topics306,053
Posts5,286,491
Members71,593
Engine Oil cooler effectiveness. #5421951 05/05/20 07:14 PM
J
Jarpin Offline OP
J
Hey guys. I drive a clunker that's got 263k on it. It runs strong, and lubrication wise, it's got no issues. I recently installed a Derale oil filter reloc. kit, and also plumbed in an aftermarket 7 row plate and fin oil cooler underneath the front bumper. It gets direct moving air exposure, and I made sure to increase the qt. capacity to account for this extra tubing, and cooler volume. I run regular synthetic 5W-30 and change it every 6,000.
How much of a difference to oil thermal breakdown do you guys think that the cooler could make between OCI's? I don't plan on extending the interval, just finding out if this was a worthwhile project that might promote increased longevity of the motor in general.
Re: Engine Oil cooler effectiveness. [Re: Jarpin] #5421960 05/05/20 07:25 PM
H
HangFire Offline
H
Unless you are towing in high heat areas up steep hills, you are unlikely to see any value out of your oil cooler. An old engine will contaminate oil faster than it will wear it out, in normal usage.
Various musings: http://hangfire.net
Re: Engine Oil cooler effectiveness. [Re: HangFire] #5421969 05/05/20 07:32 PM
O
Oildudeny Offline
O
thumbsup
Re: Engine Oil cooler effectiveness. [Re: Jarpin] #5422046 05/05/20 08:45 PM
R
ripcord Offline
R
Is there a thermal bypass on your cooler? If it delays the oil reaching operating temps significantly, you're probably causing more wear in your engine. If the cooler does not allow the oil temps to exceed 212f at least some of the time, then condensation may build up in the oil, too.
You might think about converting your engine oil cooler into a transmission cooler instead.
Re: Engine Oil cooler effectiveness. [Re: Jarpin] #5422147 05/05/20 10:43 PM
CT8 Online Content
Online Content
thermal breakdown
2015 F150 2.7
2018 F350 6.2
Re: Engine Oil cooler effectiveness. [Re: Jarpin] #5422290 05/06/20 06:17 AM
M
MrHorspwer Offline
M
Is it worthwhile? Probably not.
If you want anything more than internet conjecture (my own included), you'd need before and after oil temps to see how operating conditions change with and without the cooler and you'd need oil analysis before and after to see how it affected the oil.
Like I said, probably not worthwhile on a car that's gone 263k without one just fine. Being you're in Texas and not someplace that often gets really cold temps, I wouldn't be too worried about not getting the oil up to operating temps.
Re: Engine Oil cooler effectiveness. [Re: Jarpin] #5422363 05/06/20 07:51 AM
supton Online Content
Online Content
Whatever happens, it has that much more oil to work across (dilution).
I'd hook up an oil temp gauge next, see what is coming out of the motor--then, because it was me, I'd hook one up on the inlet line too, and see how effective the cooler is. smile
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: Engine Oil cooler effectiveness. [Re: Jarpin] #5422367 05/06/20 07:55 AM
K
Kira Offline
K
Texas made me think of my neighbor's Arlington, TX built 2006 Chevy Caprice Classic with a towing package which I sold.
An engine oil cooler was included in the factory setup.
That car was loaded with every option Chevy had (for the Caprice) except for leather.
Even with low mileage (75K) the phone didn't ring.
I guess that's how "roundy and ugly" those cars were. A similar Crown Vic would've sold in a second.
Re: Engine Oil cooler effectiveness. [Re: Jarpin] #5422406 05/06/20 08:34 AM
A
ARB1977 Offline
A
With 263K why even worry about it. Just run synthetic and call it a day.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: Engine Oil cooler effectiveness. [Re: Kira] #5422424 05/06/20 08:49 AM
4WD Offline
Maybe GM Guy could help … but thought they only had the name on a Holden and US had Impala ?
Re: Engine Oil cooler effectiveness. [Re: Jarpin] #5422852 05/06/20 05:47 PM
SHOZ Offline
Those oil filter mount oil to coolant heat exchanges work pretty good. Especially at getting the oil up to temp.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Engine Oil cooler effectiveness. [Re: ripcord] #5423652 05/07/20 08:32 PM
J
Jarpin Offline OP
J
Well, it's only a small 100 ml capacity air to oil cooler. I'm not running anything huge like a boosted car for racing would need. I thought that if I found a way just to reduce oil temps a little bit, then it might be worthwhile in carrying more heat away from the engine, so that other hoses and electrical connectors in the engine bay might not deteriorate and snap so fast.
