Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
Best oil on the market?
by sloinker - 05/25/20 08:47 PM
Xfinity Race in Charlotte
by kstanf150 - 05/25/20 08:12 PM
Purolator PBL14610 C&P
by FordBroncoVWJeta - 05/25/20 08:00 PM
Carquest Blue 85522 C&P
by FordBroncoVWJeta - 05/25/20 07:52 PM
2020 RAV4 Hybrid - oil options
by CELICA_XX - 05/25/20 07:44 PM
any battery charger/repair that can fix sulfation?
by apollo18 - 05/25/20 07:28 PM
Need Mice Advice
by Mr_Luke - 05/25/20 07:01 PM
pressure washer air compressor oil
by bedwards - 05/25/20 06:49 PM
2014 Elantra delayed shift 4th to 5th
by Propflux01 - 05/25/20 05:51 PM
2002 Ranger Electrical Weirdness (GEM, RAP?)
by DuckRyder - 05/25/20 05:47 PM
Oil change problems
by philipp10 - 05/25/20 05:41 PM
Denso 150 3024
by thrace - 05/25/20 04:58 PM
does ac delco warranty the replacement battery?
by apollo18 - 05/25/20 04:39 PM
Water drainage issue
by Paul_Siu - 05/25/20 04:39 PM
13 Corolla PCV
by AJB0009 - 05/25/20 04:24 PM
mikespine, Typerguy, showtyme1958, rickyradit, YogiTheCat
71528 Registered Users
34 registered members (bworley, bachman, ajchien, ArrestMeRedZ, BlakeB, blufeb95, 2 invisible), 1,231 guests, and 25 spiders.
Topics305,879
Posts5,281,961
Members71,528
water pump leaking, still driveable? #5421848 05/05/20 04:56 PM
M
motor_oil_madman Offline OP
M
I know they have a wheep hole that allows the coolant to start leaking out letting you know the pump is going out, but does this mean the vehicle shouldn't be driven until a new pump is installed? Mine has gone from no noticeable leak, to a 12" diameter puddle of coolant on the ground that develops about 30 minutes after shutdown. I'm just concerned the pump is going to suddenly fail and the engine is going to pump all its coolant out within 2 minutes going down the road. I went ahead and had a new pump overnighted so my buddy can help me install it tomorrow morning. It's only been leaking a few days I park in the same spot everyday, but it's definitely getting worse. Kind of a bummer I had to spend $45 bucks on shipping to get it here, but I don't want to ruin my engine, this truck is my only vehicle.
The truck is a dodge ram cummins diesel, looks like my profile signature isn't their anymore.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: water pump leaking, still driveable? [Re: motor_oil_madman] #5421855 05/05/20 05:02 PM
Snagglefoot Offline
You caught it just in time. smile
If you want the job done right......do it yourself.
Re: water pump leaking, still driveable? [Re: motor_oil_madman] #5421874 05/05/20 05:27 PM
M
M
well it's not fixed yet, still have to drive it around a bit more.
Re: water pump leaking, still driveable? [Re: motor_oil_madman] #5421878 05/05/20 05:35 PM
J
Jake_J Offline
J
The weep hole is the early warning, you can keep driving the truck as long as you keep an eye on the coolant level. But with a 12" diameter puddle yours is a little more than a tiny leak, so I wouldn't take it on any trips out of town.
Re: water pump leaking, still driveable? [Re: motor_oil_madman] #5421882 05/05/20 05:37 PM
O
oldhp Offline
O
Anti-freeze going thru seal leaking out the weep hole will ruin the bearing. Bearing could lock up if left long enough. Change it as soon as possible, fan going into radiator ain't good.
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: water pump leaking, still driveable? [Re: motor_oil_madman] #5421892 05/05/20 05:44 PM
M
M
Yeah i'm keeping a close eye on the overflow bottle and adding as necessary.
Re: water pump leaking, still driveable? [Re: motor_oil_madman] #5421895 05/05/20 05:47 PM
M
M
Now I know why the ac compressor always has had oil on it. I guess they periodically seep a little here and there over the years.
Re: water pump leaking, still driveable? [Re: motor_oil_madman] #5421993 05/05/20 07:51 PM
Chris142 Offline
Until the bearing locks up and the fan comes off and goes through the radiator or breaks the timing belt and eats the valves.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: water pump leaking, still driveable? [Re: Chris142] #5422028 05/05/20 08:29 PM
M
M
I see. My water pump isn't connected to the fan, but it is driven by the belt.
Re: water pump leaking, still driveable? [Re: motor_oil_madman] #5422050 05/05/20 08:46 PM
M
M
Re: water pump leaking, still driveable? [Re: motor_oil_madman] #5422076 05/05/20 09:03 PM
clinebarger Online Content
Online Content
Why would you mail order a water pump for a ISB Cummins? I guarantee Cummins Southern Plains in Houston has a OE pump in stock. Just don't walk in there without the Engine Number!
2001 Chevy Camaro L92/4L80E
Re: water pump leaking, still driveable? [Re: clinebarger] #5422086 05/05/20 09:11 PM
M
M
Because Houston is big and I'd prefer not to drive 45 minutes each way into Houston with a bad water pump and be on the side of I-10 or I-45.
Re: water pump leaking, still driveable? [Re: motor_oil_madman] #5422089 05/05/20 09:16 PM
M
M
On the north 610 loop. I'll keep them in mind for next time though.
Re: water pump leaking, still driveable? [Re: motor_oil_madman] #5422169 05/05/20 11:16 PM
Online Content
I've been to Houston more than a few times, It's not any larger than the Metroplex (DFW).....I think DFW is the most populated metropolitan area in Texas?
Re: water pump leaking, still driveable? [Re: motor_oil_madman] #5422269 05/06/20 05:37 AM
L
Lubener Offline
L
The leak won't get any better with time. What puzzles me is why someone would pay $45 for overnight freight on a water pump when you could have procured one locally which would be equally as good???? Then ask if it is still drivable. Doesn't make sense to me.
The "thinking" man's friend.
