I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
36 registered members (ArrestMeRedZ, 2009Caraman, AZjeff, Blkstanger, blufeb95, Arcoril, 3 invisible), 1,265 guests, and 24 spiders.
Topics306,032
Posts5,285,231
Members71,566
Downside to WPA2/WPA3? #5421746 05/05/20 02:51 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
As many know, I was tracking issues with my old netgear router. For kicks, I decided to get an Asus RT-AX56U, since it claims its ideal for more users (we dont necessarily use a ton of bandwidth, but have a lot of simultaneous connections), and a number of other benefits. I figured since returns were free on Amazon, the worst that could happen is that it doesnt make anything better, and we return it.
Set it up, including using new WPA3 security. Seems to work for a lot of things, including the 2013 MBP running 10.15.4 currently. But other items (a kid tablet, my old 2010 MBA, etc) dont.
While it doesnt seem like I have a choice, Id still like to understand - what's the downside to using WPA2/WPA3 versus just WPA3? Is there a reason Id want to avoid this? For example, I could put the old devices on either the 2.4GHz network that is segregated, or just use a guest network for those devices... Something like that.
Thoughts?
Thanks!
Re: Downside to WPA2/WPA3? [Re: JHZR2] #5421803 05/05/20 03:49 PM
sohccammer427 Offline
No downside to using WPA2/WPA3 at all. Once the connection is established, there is nothing else that could be considered extra overhead.
As you found out some older devices don't support WPA3, so you probably don't even have a choice at this point. For home security, I'd probably just run WPA2 personal and be done with it, but either way will work. You could make a list of what devices connect with WPA2 and have a timetable of what needs replaced over time.
As far as the a second network ID, I don't thin the extra config would be worth it. Run WPA2/WPA3 and you'll be fine.
2015 VW Passat TDi 6 Speed Manual
2017 Colorado Duramax
Re: Downside to WPA2/WPA3? [Re: JHZR2] #5421805 05/05/20 03:53 PM
R
ripcord Offline
R
WPA2 is fine if you use a password/phrase that's sufficiently long and complex, but it is vulnerable to dictionary attacks. With WPA2, you can just keep brute force guessing passwords until you hit the right one. This is bad if your password/phrase is your initial and your favorite brand of oil, but if your password is over 16 characters and is a mix of words, numbers, symbols, etc, it's still pretty safe.
Re: Downside to WPA2/WPA3? [Re: JHZR2] #5421809 05/05/20 03:58 PM
R
ripcord Offline
R
There is a recently discovered flaw in WPA2 called "Kr00k" that a lot of router companies are releasing patches for. It was found by researchers and supposedly there's no evidence that it was being used by hackers, BTW. I checked and there was even a patch for my old Trendnet router.
Re: Downside to WPA2/WPA3? [Re: JHZR2] #5421872 05/05/20 05:24 PM
H
hallstevenson Offline
H
You can't use WPA3 if a client doesn't support it, right ? You mention (2) devices that don't work with it. I just bought a new router and didn't pay attention to the wireless security it uses although I'm 100% confident it's using WPA2 by default. Just use a proper passphrase, not password, and you will be fine.
My old SSID was "Echo Base Hoth" and I'm not afraid to post it now, the password was "Luke's Rogue Squadron". One of those password strength checkers says it would take 596 quintillion years to crack that password. I'm fine with that....
Re: Downside to WPA2/WPA3? [Re: JHZR2] #5421897 05/05/20 05:53 PM
O
Oildudeny Offline
O
Downside can just be a user error
Re: Downside to WPA2/WPA3? [Re: JHZR2] #5422092 05/05/20 09:19 PM
M
mattwithcats Offline
M
WPA2 is fine if you turn off SSID broadcast, and turn on Mac Address filtering...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Downside to WPA2/WPA3? [Re: JHZR2] #5422114 05/05/20 09:45 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
As it turns out, they removed the WPA3 capability in the latest firmware flash. Not sure why?
Re: Downside to WPA2/WPA3? [Re: JHZR2] #5422388 05/06/20 08:16 AM
Interesting. Probably causing more headaches with support than they wanted to deal with.
Re: Downside to WPA2/WPA3? [Re: mattwithcats] #5434520 05/20/20 07:14 PM
H
HangFire Offline
H
SSID broadcast buys you NOTHING in terms of security, as a moment's snooping will still reveal the SSD to a casual hacker. It only keeps away the noobs.
MAC filtering buys you very little, as you can see here:
https://www.howtogeek.com/192173/how-and-why-to-change-your-mac-address-on-windows-linux-and-mac/
Various musings: http://hangfire.net
Re: Downside to WPA2/WPA3? [Re: HangFire] #5434568 05/20/20 08:06 PM
O
OVERKILL Offline
O
Yes, I've told him all this before, but he ignores it shrug
