Any decent lap tops for $200.00 or less?
by BAJA_05 - 05/28/20 06:49 PM
New PW with Honda 190 engine - Ethanol treatment?
by DirtyApe - 05/28/20 06:38 PM
What size tube should a 110/50-6.5 Tire use?
by taztheman - 05/28/20 06:14 PM
C&P Allison Transmission Filter - 27k miles, 3 years
by shibby6600 - 05/28/20 05:51 PM
XG9100 - 7k miles - 9 months - filter magnet
by shibby6600 - 05/28/20 05:47 PM
2017 Audi A4 PCV Valve replacement
by dbias - 05/28/20 05:23 PM
Audi E-Tron Technik
by OVERKILL - 05/28/20 05:12 PM
Deer 1....My Avalon 0
by ZZman - 05/28/20 03:21 PM
Auto Dealers Supplies?
by cknight49090 - 05/28/20 03:09 PM
interesting video reg vs premium
by raaizin - 05/28/20 02:55 PM
Discount Tire Direct FLASH SALE
by Mr Nice - 05/28/20 02:42 PM
2021 Acura TLX Sports
by buster - 05/28/20 01:36 PM
Honda GC vs GS engines?
by Avery4 - 05/28/20 01:10 PM
Advanced auto parts
by Fitter30 - 05/28/20 12:52 PM
Is there a best time to switch to synthetic oil?
by Jgelack - 05/28/20 12:37 PM
Alignment good then bad
by Barkleymut - 05/28/20 11:56 AM
What's in the Box?
by BeerCan - 05/28/20 11:31 AM
High Gloss product for Silver car?
by tc1446 - 05/28/20 11:15 AM
oldcodger, cwllams1, Danwrig, DanielR, lagreca
71557 Registered Users
111 registered members (55hambone, 2010Civic, 2004tdigls, 928, AandPDan, 53' Stude, 10 invisible), 2,207 guests, and 40 spiders.
Topics305,990
Posts5,284,282
Members71,557
PUP From Napa, different! #5421645 05/05/20 12:58 PM
M
mahanddeem Offline OP
M
Hello,
Yesterday I ordered 1 quart bottle of Pennzoil Ultra Platinum 5w30 from Napa, today I received it. Point is, it's different from the 5-quart PUP (from Amazon) jug I had used for my previous oil change.
This quart bottle has API SN (not plus), and the label also seem different than what I assume is the current new PUP bottle labels.
Thoughts? I need to top my sump with half a quart!
See pics below
[Linked Image from i.ibb.co]
Re: PUP From Napa, different! [Re: mahanddeem] #5421654 05/05/20 01:04 PM
W
WylieCoyote Offline
W
My guess is your quart is older than your jug. I've personally never seen a jug of Ultra SN Plus, so thank you for that bit of information. I wasn't aware they'd 'upgraded' it.
2015 Canyon 3.6
2018 Mustang Ecoboost Convertible
2017 Focus ST
Re: PUP From Napa, different! [Re: WylieCoyote] #5421660 05/05/20 01:07 PM
M
M
All my PUP 5w30 jugs ordered from Amazon were SN plus!
I had ordered like 6 times before
Re: PUP From Napa, different! [Re: mahanddeem] #5421663 05/05/20 01:11 PM
W
WylieCoyote Offline
W
Weird. But I haven't shopped for it there, so..... None of the WalMart jugs I looked at were Plus, which is why I bought PP. Is their website wrong, or am I not interpreting the below correctly?
2015 Canyon 3.6
2017 Focus ST
Re: PUP From Napa, different! [Re: mahanddeem] #5421675 05/05/20 01:22 PM
M
M
I recall the topic here on which place sells the most recent versions of oil (between Amazon and Wal-Mart) and it seems Amazon is the most current based on this! Although never seen PUP on Walmart shelves.
Re: PUP From Napa, different! [Re: mahanddeem] #5421693 05/05/20 01:42 PM
H
hemitom Offline
H
well the date is june 15 2018 on the quart bottle ! so before the sn plus spec ??
2009 Saturn Vue.
2015 Mustang GT Convertible.
Re: PUP From Napa, different! [Re: mahanddeem] #5421762 05/05/20 03:10 PM
03s Offline
The one on Amazon is still SN Plus
Link
2005 Chevrolet Optra
Quaker State High Mileage Synthetic 5W30 Fram Tough Guard 3387A
Re: PUP From Napa, different! [Re: mahanddeem] #5421852 05/05/20 05:00 PM
DGXR Offline
Isn't your oil level between the two marks on the dipstick? I don't see the point in adding 1/2 quart. Either it is low and you add 1 quart, or it's not low and you don't add any.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: PUP From Napa, different! [Re: mahanddeem] #5421921 05/05/20 06:24 PM
A
Avery4 Offline
A
As other people have said, my guess is that it's simply an older bottle. For what it's worth the jugs of PUP 5W-30 that I ordered on Amazon a few months ago are API SN Plus certified.
Re: PUP From Napa, different! [Re: mahanddeem] #5422048 05/05/20 08:45 PM
LTZ10 Offline
Same here...I’ve yet to see PUP at any Walmarts in this area.
US Army Veteran
Law Enforcement Veteran
Re: PUP From Napa, different! [Re: mahanddeem] #5422061 05/05/20 08:52 PM
R
racin4ds Offline
R
Don't matter, dump it in! lol half a quart.... smile
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
'13 Passat TDi SE+Nav
Re: PUP From Napa, different! [Re: mahanddeem] #5422064 05/05/20 08:54 PM
I
Imp4 Offline
I
It's old stock from a Napa that was slow moving their inventory.
Nothing more.
Re: PUP From Napa, different! [Re: DGXR] #5422068 05/05/20 08:57 PM
M
M
Half a quart is 12 percent of engine oil, in my case.
I'm not comfortable driving around with 12% oil missing from the engine.
Re: PUP From Napa, different! [Re: mahanddeem] #5422084 05/05/20 09:10 PM
A
Avery4 Offline
A
The exact level is inconsequential as long as its between the two marks. Most people including myself wouldn't be comfortable driving with the oil right at the minimum mark because if something goes wrong or if the engine burns a little oil it's low, but the engine is just as well protected whether the oil is at the minimum or the maximum mark. The engine won't know the difference unless there is so little oil in the engine that the pickup screen is sucking air or so much that the crank is hitting it and causing it to foam up. Actually there is quite a bit of a safety margin built into the dipstick, the engine isn't going to blow up if you are an ounce below minimum or above maximum. However, that doesn't mean that you should run it low or overfill it.
It can be argued that lower oil level is better because less oil means a faster warmup in cold weather, more oil is better because the temp of a larger volume of oil is more stable, etc and there may be some truth to those arguments, how significant those factors are who knows. Realistically the oil will circulate and lubricate the engine the same way whether the level is at minimum or maximum.
Re: PUP From Napa, different! [Re: WylieCoyote] #5422622 05/06/20 12:22 PM
dave1251 Online Happy
Online Happy
I agree. Interesting.
don't use.
