Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
Best oil on the market?
by sloinker - 05/25/20 08:47 PM
Xfinity Race in Charlotte
by kstanf150 - 05/25/20 08:12 PM
Purolator PBL14610 C&P
by FordBroncoVWJeta - 05/25/20 08:00 PM
Carquest Blue 85522 C&P
by FordBroncoVWJeta - 05/25/20 07:52 PM
2020 RAV4 Hybrid - oil options
by CELICA_XX - 05/25/20 07:44 PM
any battery charger/repair that can fix sulfation?
by apollo18 - 05/25/20 07:28 PM
Need Mice Advice
by Mr_Luke - 05/25/20 07:01 PM
pressure washer air compressor oil
by bedwards - 05/25/20 06:49 PM
2014 Elantra delayed shift 4th to 5th
by Propflux01 - 05/25/20 05:51 PM
2002 Ranger Electrical Weirdness (GEM, RAP?)
by DuckRyder - 05/25/20 05:47 PM
Oil change problems
by philipp10 - 05/25/20 05:41 PM
Denso 150 3024
by thrace - 05/25/20 04:58 PM
does ac delco warranty the replacement battery?
by apollo18 - 05/25/20 04:39 PM
Water drainage issue
by Paul_Siu - 05/25/20 04:39 PM
13 Corolla PCV
by AJB0009 - 05/25/20 04:24 PM
SpaceX Launch - Wednesday
by MasterSolenoid - 05/25/20 04:15 PM
mikespine, Typerguy, showtyme1958, rickyradit, YogiTheCat
71528 Registered Users
26 registered members (blufeb95, bworley, bachman, BigRich954, ABCarr, 2 invisible), 1,449 guests, and 52 spiders.
Topics305,878
Posts5,281,956
Members71,528
Can I reuse a Nissan Transmission pan gasket? #5421581 05/05/20 11:47 AM
Dogred08 Offline OP
I have a 06 Pathfinder and I want to inspect the transmission filter and magnets after 127k miles. Nissan wanted 45 for just the gasket and eBay wants 30 for it. Is this thing using gold to seal it??? I've seen rubber gaskets at Napa for around 5 bucks would these work? Can I reuse the old one? Or can I just use some red high heat rtv silicone gasket maker by permatex? The OEM gasket is thin so I don't think it's used for a clearance in the pan.
Re: Can I reuse a Nissan Transmission pan gasket? [Re: Dogred08] #5421588 05/05/20 11:52 AM
Donald Offline
You need to have a new one on hand. Not a cheesy cork one either. Then when your in the process you will see if a new one is needed.
2015 Ford F-250 w/Powerstroke
Re: Can I reuse a Nissan Transmission pan gasket? [Re: Dogred08] #5421598 05/05/20 12:02 PM
doitmyself Offline
Felpro tranny gaskets are really great. More substantial material than plain rubber or cork.
There are reusable gaskets. The ones I saw were thin metal with a bead of rubber embedded.
Re: Can I reuse a Nissan Transmission pan gasket? [Re: doitmyself] #5421616 05/05/20 12:16 PM
Dogred08 Offline OP
Can you find me one I've tried looking everywhere and even their website but have had no luck at all finding one for this nissan. It's a 06 Pathfinder SE 4WD
Re: Can I reuse a Nissan Transmission pan gasket? [Re: doitmyself] #5421618 05/05/20 12:17 PM
Dogred08 Offline OP
[Linked Image]
Here is what it looks like
Re: Can I reuse a Nissan Transmission pan gasket? [Re: Dogred08] #5421621 05/05/20 12:21 PM
B
BMWTurboDzl Offline
B
I wouldn't. If the ATF is lifetime fill why would the gasket be re-usable?
435i
Re: Can I reuse a Nissan Transmission pan gasket? [Re: BMWTurboDzl] #5421629 05/05/20 12:34 PM
Dogred08 Offline OP
The atf is definitely not lifetime it even states it in the manual. I think that's some bs Toyota started with the world standard atf. But I've changed my fluid over to Valvoline max life full synthetic atf and it has worked really well it shifts smoother and stays the nice red color. The Nissan stuff turned a clearish brown color which I read online was normal when it was worn out.
Re: Can I reuse a Nissan Transmission pan gasket? [Re: Dogred08] #5421680 05/05/20 01:30 PM
J
Jimzz Offline
J
If its a thin piece of metal I have reused those on Infinities with no leaks. Or even a rubber with metal core is fine to reuse as well.
If its rubber with no metal core then I generally replace those.
yup
Re: Can I reuse a Nissan Transmission pan gasket? [Re: Dogred08] #5421709 05/05/20 02:05 PM
J
JTK Offline
J
Pretty sure I recall paying more than $5, 35yrs ago even for a junker cork gasket.
If some type of metal/rubber laminated gasket is available, those are worth $45 for an application like this IMO.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Can I reuse a Nissan Transmission pan gasket? [Re: Dogred08] #5421745 05/05/20 02:49 PM
J
JeffKeryk Offline
J
If it looks OK, I guess you can give it a try.
Your choice.
As other has said, better safe than sorry.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Can I reuse a Nissan Transmission pan gasket? [Re: Dogred08] #5421749 05/05/20 02:55 PM
slacktide_bitog Offline
no-no
If you drop the pan, replace the gasket.
Rock Auto has the OEM gasket for $20, but they only have one left!
Re: Can I reuse a Nissan Transmission pan gasket? [Re: JTK] #5421753 05/05/20 02:59 PM
Dogred08 Offline OP
This was the Napa one I was talking about it's definitely not cork. I just have several other parts to replace and need to use my extra money as little as possible like the OEM gasket costs more than the filter!
If rtv was an option I would prefer that but it doesn't seem l ike it is.
NAPA Gasket
Re: Can I reuse a Nissan Transmission pan gasket? [Re: Dogred08] #5421845 05/05/20 04:51 PM
sloinker Offline
Here's a filter and gasket from Amazon. Cheap. Make sure you follow the tightening sequence and have an inch pound torque wrench. ATP is widely used in shops.
https://www.amazon.com/dp/B00P1929I...comp-feature-scomp-wm-5&ref=aa_scomp
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Can I reuse a Nissan Transmission pan gasket? [Re: sloinker] #5421920 05/05/20 06:23 PM
Dogred08 Offline OP
Napa sells that exact same kit but the gasket is rubber and the reviews on the gasket are mixed which is the only thing I'm concerned about
