Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
19 registered members (deoxy4, buck91, bachman, Char Baby, blufeb95, 1 invisible), 1,093 guests, and 39 spiders.
Topics306,047
Posts5,286,364
Members71,593
Lucas Gun Oil (Red) #5421495 05/05/20 10:01 AM
ChrisD46 Offline OP
I picked up the above fire arm oil - no smell , good viscosity , stays put where you place it and the red color shows exactly where it is being placed .
Offers rust protection , doesn't dry out too much and appears to have sufficient good lubrication capabilities - all for like under $4.00 per 2 oz. bottle .
The Lucas "red" at of all places at an auto parts store where they were running a counter promotion with about 50 bottles in a open container for $3.85 per 2 oz. bottle .
So far the Lucas "red" checks all of the boxes but again , for about 40% more per bottle the Lucas Extreme (Green) may be better for semi - auto slides and such (due to higher viscosity) .
There is also a Lucas CLP that looks promising but I have tried this yet either .
'17 Hyundai Sonata 2.4L GDI 5W30 PUP / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: Lucas Gun Oil (Red) [Re: ChrisD46] #5421668 05/05/20 01:12 PM
P
Panzerman Offline
P
You can buy a Quart of Marvel Mystery oil for $3.99 and a Quart of ATF ( Your choice) for $2.99, mix the two and get 64 ounces of gun lube for $6.98 which comes out to $.43 per 2 ounce bottles that is Red and works well in guns.
What I have been using for years.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Lucas Gun Oil (Red) [Re: ChrisD46] #5423896 05/08/20 08:22 AM
E
Elkins45 Offline
E
I’ve been using a mix of 50% ATF 25% STP and 25% Mobil1 30wt for about 30 years now based on the recommendation of a NG armorer I used to shoot with. It’s the perfect mix of penetration, clinginess and temperature resistance.
Re: Lucas Gun Oil (Red) [Re: ChrisD46] #5424018 05/08/20 11:24 AM
CourierDriver Offline
IN Nam, the guys used kerosene , worked ok. Ive tried here , works great, smelly, you know....
I'd still like to have my 67 Beetle back....life was easy then..imho 2 quarts of oil roughly ,lol
No matter what time it is,its always time for a nap
Re: Lucas Gun Oil (Red) [Re: ChrisD46] #5424211 05/08/20 03:51 PM
ABN_CBT_ENGR Offline
Truth be known there is more personal preference and belief than actual fact of superior lubricating ability with weapons oils.
As long as the selected oil meets the needs of the weapon and isn't hygroscopic or gums when faced with heat from friction and firing or has some other adverse property- the weapon will function properly.
Anything beyond that is individual heuristics.
Personally I clean in the parts cleaner (because its already there) and unless customer specified other, it will get a straight weight ND engine oil- and that's ONLY because its available because its my curing fluid and displacement media post bluing.
Re: Lucas Gun Oil (Red) [Re: CourierDriver] #5424258 05/08/20 05:12 PM
K
Kamele0N Offline
K
Odorless lamp oil..... smile
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
Re: Lucas Gun Oil (Red) [Re: ChrisD46] #5425301 05/10/20 08:00 AM
R
Robster Offline
R
I'm currently using Lucas "green" extreme on my firearms that I picked up at a gun show. For the reasons you mention, I like it. I've had some extended range sessions with it and had no problems. So far I've used it on a Glock, Springfield, and Taurus (all semiauto) with no issues. For cleaning, I use M-Pro cleaner--works great, no smell.
2017 RAM 1500 Big Horn 5.7L:Valvoline AFS 5w-20, Fram TG10060
2019 Hyundai Santa Fe Ultimate AWD 2.4L:Valvoline AFS 5w-20 / OEM filter
2013 Victory Cross Country:Valvoline 4T syn 10w-40, NAPA Gold
Re: Lucas Gun Oil (Red) [Re: ChrisD46] #5425311 05/10/20 08:13 AM
I
IndyFan Offline
I
Battlefield Vegas runs Lucas oil, but I'm not sure which one. I'm guessing the red. They run it on all their guns and they love it. They put more rounds downrange than anyone I can think of and they run their guns HARD, mostly full-auto. I'd say that is as good a testimonial for Lucas as you'll find. Look them up on Arfcom or just call them up and ask them. They'll rave about it, and they've tried MANY. They like that the Lucas stays put and doesn't spray all over the operator (customer).
I run the red in all my guns but I've got some green, too, in case I go hunting in cold, cold winter temps. I've also thought of just using Mobil 1 0w20 in those conditions.
18 Jeep JLUR Wrangler 3.6 31k
15 Ford Transit 129k, Reman 3.5 @85k
17 Jeep Renegade 2.4 29k
08 Jeep Wrangler 3.8 141k
04 Jeep Grand Cherokee 4.7 111k
99 Mercedes E430 Sport 90k
Re: Lucas Gun Oil (Red) [Re: ChrisD46] #5427696 05/12/20 08:25 PM
B
buck91 Online Content
Online Content
B
I'll stick with Breakfree for over-priced gun boutique oil. The CLP is fine but the "LP" is where its at.
2018 F150 Screw 4x4 2.7L Ecoboost
2011 F150 Scab 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Lucas Gun Oil (Red) [Re: ChrisD46] #5427762 05/12/20 10:21 PM
BlueOvalFitter Offline
I use GRIZZLY GREASE, brake clean spray, Throttle Body cleaner spray, or Hoppe's solvent.
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: Lucas Gun Oil (Red) [Re: ChrisD46] #5436950 05/23/20 07:30 PM
Marco620 Offline
Gunzilla
15' Civic r18, 335,000 mi M1 0w30/5w30 & LG Biotech,Castrol CVT Fluid,Redline Si-1
Dog Whisperer! Honda/Acura nerd; detest ethanol,wind, and anything vegan.
