Forums Migration
Please read this thread
Glock Gen 5 .40 Caliber
by BlueOvalFitter - 07/12/20 08:34 PM
Help me determine if my CVT fluid has been changed
by Dallasmale1970 - 07/12/20 08:01 PM
Hyundais, Hyundais, Hyundais!
by csandste - 07/12/20 07:57 PM
Traveller's (WPP) $10.99 - 5 QT
by Gene K - 07/12/20 07:26 PM
PEAK 10X or Peak Global Lifetime
by pbm - 07/12/20 07:25 PM
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Japan unveils timeline for indigenous fighter jet program
by gathermewool - 07/12/20 12:27 PM
NEW Rotella T6 15w40
by ToadU - 07/12/20 11:54 AM
Mark_C, fxxkat, Ajreitano, Slick122, Ford4life76
71917 Registered Users
107 registered members (Anthony, 2018matto, ArrestMeRedZ, Aichiguy, 87sammy, 11 invisible), 2,007 guests, and 33 spiders.
Topics307,777
Posts5,317,602
Members71,917
Clogged zerk remedy? #5421329 05/05/20 04:58 AM
dlundblad Offline OP
What’s everyone’s fixes for these?
I also have a LockNLube coupler. Works great and arguably helps, but if it’s really clogged, it won’t do a thing besides fill the gun hose with grease and spew out when you remove the coupler. Lol.
Some people say to apply heat. The area is painted so I’d rather not unless a heat gun would work.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Clogged zerk remedy? [Re: dlundblad] #5421333 05/05/20 05:08 AM
demarpaint Offline
I clean the zerk fittings before and after greasing them, then cap them with the rubber caps used to seal vacuum lines. The king pins and drag link on my 88 Ford are OE, with the original zerk fittings which are not clogged and work perfectly.
God Bless Our Troops
Re: Clogged zerk remedy? [Re: dlundblad] #5421339 05/05/20 05:25 AM
Z
ZeeOSix Offline
Z
Try a heavy duty soldering iron.
Re: Clogged zerk remedy? [Re: dlundblad] #5421343 05/05/20 05:46 AM
I
Imp4 Online Content
Online Content
I
Can you unscrew the zero fitting?
Then clean it out and clean out any wax buildup in the female thread.
Reassemble and give it a go.
Re: Clogged zerk remedy? [Re: dlundblad] #5421369 05/05/20 06:49 AM
Donald Offline
They sell a kit to free the zerk fittings.
Alemite 339841 Zerk-Mate Grease Fitting/Joint Cleaner,Silver; Gold/Yellow; Black
Its pricey. I paid a lot less when I bought it in 2015.
2015 Ford F-250 w/Powerstroke
Re: Clogged zerk remedy? [Re: dlundblad] #5421398 05/05/20 07:36 AM
K
krismoriah72 Offline
K
Re: Clogged zerk remedy? [Re: dlundblad] #5421401 05/05/20 07:39 AM
Snagglefoot Offline
Sometimes it’s not the fitting where the problem is. It can be inside the item, such as an inner ball joint. In on case I completely changed the zerk fitting then obtained a zerk fitting cleaner, not for the zerk but for what was beyond.
A zerk fitting cleaner ( quality varies) can work well. Put a solvent in it and give it a hit with a hammer. I’ve been able to inject some solvent, let it sit for a few days and when I came back it was clear and I injected a copious amount of grease.
If you want the job done right......do it yourself.
Re: Clogged zerk remedy? [Re: dlundblad] #5421421 05/05/20 08:00 AM
A
ARCOgraphite Offline
A
Uhh, replace them? .. I have a whole little box of them - straight and 45 degree.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Clogged zerk remedy? [Re: dlundblad] #5421444 05/05/20 08:43 AM
6
64bawagon Offline
6
We never fought with them, they are too cheap to waste time trying to free up, replace it and move on. If the joint itself was clogged we shot it full of PB blaster, put the fitting back on and pressurized it with grease then noted it on the maintenance report and checked it the next time.
64 Chevy wagon, 10 Jeep Wrangler, 18 Silverado 1/2 ton
Re: Clogged zerk remedy? [Re: dlundblad] #5421465 05/05/20 09:15 AM
R
ragtoplvr Offline
R
some greases are not compatible and turn rock hard. Modem grease guns and fittings are not capable of high pressure. My old gun and chuck are rated at 10,000 PSI it can be very hard to pump and the fitting will stick on. But it breaks anything free.
Rod
Re: Clogged zerk remedy? [Re: ARCOgraphite] #5421473 05/05/20 09:28 AM
Char Baby Offline
Yeah, I do the same.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Clogged zerk remedy? [Re: dlundblad] #5421560 05/05/20 11:28 AM
spasm3 Offline
i've used a pick, and tapped it with a small wrench or ball peen.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Clogged zerk remedy? [Re: Snagglefoot] #5422247 05/06/20 04:21 AM
This has always been my understanding too. I have my doubts that the fitting is the issue so we shall see.
I can’t recall if it is even replaceable.
03 Jeep WJ 4.0 208k
04 Audi A4 3.0 210k
Re: Clogged zerk remedy? [Re: dlundblad] #5422264 05/06/20 05:26 AM
L
Lubener Offline
L
I replace the zerk fitting first.
The "thinking" man's friend.
Re: Clogged zerk remedy? [Re: dlundblad] #5422841 05/06/20 05:19 PM
super20dan Offline
the pick and hammer method almost always works
99 silverado 5.3
2003 tundra v6
1981 toyota cressida wagon
2003 kia sorento
04 toyota highlander 4cyl 2013 toyota rav4
