Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
Eezox vs Prolix?
by Gebo - 06/03/20 11:49 AM
Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Ghosty, zmann96, yetti96, weekendwally, Bugsbrewery
71601 Registered Users
94 registered members (2oldtommy, 55hambone, 830Lee, 1911CHAMPION, apollo18, 53' Stude, 10 invisible), 2,040 guests, and 26 spiders.
Topics306,103
Posts5,287,506
Members71,601
Very basic plumbing DIY question #5421346 05/05/20 05:52 AM
Carmudgeon Offline OP
Getting ready to replace a kitchen sink garbage disposal, and want to have everything on hand to avoid an extra trip to the store -- including new washer(s) for the P-trap.
I can't remember what it looked like last time, but from what I can gather now, since it's a metal trap, it calls for a square-cut rubber washer, and not the beveled plastic washers which are meant for PVC traps, correct?
Any reason to replace the nut if it's not chewed up?
Since it's a straight swap from one ISE to another, I figure I can keep the mounting and transfer the power cord.
Re: Very basic plumbing DIY question [Re: Carmudgeon] #5421361 05/05/20 06:41 AM
Donald Offline
I would consider replacing the P-trap with PVC. Over the years the metal ones corrode away. At least check the metal P-trap to make sure its solid.
2015 Ford F-250 w/Powerstroke
Re: Very basic plumbing DIY question [Re: Carmudgeon] #5421403 05/05/20 07:41 AM
M
mahansm Offline
M
One other thing to consider is that if you're going to keep the house for any substantial period of time you'll be replacing the disposer again. I'd look at replacing the hard wired electrical connection with a switched outlet under the sink (from the same feed/switch you are using now) and a standard plug to pigtail cable to provide power. This will allow you to unplug power when taking the old unit out, swap the cable (or replace as required) from the old unit to the new on your workbench, and then plug the new disposer into the outlet after the physical install.
'14 Honda CR-V (toad)
'09 Honda Odyssey
'99 Bluebird Wanderlodge 43 LXi
Re: Very basic plumbing DIY question [Re: Carmudgeon] #5421404 05/05/20 07:42 AM
doitmyself Offline
No reason to replace the nut if it is not corroded. I think you are correct about the washer.
You are kidding yourself if you think you can get the job done with only one trip to the store, LOL. That's a guaranteed rule of DIY plumbing...3 trips back to the store on any plumbing project. grin I usually take it apart before the store trip to unveil any unforeseen problems.
Re: Very basic plumbing DIY question [Re: mahansm] #5421430 05/05/20 08:16 AM
Donald Offline
If you do that you will need a GFI outlet as it will be within 6' of the sink.
Re: Very basic plumbing DIY question [Re: Carmudgeon] #5421437 05/05/20 08:30 AM
F
Fitter30 Offline
F
If you have a dishwasher don't forget to knock the plug out of the drain fitting.
Re: Very basic plumbing DIY question [Re: Carmudgeon] #5421454 05/05/20 09:01 AM
T
Touring5 Offline
T
I've found that plastic is preferable for traps because, as previously mentioned, it won't corrode. I have seen connections to sinks that use the square washer. I generally get a bag of the rubber washers and pitch the polyethylene ones - the chances of getting a leak are greatly reduced.
FIRST LAW OF DEBATE
Never argue with a fool - people might
not know the difference.
Re: Very basic plumbing DIY question [Re: Touring5] #5421506 05/05/20 10:24 AM
F
ffhdriver Offline
F
I have never connected a dishwasher to the disposal. There is a special Y fitting for this. Figured the disposal might last longer.
Re: Very basic plumbing DIY question [Re: Carmudgeon] #5421595 05/05/20 12:00 PM
Yah-Tah-Hey Offline
If you plan on staying in that house for more than a year or two, purchase the best disposal available.
Re: Very basic plumbing DIY question [Re: Donald] #5421605 05/05/20 12:05 PM
W
Wolf359 Online Content
Online Content
W
You don't need a GFCI if it is a dedicated outlet for a specific device like a garbage disposal. Only if it's a general purpose outlet. So add a single outlet instead of a duplex under the sink.
Also I wouldn't use PVC, they eventually leak from those plastic connectors. Metal is better, typically lasts longer. If not metal, black ABS and glue it.
Re: Very basic plumbing DIY question [Re: doitmyself] #5421701 05/05/20 01:53 PM
T
TMoto Offline
T
Ain't that the truth!! Been there, done that, and got the t-shirt.
Weekdays aren't too bad but weekday evenings and weekends at the hardware stores around here are a 30-45 minute wait standing in line to get in so minimizing trips is important.
Put 2 BITOGers together and you'll get 3 opinions
Re: Very basic plumbing DIY question [Re: Carmudgeon] #5421881 05/05/20 05:37 PM
J
JLawrence08648 Online Content
Online Content
J
I am not an electrician but my sister bought a new Condo last year and the site supervisor and was told the garbage disposal switch must be under the sink, that is inside the cabinet, and the wire must be armoured.
2019 Hyundai Santa Fe SEL Plus, 2.4
1992 Acura Vigor GS, 2.5
Re: Very basic plumbing DIY question [Re: JLawrence08648] #5421888 05/05/20 05:42 PM
W
Online Content
W
That might be local code or local authority decision. I see them on the wall next to the sink all the time.
Re: Very basic plumbing DIY question [Re: Wolf359] #5422164 05/05/20 11:07 PM
H
hallstevenson Offline
H
Something like this can definitely vary by location unless the NEC requires it. As I understand it, NEC is the baseline and then local inspection authorities can impose stricter rules but not less strict rules.
I can understand spec'ing armored cable though. I've never seen a disposal that had the wiring neatly stapled up or anything. It's always just drooped from the 'box' to the disposal. Then you have people storing stuff in there, getting stuff in and out - armored cable makes sense. No point stapling it out of the way either as it would make disposal replacements trickier if the wiring ends up too short (junction box further away) or extra wire if it's closer.
Re: Very basic plumbing DIY question [Re: Carmudgeon] #5422242 05/06/20 03:43 AM
Thank you, folks.
The trap appears to be solid, with no leaking, but I'll keep that in mind.
The cord will be an easy swap, because it's powered by a switched outlet, so I can yank it and do it on the bench.
I've generally had good luck with ISE, and need to replace them only because corrosion causes the turntable to seize up. This one has also developed a bad bearing, but it's probably 25 years old.
Hopefully, some level of quality still exists, but I wouldn't be surprised if it doesn't last as long, as with lots of stuff now.
