Vredestein will start making American-market specific tires
by slacktide_bitog - 06/05/20 11:33 PM
Fried plantain question
by aquariuscsm - 06/05/20 11:08 PM
Castrol Edge LL IV 0w20, not majority PAO
by wemay - 06/05/20 09:08 PM
Fram Titanium 20k mile oil filters at AAP....
by bbhero - 06/05/20 09:04 PM
D-Day 🇺🇸
by kstanf150 - 06/05/20 08:57 PM
Husqvarna 5.2 ounce 2 stroke oil .39 ymmv
by maintenanceMan - 06/05/20 08:53 PM
Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
Two Motorcraft FL400S Filters Cut Open
by HX520W - 06/05/20 04:36 PM
VIN character that designates engine
by grampi - 06/05/20 04:35 PM
Two WIX 57356XP Filters Cut Open
by HX520W - 06/05/20 04:17 PM
Blue lights on Uber vehicles
by John_Conrad - 06/05/20 04:08 PM
2015 RAM EcoDiesel 3.0L, 5,354mi, M1 TDT 5w40
by SavagePatch - 06/05/20 03:18 PM
3Dperf, LouK2, Michael328i, tyman, Knot_A_Mekanik
71616 Registered Users
70 registered members (Alfred_B, aba4430, Blkstanger, ArrestMeRedZ, 77GrandPrix, aquariuscsm, 5 invisible), 1,249 guests, and 35 spiders.
Topics306,272
Posts5,289,371
Members71,616
A little dab of sealant. #5421197 05/04/20 09:06 PM
Snagglefoot Offline OP
I’m going to be installing a new oil pan gasket in my Ford Taurus. All sources I checked said put a dab of sealant at the appropriate corners when installing the Fel-Pro gasket. Normally, I’d use Permatex Ultra Black. Only problem is I’m renting a lift at a self serve garage called U-Wrench and will be driving away after the job, a 10 mile trip. I understand If I used “The Right Stuff” by Permatex I could do this. Do you think there’s a chance I might screw up the Ultra Black if I drove it away before it set up? Also, perhaps “ The Right Stuff” is too thick for this purpose? Thanks.
If you want the job done right......do it yourself.
Re: A little dab of sealant. [Re: Snagglefoot] #5421207 05/04/20 09:22 PM
T
TheLawnRanger Offline
T
Most of the Fel-Pro gaskets say to apply dry. There is something made into them that helps them seal and some are made to stay lined up during installation. Their gaskets that require a sealant usually have it included.
https://www.felpro.com/technical/field-test-garage/use-and-misuse-of-sealers.html
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
Re: A little dab of sealant. [Re: Snagglefoot] #5421208 05/04/20 09:22 PM
Donald Offline
The sealant is just to hold the gasket in place while you install the oil pan. Once the pan is in place and bolts have been tightened, the sealant is no longer needed.
2015 Ford F-250 w/Powerstroke
Re: A little dab of sealant. [Re: Snagglefoot] #5421223 05/04/20 09:41 PM
clinebarger Offline
If there's a joint/s along the oil pan sealing surface....Like for a Timing Cover or Rear Main Adapter....Sealant IS required at those joints.
Right Stuff will work fine, Just don't let it "Tack" too long! This is actually a perfect application for Hylomar M or Blue....The solvent evaporates quickly enough that once you're done, You can drive it home.
2001 Chevy Camaro L92/4L80E
Re: A little dab of sealant. [Re: clinebarger] #5421249 05/04/20 10:17 PM
Originally Posted by clinebarger
IThis is actually a perfect application for Hylomar M or Blue....The solvent evaporates quickly enough that once you're done, You can drive it home.
Thanks, how would I choose between Blue or M. Anything I should know about? Thanks.
Re: A little dab of sealant. [Re: Snagglefoot] #5421255 05/04/20 10:34 PM
Chris142 Offline
Often a little sealer is used where say the block and timing cover meet. I put them together then go to lunch. I put the oil in after lunch and never had a leak.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: A little dab of sealant. [Re: Snagglefoot] #5421261 05/04/20 10:40 PM
clinebarger Offline
If I had to chose for the given application....Hylomar M. Where for O-ring dressing I like Blue as it's not quite as adhesive.
Re: A little dab of sealant. [Re: Snagglefoot] #5421303 05/05/20 12:59 AM
IMSA_Racing_Fan Offline
Weatherstrip adhesive works even better.
Re: A little dab of sealant. [Re: Snagglefoot] #5421406 05/05/20 07:43 AM
Thanks everyone. smile
