Horsepower in Various Modes
by Al - 06/01/20 11:39 AM
ATF Flush vs Drain and Fill
by diyjake - 06/01/20 11:24 AM
Is Your Vehicle Deadly?
by SubLGT - 06/01/20 11:02 AM
Question on the bottom of bottle with Penz Platinum
by babyivan - 06/01/20 10:55 AM
Used Mitsubishi Lancer prices
by 97prizm - 06/01/20 10:32 AM
Which oil is the better quality
by galaxy333 - 06/01/20 09:57 AM
"Boutique" Brands
by buster - 06/01/20 09:15 AM
CASTROL Edge 5w20 or EP 5w20
by 53' Stude - 06/01/20 09:09 AM
BT Oil
by js1956 - 06/01/20 09:00 AM
How to Properly Read a Dipstick
by Gebo - 06/01/20 07:59 AM
Why did some older cars have + grounded systems?
by JLawrence08648 - 06/01/20 07:39 AM
Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
C6H8O7, Jcvjr, Haywood, ToOliwer, AbbeyRoad
71588 Registered Users
91 registered members (ABN_CBT_ENGR, Arcoril, 2009Edge, Al, 2015_PSD, aquariuscsm, 10 invisible), 2,320 guests, and 29 spiders.
Topics306,122
Posts5,286,878
Members71,588
Swap out transmission filter or just let it be. #5421163 05/04/20 08:27 PM
M
Micahmcmeen Offline OP
M
planned on changing the transmission fluid in my 2008 Mazda 5 with about 115,000 miles on it. Normally I would do the filter but this bad boy has a drain plug on the bottom of the fluid pan. Should I just do the extra work and change the filter or just change the fluid. The fluid does appear to be pretty clean still.
Re: Swap out transmission filter or just let it be. [Re: Micahmcmeen] #5421175 05/04/20 08:40 PM
I
Inspecktor Offline
I
If it has not been changed, I would put in a new filter. After than, drain and fill to your heart's content. Did one filter change on the buick in sig, then a few drain and fills. It is about to crack 300k on original trans.
2004 Mini Cooper 43,000 mi
2006 Dakota 4.7 156,000 mi
1986 GL1200A 74,500 mi
2001 Buick LeSabre Limited 299,800 mi
2001 Subaru Outback 169,000 mi
Re: Swap out transmission filter or just let it be. [Re: Micahmcmeen] #5421181 05/04/20 08:42 PM
Snagglefoot Offline
Yes, Time for a new filter. You can still use the drain to empty out the pan. Much less of a mess. smile
If you want the job done right......do it yourself.
Re: Swap out transmission filter or just let it be. [Re: Micahmcmeen] #5421190 05/04/20 08:50 PM
clinebarger Offline
Cleaning the magnets in the pan is important....Especially to the Solenoids.
2001 Chevy Camaro L92/4L80E
Re: Swap out transmission filter or just let it be. [Re: Micahmcmeen] #5421199 05/04/20 09:11 PM
JohnnyJohnson Offline
Change it how do you know it isn't a Tare O later?
2004 Corolla 140116
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77077
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Swap out transmission filter or just let it be. [Re: Micahmcmeen] #5421232 05/04/20 10:01 PM
J
JeffKeryk Offline
J
I would probably just do a spill and fill.
If i changed the filter, I would use a factory filter. Good luck.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Swap out transmission filter or just let it be. [Re: Micahmcmeen] #5421243 05/04/20 10:08 PM
Donald Offline
How long has the filter been in place? If it has over 1/2 your mileage (roughly 60K) I would change it. Not very expensive. The drain plug makes the job less messy.
2015 Ford F-250 w/Powerstroke
Re: Swap out transmission filter or just let it be. [Re: Micahmcmeen] #5421247 05/04/20 10:16 PM
slacktide_bitog Offline
There is no need to replace the filter smile
Re: Swap out transmission filter or just let it be. [Re: clinebarger] #5421293 05/05/20 12:36 AM
IMSA_Racing_Fan Offline
I agree with the magnet cleaning. Has anyone ever put two magnets in a trans pan? Also what about those oil filterwrap around magnets?
2012 Cadillac CTS 3.0
1997 Ford Aspire
1991 Jaguar XJ6
1986 Kawasaki ZG1000 Concours
Re: Swap out transmission filter or just let it be. [Re: Micahmcmeen] #5421297 05/05/20 12:43 AM
sloinker Online Shocked
Online Shocked
Change the filter. After 115k miles there will be an abundance of clutch material in the filter and plenty of worn steels on the magnets. I am sure the owners manual has an interval and it will be less than 115k miles.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Swap out transmission filter or just let it be. [Re: IMSA_Racing_Fan] #5421301 05/05/20 12:55 AM
clinebarger Offline
Japanese makes like using several small magnets vs Domestic with 1 or 2 larger magnets in the trans pan.
Re: Swap out transmission filter or just let it be. [Re: sloinker] #5421318 05/05/20 02:57 AM
Snagglefoot Offline
The owners manual has six pages on appearance care and nothing about changing transmission fluid. Crazy.
Re: Swap out transmission filter or just let it be. [Re: Donald] #5421322 05/05/20 03:47 AM
M
M
No Idea. I but the car recently and I just assume do it to be safe.
Re: Swap out transmission filter or just let it be. [Re: IMSA_Racing_Fan] #5421328 05/05/20 04:47 AM
demarpaint Offline
I have two OE magnets in both of the transmission pans in my two Jeeps. I did that under the advisement of two well respected Bitog friends.
God Bless Our Troops
Re: Swap out transmission filter or just let it be. [Re: Micahmcmeen] #5421416 05/05/20 07:54 AM
B
Barkleymut Offline
B
Can these OE magnets be purchased on RockAuto or are they a dealer only thing?
09 Vue 2.4L 4spd AT/ 09 Flex 3.5L / 96 F150 5.0 5speed / 07 Mustang GT auto
