New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
Should I buy a "B" Temperature tire for 2016 Pilot?
by oily boyd - 07/04/20 11:15 AM
Happy 4th of July
by 4WD - 07/04/20 09:12 AM
Collective car nouns, real and imagined
by MrHorspwer - 07/04/20 08:44 AM
Motorcraft FL-820S, ~9000 miles
by robertcope - 07/04/20 08:42 AM
FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
94 registered members (14Accent, 97trophy, 55hambone, 2010Civic, 2015_PSD, 2009Caraman, 9 invisible), 1,583 guests, and 28 spiders.
Topics307,426
Posts5,310,800
Members71,843
High Mileage Oil Seal Damage Debate; Finally Ended? #5420959 05/04/20 04:19 PM
A
AJB0009 Offline OP
A
I have only recently started posting on this site, but I have been reading for several years. It seems that the topic of high mileage oils often brings out the most passion in many people.
I work in industrial maintenance. Where I work, we use all Mobil lubricants. I often use Mobil's forum, much like this site, but focused on industrial topics. www.club.mobilindustrial.com
I recently posted a question in the "Ask the Experts" thread. Here is what I asked:
There is a popular motor oil forum called Bob Is The Oil Guy. More than any other topic, high mileage motor oil brings out the most passionate dialog. There are many whom are staunchly opposed to the use of high mileage oil, unless you are having issues. They say that if you put high mileage oil in an engine that does not have any leaks, smoke, noise, etc. you will actually cause damage to the engine. They contend that high mileage oils contain seal swellers that will actually damage many seals over time by softening them too much, etc. They go on to say that in areas that engine manufactures use silicone based sealants rather than gaskets, high mileage oil additives will break that sealant down over time too and cause additional leaks. Then there are those that say the opposite, high mileage oil is fine to use in any engine with no worries. There are also some whom sing praises of high mileage oil saying that their engines had leaks that stopped once they started using high mileage oil. Could we please get some honest, candid, facts from engineers whom know the truth about what is in that oil and all of the different possible outcomes of using it? It would be wonderful to put some of this banter to rest. Thank you!
The response came today from Korey Sargent, Lubrication Support E.I.T in Fuels and Lubricants Marketing at Exxon Mobil. Here is what he said:
Seals tests are part of the testing requirements for many specifications and claims. Specifically ASTM test D7216 is required for ILSAC and API performance claims. Mobil 1 motor oils are tested for compatibility with many types of seal materials including silicone seals. As lubricant developers, we are not always privileged to know the specific elastomers in each engine for each manufacturer. We rely on the auto manufacturers to ensure that all the relevant seal materials are required in the industry required tests or their own proprietary tests. Both regular and high mileage oils are tested in the industry or proprietary seal tests required for the claims that are listed on the PDS of the product. There should be no issues with using a high mileage product in a newer vehicle as long as that product meets the viscosity and claims required by the manufacturer. Lastly, we always recommend that our customers consult their owner’s manual to ensure they are choosing the correct lubricant for their vehicle.
13 Toyota Corolla S 1.8; Valvoline FS HM 0W20, OEM filter
12 Ford Fusion 2.5; Castrol EDGE 5W30, CQ Blue 85348
06 Toyota Tacoma 2.7; M1 HM 5W30, Wix XP
04 Ford Explorer 4.0; MC SB 5W30, MC FL820-S
Re: High Mileage Oil Seal Damage Debate; Finally Ended? [Re: AJB0009] #5420996 05/04/20 05:08 PM
CT8 Offline
We at BITOG have people that believe what they heard. If the oil meets the specs how can it be not proper for use in its intended engine, Yes I always refer to the major brand oil Shell Chevron Mobil Castro and the top of the line private brand blenders. [The Warren types]
2015 F150 2.7
2018 F350 6.2
Re: High Mileage Oil Seal Damage Debate; Finally Ended? [Re: AJB0009] #5421013 05/04/20 05:32 PM
O
OilUzer Offline
O
Sounds like @kschachn wrote or helped with that response grin2
Good response btw.
Re: High Mileage Oil Seal Damage Debate; Finally Ended? [Re: AJB0009] #5421400 05/05/20 07:38 AM
R
ragtoplvr Offline
R
any oil is better than no oil
Clean oil is better than dirty worn out oil
Oil meeting manufacturers specifications is better than clean oil
An oil filter that is not split or clogged is better than a used up oil filter.
A premium filter is better than any filter.
There, now we can shut down the forum
banana
Re: High Mileage Oil Seal Damage Debate; Finally Ended? [Re: ragtoplvr] #5421411 05/05/20 07:47 AM
B
buster Offline
B
banana
LOL
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
