Forums Migration
Please read this thread
Help me determine if my CVT fluid has been changed
by Dallasmale1970 - 07/12/20 08:01 PM
Hyundais, Hyundais, Hyundais!
by csandste - 07/12/20 07:57 PM
Traveller's (WPP) $10.99 - 5 QT
by Gene K - 07/12/20 07:26 PM
PEAK 10X or Peak Global Lifetime
by pbm - 07/12/20 07:25 PM
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Japan unveils timeline for indigenous fighter jet program
by gathermewool - 07/12/20 12:27 PM
NEW Rotella T6 15w40
by ToadU - 07/12/20 11:54 AM
2001 Silverado 1500 4x4 Alignment Concerns
by Blang - 07/12/20 11:37 AM
Mark_C, fxxkat, Ajreitano, Slick122, Ford4life76
71917 Registered Users
105 registered members (alchargo, 92saturnsl2, apollo18, 2004tdigls, 77GrandPrix, 7 invisible), 1,962 guests, and 29 spiders.
Topics307,776
Posts5,317,553
Members71,917
Got a toilet question #5420658 05/04/20 10:24 AM
M
mclasser Offline OP
M
Toilet wasn't flushing correctly; turned out the old fill valve was leaking water out the top. Bought the same replacement part (Flushmaster 400A) and set the height & water fill level correctly as listed in the instructions.
Toilet flushes great again but now once a day, it makes a running noise for like 2 seconds. Doesn't phantom flush but just a running noise. The old busted part never did this. I ruled out a possible bad flapper by adding some food coloring to the tank water; the bowl stayed clean,
Is the new fill valve bad out-of-the-box?
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Got a toilet question [Re: mclasser] #5420665 05/04/20 10:35 AM
JohnnyJohnson Offline
Could it be your float needs to be adjusted just a hair? Watch it fill if is to close to the top of the drain pipe sometimes the valve may not shut all the way off.
2004 Corolla 140744
Out: Pennzoil Platinum HM 5W-20 ST 4386
In: Valvoline Synpower Full Synthetic 5W-30 Purolator PureONE
2006 Duramax 77117
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Got a toilet question [Re: mclasser] #5420666 05/04/20 10:36 AM
B
Barkleymut Offline
B
I have noticed the same thing after replacing the internals on 2 different toilets in my house. Since it is so infrequent I decided that I don't care. It has become less frequent over the past year, maybe once a week or so.
09 Vue 2.4L 4spd AT/ 09 Flex 3.5L / 96 F150 5.0 5speed / 07 Mustang GT auto
Re: Got a toilet question [Re: mclasser] #5420675 05/04/20 10:41 AM
O
Oildudeny Offline
O
As mentioned check the float level, is your supply fully opened? if a multi turn valve.
Re: Got a toilet question [Re: mclasser] #5420678 05/04/20 10:44 AM
M
mk378 Offline
M
If the fill valve keeps opening the water must be going somewhere. Either it is set too high and going down the overflow tube or the flapper is leaking.
You could close the supply valve and without flushing check if the level in the tank drops.
Re: Got a toilet question [Re: JohnnyJohnson] #5420685 05/04/20 10:58 AM
F
Fattylocks Offline
F
It is that wee tiny adjustment. I fiddled around with the float level a dozen times before it settled in and was happy.
94 Caprice Wagon Daily driver sold
05 Focus Wagon 2.0 Duratech city car sold
05 Mustang GT Convertible sold
05 P71 ex Homeland Security
12 Ford Explorer XLT Base
11 Nissan Titan SV King cab 4x4
Re: Got a toilet question [Re: mclasser] #5420687 05/04/20 11:00 AM
P
Paul_Siu Offline
P
When you hear that phantom flush, try opening the cover and see where the water level is at. Is it over the top of the tube? If it's going over, the water would run into the bowl.
Paul
Re: Got a toilet question [Re: mclasser] #5420697 05/04/20 11:14 AM
A
Aredeeem Offline
A
Had the same problem with mine. The round silicone seal on the bottom of the flapper has tiny valleys and bumps, too small to even see or feel that allows water to get past it, lower the water level in the tank, and cause a short phantom re-fill. Take a finger tip dab of Vaseline and run it around and on that seal. Worked for me.
Re: Got a toilet question [Re: mclasser] #5420700 05/04/20 11:16 AM
A
Aredeeem Offline
A
No need to remove the flapper, just reach in, pull it back and coat the seal. Doesn’t need much.
Re: Got a toilet question [Re: Aredeeem] #5420725 05/04/20 11:57 AM
M
MasterSolenoid Offline
M
So if the 'bottom of the flapper' is leaking, the water should be going into the Bowl.
Add some Food Dye in the tank and next day see if the Bowl has coloring in it / maybe just a poor fitting flapper.
At least you would NOT have to mess with any other components.
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Got a toilet question [Re: Aredeeem] #5420726 05/04/20 11:59 AM
P
pandus13 Offline
P
This (confirmed with 3 different toilets at 3 different houses).
Worst case, a new Fluidmaster replacement flapper is cheap.
Also, some in the house may pull just hard enough to kink the chain into an obstruction.
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: Got a toilet question [Re: mclasser] #5420747 05/04/20 12:20 PM
Dave9 Offline
There are only 3 places the water could be going to cause it to keep topping off.
1) Evaporation, tank lid off and gale force wind blowing at it. You'd notice. wink
2) Crack in tank, leaking on floor
3) Getting past flapper. if it is a very tiny rate, you might not notice the food coloring.
Flappers get old and harden, and the mating lip can get water deposits or fungus. Clean both, and sometimes I'll put a light layer of silicone grease on the flapper mating seal area and get a few more months out of it before replacement.
Re: Got a toilet question [Re: mclasser] #5420797 05/04/20 01:16 PM
AZjeff Offline
The float could be dragging on the standpipe causing strange fill problems. A flapper is $5, how much time does one spend to get a little more life out of one?
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Got a toilet question [Re: mclasser] #5420805 05/04/20 01:20 PM
W
Wolf359 Online Content
Online Content
W
The flapper and fill valve go all the time. Should change the flapper the same time you change the fill valve. The water level should be about 1/2 inch to 1 inch below the tube otherwise sometimes the water level will overflow the tube.
Re: Got a toilet question [Re: mclasser] #5420808 05/04/20 01:23 PM
R
Reddy45 Offline
R
Fluidmaster sells a "contractor pack" of 3 flappers by itself for a reason. These are wear items that should be replaced occasionally. You should also take a small cloth and clean up the flapper mating surface since mineral deposits can grow along that seal.
