Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
Eezox vs Prolix?
by Gebo - 06/03/20 11:49 AM
rorty, Ghosty, zmann96, yetti96, weekendwally
71602 Registered Users
88 registered members (bbhero, 340_Magnum, BigGeo, BigCahuna, alchargo, 6 invisible), 1,654 guests, and 36 spiders.
Topics306,112
Posts5,287,757
Members71,602
Valve Cleaning Tip needed #5420549 05/04/20 07:50 AM
W
WylieCoyote Offline OP
W
Hey guys, as soon as all the needed materials arrive, I'm going to clean the carbon off the intake valves of my 2017 Focus ST. One issue came to mind as I walked myself through the process.
Do you guys have any ideas on a method / device to vacuum out the carbon sludge after I've soaked it in chemicals and brushed it loose? Looking for an alternative method that will actually work, without the inevitable explosion that will likely occur if I use the Shop Vac.
Any suggestions would be great. Thanks!
2015 Canyon 3.6
2018 Mustang Ecoboost Convertible
2017 Focus ST
Re: Valve Cleaning Tip needed [Re: WylieCoyote] #5420557 05/04/20 08:02 AM
B
BigCahuna Online Content
Online Content
B
I would load up the gas with some form of cleaner, and just take the car on a long drive and run it hard, and let the cleaner do it's magic. Don't expect a miracle tho. The only way to really clean up internal parts is to disassemble the motor and clean it by hand.,,
Re: Valve Cleaning Tip needed [Re: BigCahuna] #5420564 05/04/20 08:20 AM
Delta Offline
Doesn't work with direct injection motors.
'17 VW GTI 2.0T - 6MT - 21K - Motul X-Cess 5w40
'15 Camry SE - 2.5 - 26K - Edge 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 141K - RGT 5w30
Re: Valve Cleaning Tip needed [Re: WylieCoyote] #5420565 05/04/20 08:24 AM
W
W
I'm removing the intake manifold and cleaning by hand, with brushes and CRC Intake Valve Cleaner. I'm pretty sure if I suck that stuff into my shop vac, there will be an explosion. Looking around at vacuum-operated oil extractors, but not sure if that will work for this job.
2015 Canyon 3.6
2017 Focus ST
Re: Valve Cleaning Tip needed [Re: WylieCoyote] #5420571 05/04/20 08:34 AM
I
irad Offline
I
Run the engine and mist distilled water through the air intake. Have someone rev the engine to prevent stall. I mist the intake until I see steam coming out of the exhaust. I use about a quart of water.
Re: Valve Cleaning Tip needed [Re: WylieCoyote] #5420574 05/04/20 08:34 AM
Z
zrxkawboy Online Content
Online Content
Z
There are simple venturi-operated vacs, with a long wand like a blow gun, that you can connect to compressed air.
Here’s an example:
https://www.tooldiscounter.com/product/sunex-dual-function-power-vacuum-snxsx1000
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Valve Cleaning Tip needed [Re: Delta] #5420575 05/04/20 08:35 AM
B
Online Content
B
Disassembling the motor and cleaning it by hand won't work?.,,,
Re: Valve Cleaning Tip needed [Re: BigCahuna] #5420601 05/04/20 09:09 AM
Delta Offline
Was talking about the filling it up with an injection cleaner and going out for the old Italian tune-up.
Re: Valve Cleaning Tip needed [Re: WylieCoyote] #5420639 05/04/20 10:04 AM
B
BMWTurboDzl Offline
B
Place a rag over the hole and give intermittent blasts with compressed air. The rag will catch the debris. Cover the other valve as well so debris doesn't move from the one you're blasting into another.
The companies that shill these cleaners really leave people hanging with regards to how to perform the job.
Of course the "correct" method for cleaning carbon off intake valves is to use crushed walnuts shells w/air and shop vac along with an adapter specific to your engine.
435i
Re: Valve Cleaning Tip needed [Re: WylieCoyote] #5420648 05/04/20 10:17 AM
T
Trav Offline
T
I would blast them clean with walnut shells using a hand blaster with a hopper. You need to hook up your shop vac to suck the shells and carbon as you are blasting.
Do one cylinder at a time with closed valves. Start with these (these are just examples, you can find them anywhere) and find a rubber cone, pcv T fitting or plug you can adapt to the vac.
https://www.amazon.com/dp/B07H4S9CJ...Y2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
https://www.amazon.com/dp/B01M0CRUU...aWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
Re: Valve Cleaning Tip needed [Re: Trav] #5420680 05/04/20 10:47 AM
The Critic Offline
+1
HF Walnut Blaster and a custom-made adapter. Take a look at these:
https://www.ebay.com/itm/Ford-Focus...082860723589269bb17247afbb4320b9117f8f71
https://www.harborfreight.com/110-lb-pressurized-abrasive-blaster-69724.html
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Valve Cleaning Tip needed [Re: The Critic] #5420732 05/04/20 12:07 PM
T
Trav Offline
T
Thanks for that link to the adapter! The blaster is way too big for this job.
Re: Valve Cleaning Tip needed [Re: WylieCoyote] #5420742 05/04/20 12:18 PM
W
W
I'm gonna go at this with chemicals, brushes & suction first. If I can't get good results, I'll invest in a blasting system. Thanks for all the helpful links & info!
2015 Canyon 3.6
2017 Focus ST
Re: Valve Cleaning Tip needed [Re: WylieCoyote] #5420758 05/04/20 12:33 PM
M
MCompact Online Content
Online Content
M
Walnut shell blasting will be much more effective and simpler in the long run.
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i M Sport
Son's
2009 328i
Buy what makes you smile...
Re: Valve Cleaning Tip needed [Re: WylieCoyote] #5420799 05/04/20 01:16 PM
CT8 Offline
Is there a problem ? Or prophylactic ?
2015 F150 2.7
2018 F350 6.2
