Forums Migration
Please read this thread
BEST Oil Filter for 2020
by DCMotorsports - 07/07/20 12:39 PM
1997 Lancruiser/Colorado/
4Runner wishbone bolt
by Kamele0N - 07/07/20 12:33 PM
why change oil on low mileage car consuming oil
by NewC-05 - 07/07/20 11:50 AM
Which oil to use?
by HydroxZ - 07/07/20 11:02 AM
What oil for supercharged Lotus Exige?
by mkiv808 - 07/07/20 10:59 AM
Carb Metering Diaphrams
by Fordiesel69 - 07/07/20 10:30 AM
ABS Brake Bleeder/Pulsate Software?
by shibby6600 - 07/07/20 10:30 AM
NAPA Gold vs. WIX
by DCMotorsports - 07/07/20 10:11 AM
A/C symptoms-what to do?
by sipman - 07/07/20 09:59 AM
M1 and Liqui Moly - can I mix?
by ssoH - 07/07/20 08:47 AM
HF JACK-STAND RECALL EXPANDED
by demarpaint - 07/07/20 08:15 AM
Five Euro Car Myths?
by BMWTurboDzl - 07/07/20 07:46 AM
Trust Funds
by stockrex - 07/07/20 07:28 AM
3 on the tree
by Chris142 - 07/07/20 07:21 AM
ROCKAUTO selling old expired stock.
by nicholas - 07/07/20 07:21 AM
Amsoil SS 5w30
by mpgo4th - 07/07/20 06:57 AM
Water/Coolant Contamination?
by nastyc5 - 07/07/20 06:53 AM
07 Tahoe trans fluid change.
by Anthony - 07/07/20 06:06 AM
Ravenol 15W40 Marine
by Realfine69 - 07/07/20 05:10 AM
2020 VW 0W20??
by Realfine69 - 07/07/20 05:06 AM
HydroxZ, JDMorgan, sycboi, Chuck_Ellison, BakonBittz
71871 Registered Users
112 registered members (4WD, 2010Civic, 77GrandPrix, 1978elcamino, 2015_PSD, 2002 Maxima SE, 11 invisible), 1,993 guests, and 21 spiders.
Topics307,552
Posts5,313,007
Members71,871
Go with Denso Iridium TT trend or Long Life OE spark plugs? #5420422 05/04/20 01:16 AM
W
wing0 Offline OP
W
The manual calls for Denso Iridium Long Life plugs to be changed at 160k km.
Cars at 320k so second swap and I noticed Denso has new TT plugs with smaller 0.4mm center electrode as opposed to 0.7mm in long life.
Previously 0.4mm center electrode is for the "performance" plugs and generally doesn't last as long.
I saw photo from here which is the TT plug after 150k miles or 240k km.
https://www.rav4world.com/threads/a...5-000-miles-pic.82732/page-2#post-926475
I'm debating now if I should just leave the long life in there(first change at 160k didn't show significant wear on the original plugs) or maybe go with the new TT plugs?
Is there any good reason to get long life plugs again over TT?
TT is $4 cheaper than Long Life per plug for some reason even though it's newer. Less iridium = less cost?
Re: Go with Denso Iridium TT trend or Long Life OE spark plugs? [Re: wing0] #5420447 05/04/20 02:27 AM
U
UG_Passat Offline
U
I thought the BITOG trend is NGK Ruthenium plugs?
.4 vs .7mm isn't really much material, but at .4mm the laser welding has to be more precise and controlled due to less material to work eith.
The Iridium power doesn't last as long because the ground electrode is standard U-groove electrode, not a platinum tipped electrode.
Iridium TT doesn't have the same gap. It's 0.040", vs the Iridium long life having 0.044" gap, so you would have to slightly open up the gap on the TT.
2016 VW Tiguan
Re: Go with Denso Iridium TT trend or Long Life OE spark plugs? [Re: wing0] #5420451 05/04/20 02:59 AM
U
UG_Passat Offline
U
According to the Denso spark plug manual, https://www.denso.com/global/en/pro...ts-and-accessories/plug/pdf/t-manual.pdf
the longlife has a 0.55mm center tip, with a 0.7mm platinum ground tip, since the longlife plugs start with an "F"
2016 VW Tiguan
Re: Go with Denso Iridium TT trend or Long Life OE spark plugs? [Re: wing0] #5420453 05/04/20 03:06 AM
A
adamsoil Offline
A
Iridium is better for fuel economy
Re: Go with Denso Iridium TT trend or Long Life OE spark plugs? [Re: wing0] #5420494 05/04/20 06:08 AM
B
bbhero Offline
B
You don't need to open up the gap.... 0.044 vs 0.040...
In fact that could easily jack up the plug to begin with...
I have the Denso iridium TT plugs in my car instead of the long life Denso because the long life plugs are just too high priced... The Denso iridium TT plugs are also good for 100,000 miles per what they say... So far so good in my car at 65k miles...
Nissan Altima 3.5 Coupe
Royal Purple 10w30+ Ceratec+ Carquest red 85358
"Treat your family like your friends and treat your friends like your family."
Re: Go with Denso Iridium TT trend or Long Life OE spark plugs? [Re: wing0] #5420767 05/04/20 12:41 PM
Dave9 Offline
If you have good results with what you are presently using, there is no good reason to change.
I'd swap in the same plugs, not wait, because the older it gets, the more chances of seized plug or fouling. I mean once you have them out to check them, it hardly makes sense to put 160K mi plugs back in unless you have no other choice.
Re: Go with Denso Iridium TT trend or Long Life OE spark plugs? [Re: wing0] #5420854 05/04/20 02:34 PM
B
BHopkins Offline
B
How difficult is it to change spark plugs on the car? If it is relatively easy, then give the TT plugs a try. If you don't like the way the car runs with the TT plugs, then change back to a set of Long Life.
but if it's a bugger to change plugs on your car, then stay with the Long LIfe. You have proven history that the Long LIfe have performed to your expectations.
That said, I've always been one to stay with the original plugs that were spec'd for the car. With the exception of a VW Dasher that ran better with a set of hotter plugs, but same brand as original, I've always found my cars to perform better by replacing plugs with the same brand and type that the car was spec'd for.
In God we trust. All others bring data.
2013 Subaru Outback 2.5i - M1 HM 0W-20 & NAPA Gold filter
2014 Mercedes E350 M276 - M1 European 0W-40 & Purflux filter
Re: Go with Denso Iridium TT trend or Long Life OE spark plugs? [Re: wing0] #5422261 05/06/20 05:21 AM
A
Amkeer Offline
A
Use the Iridium plugs and change around 80,000-100,000 miles.
2014 Toyota Tacoma D Cab 4.0 M1 5-30 107000
2008 Toyota Tundra D Cab 5.7 M1 5-20 100000 miles
2003 Toyota Tacoma Ex Cab 2.7 M1 5-30 220000 miles
2020 Toyota Camry SE 2.5 600 miles
