AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
Eezox vs Prolix?
by Gebo - 06/03/20 11:49 AM
Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
Ghosty, zmann96, yetti96, weekendwally, Bugsbrewery
71601 Registered Users
106 registered members (53' Stude, 830Lee, ammolab, 4WD, 2015_PSD, 77GrandPrix, 8 invisible), 1,998 guests, and 46 spiders.
Topics306,104
Posts5,287,569
Members71,601
Go with Denso Iridium TT trend or Long Life OE spark plugs? #5420422 05/04/20 01:16 AM
W
wing0 Offline OP
W
The manual calls for Denso Iridium Long Life plugs to be changed at 160k km.
Cars at 320k so second swap and I noticed Denso has new TT plugs with smaller 0.4mm center electrode as opposed to 0.7mm in long life.
Previously 0.4mm center electrode is for the "performance" plugs and generally doesn't last as long.
I saw photo from here which is the TT plug after 150k miles or 240k km.
https://www.rav4world.com/threads/a...5-000-miles-pic.82732/page-2#post-926475
I'm debating now if I should just leave the long life in there(first change at 160k didn't show significant wear on the original plugs) or maybe go with the new TT plugs?
Is there any good reason to get long life plugs again over TT?
TT is $4 cheaper than Long Life per plug for some reason even though it's newer. Less iridium = less cost?
Re: Go with Denso Iridium TT trend or Long Life OE spark plugs? [Re: wing0] #5420447 05/04/20 02:27 AM
U
UG_Passat Offline
U
I thought the BITOG trend is NGK Ruthenium plugs?
.4 vs .7mm isn't really much material, but at .4mm the laser welding has to be more precise and controlled due to less material to work eith.
The Iridium power doesn't last as long because the ground electrode is standard U-groove electrode, not a platinum tipped electrode.
Iridium TT doesn't have the same gap. It's 0.040", vs the Iridium long life having 0.044" gap, so you would have to slightly open up the gap on the TT.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Go with Denso Iridium TT trend or Long Life OE spark plugs? [Re: wing0] #5420451 05/04/20 02:59 AM
U
UG_Passat Offline
U
According to the Denso spark plug manual, https://www.denso.com/global/en/pro...ts-and-accessories/plug/pdf/t-manual.pdf
the longlife has a 0.55mm center tip, with a 0.7mm platinum ground tip, since the longlife plugs start with an "F"
Re: Go with Denso Iridium TT trend or Long Life OE spark plugs? [Re: wing0] #5420453 05/04/20 03:06 AM
A
adamsoil Offline
A
Iridium is better for fuel economy
Re: Go with Denso Iridium TT trend or Long Life OE spark plugs? [Re: wing0] #5420494 05/04/20 06:08 AM
B
bbhero Online Content
Online Content
B
You don't need to open up the gap.... 0.044 vs 0.040...
In fact that could easily jack up the plug to begin with...
I have the Denso iridium TT plugs in my car instead of the long life Denso because the long life plugs are just too high priced... The Denso iridium TT plugs are also good for 100,000 miles per what they say... So far so good in my car at 65k miles...
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
Re: Go with Denso Iridium TT trend or Long Life OE spark plugs? [Re: wing0] #5420767 05/04/20 12:41 PM
Dave9 Offline
If you have good results with what you are presently using, there is no good reason to change.
I'd swap in the same plugs, not wait, because the older it gets, the more chances of seized plug or fouling. I mean once you have them out to check them, it hardly makes sense to put 160K mi plugs back in unless you have no other choice.
Re: Go with Denso Iridium TT trend or Long Life OE spark plugs? [Re: wing0] #5420854 05/04/20 02:34 PM
B
BHopkins Offline
B
How difficult is it to change spark plugs on the car? If it is relatively easy, then give the TT plugs a try. If you don't like the way the car runs with the TT plugs, then change back to a set of Long Life.
but if it's a bugger to change plugs on your car, then stay with the Long LIfe. You have proven history that the Long LIfe have performed to your expectations.
That said, I've always been one to stay with the original plugs that were spec'd for the car. With the exception of a VW Dasher that ran better with a set of hotter plugs, but same brand as original, I've always found my cars to perform better by replacing plugs with the same brand and type that the car was spec'd for.
In God we trust. All others bring data.
2013 Subaru Outback 2.5i - M1 HM 0W-20 & NAPA Gold filter
2014 Mercedes E350 M276 - M1 European 0W-40 & Purflux filter
Re: Go with Denso Iridium TT trend or Long Life OE spark plugs? [Re: wing0] #5422261 05/06/20 05:21 AM
A
Amkeer Offline
A
Use the Iridium plugs and change around 80,000-100,000 miles.
2014 Toyota Tacoma D Cab 4.0 M1 5-30 107000
2008 Toyota Tundra D Cab 5.7 M1 5-20 100000 miles
2003 Toyota Tacoma Ex Cab 2.7 M1 5-30 220000 miles
2020 Toyota Camry SE 2.5 600 miles
