2017 RAM 2500 6.4 Hemi AMSoil and PUP
by Gondul - 05/28/20 07:50 PM
Nail in tire, what would you do?
by Brybo86 - 05/28/20 07:44 PM
Any decent lap tops for $200.00 or less?
by BAJA_05 - 05/28/20 06:49 PM
New PW with Honda 190 engine - Ethanol treatment?
by DirtyApe - 05/28/20 06:38 PM
What size tube should a 110/50-6.5 Tire use?
by taztheman - 05/28/20 06:14 PM
C&P Allison Transmission Filter - 27k miles, 3 years
by shibby6600 - 05/28/20 05:51 PM
XG9100 - 7k miles - 9 months - filter magnet
by shibby6600 - 05/28/20 05:47 PM
2017 Audi A4 PCV Valve replacement
by dbias - 05/28/20 05:23 PM
Audi E-Tron Technik
by OVERKILL - 05/28/20 05:12 PM
Deer 1....My Avalon 0
by ZZman - 05/28/20 03:21 PM
Auto Dealers Supplies?
by cknight49090 - 05/28/20 03:09 PM
interesting video reg vs premium
by raaizin - 05/28/20 02:55 PM
Discount Tire Direct FLASH SALE
by Mr Nice - 05/28/20 02:42 PM
2021 Acura TLX Sports
by buster - 05/28/20 01:36 PM
Honda GC vs GS engines?
by Avery4 - 05/28/20 01:10 PM
Advanced auto parts
by Fitter30 - 05/28/20 12:52 PM
Is there a best time to switch to synthetic oil?
by Jgelack - 05/28/20 12:37 PM
Alignment good then bad
by Barkleymut - 05/28/20 11:56 AM
What's in the Box?
by BeerCan - 05/28/20 11:31 AM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
108 registered members (2002 Maxima SE, amblerman, 55hambone, 2010Civic, 2004tdigls, 928, 12 invisible), 2,233 guests, and 48 spiders.
Topics305,991
Posts5,284,290
Members71,558
Which 75/90 gear oil for AWD ATS? #5420278 05/03/20 08:42 PM
Dd3 Offline OP
Hi guys. I have a 2014 ATS AWD. It’s time to change the front and rear gear oil. I don’t THINK I have LS due to it being AWD. Can I use off the shelf stuff like M1 or Valvoline 75/90 that contains the friction modifier or will that be a bad thing if I, in fact, do NOT have LS? I didn’t know whether I could use Mobil 1 or Valvoline or if I HAD to get the Delco stuff from the dealer.
Thanks
2014 Cadillac ATS 2.0T AWD
Re: Which 75/90 gear oil for AWD ATS? [Re: Dd3] #5420287 05/03/20 08:51 PM
R
ripcord Offline
R
Your owners manual should have recommended fluids listed. If you don't have the manual, check on the tag on the driver's door column. It's the one with tire pressures and should have other information about the car. It should have a bunch of codes including ones for the axle type. If you can find that, you can google for it to see if you have limited slip.
Re: Which 75/90 gear oil for AWD ATS? [Re: ripcord] #5420294 05/03/20 08:56 PM
Dd3 Offline OP
I had this saved to my phone already to have the vin handy, lol. Is this the one?
Re: Which 75/90 gear oil for AWD ATS? [Re: Dd3] #5420296 05/03/20 08:59 PM
Snagglefoot Online Content
Online Content
Here is your owners manual.
https://my.cadillac.com/content/dam...adillac/ats/2014_cadillac_ats_owners.pdf
You might also consider doing the transfer case.
If you want the job done right......do it yourself.
Re: Which 75/90 gear oil for AWD ATS? [Re: Snagglefoot] #5420303 05/03/20 09:09 PM
Dd3 Offline OP
Thank you, sir. Yes, good idea while it’s up in the air. I’m at 65k or so so I’m just in between the “normal” and “severe” conditions schedules.
Re: Which 75/90 gear oil for AWD ATS? [Re: Dd3] #5420305 05/03/20 09:10 PM
Online Content
I believe Valvoline and Castrol make suitable products if you don't want AC Delco.
Re: Which 75/90 gear oil for AWD ATS? [Re: Snagglefoot] #5420310 05/03/20 09:16 PM
Dd3 Offline OP
Thanks guys. I’m thinking about having this done at a trans shop only bc it’s so tight to get under my car even on ramps. I’d imagine those guys have the correct fluids being that they do this all day long, but do you guys think I should grab all the fluids from the dealer and take it to them?
Re: Which 75/90 gear oil for AWD ATS? [Re: Snagglefoot] #5420311 05/03/20 09:17 PM
Dd3 Offline OP
I did actually read that the synthetic Valvoline Gear oil met an even tighter spec than did the M1.
Re: Which 75/90 gear oil for AWD ATS? [Re: Dd3] #5420315 05/03/20 09:20 PM
Online Content
It a nice car. I would take it to a GM Dealer. Its not like you have to do this every 6 months.
smile
Re: Which 75/90 gear oil for AWD ATS? [Re: Snagglefoot] #5420332 05/03/20 09:54 PM
U
UG_Passat Offline
U
75w90
Funny neither part number is in the AC Delco website:
https://www.acdelco.com/parts/oils-fluids
But in Summit Racing, it is a conventional GL-5 lube
https://www.summitracing.com/int/parts/ado-10-4061/overview
75w90 GL-5? Can always go with Amsoils SVG 75w90
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Which 75/90 gear oil for AWD ATS? [Re: Dd3] #5420337 05/03/20 10:01 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Source?
Re: Which 75/90 gear oil for AWD ATS? [Re: Dd3] #5420345 05/03/20 10:11 PM
J
JMJNet Online Content
Online Content
J
Just get brand name gear oil should be sufficient for your ATS.
For sensors and electrical parts, you need to buy ACDelco OE parts but not necessary for oil.
  • 2017 Toyota Sienna
Re: Which 75/90 gear oil for AWD ATS? [Re: Snagglefoot] #5420373 05/03/20 10:56 PM
Dd3 Offline OP
I appreciate that. Thanks. Sounds like a plan
Re: Which 75/90 gear oil for AWD ATS? [Re: JHZR2] #5420376 05/03/20 11:01 PM
Dd3 Offline OP
As far as the source of where I’d read about the Valvoline gear oil meeting a certain spec that the others didn’t cant find it now that I’m looking for it, but it was a post somewhere on this forum about it, actually.
Re: Which 75/90 gear oil for AWD ATS? [Re: Dd3] #5420385 05/03/20 11:30 PM
U
UG_Passat Offline
U
MIL-PRF-2105E?
