Hello all - Spent a few hours yesterday helping my friend, with the intention of changing out the front struts and rear shocks on his 2008 Hyundai Sonata. The car is in good shape for its age, and the mileage, at 180K km, is on the lowish side for the age. The shocks and struts were original, and the struts were certainly due. My friend had bought KYB Strut-Plus assemblies (the equivalent of Monroe's Quick-Struts), and are they ever a time saver. Perfect fit as expected, and per the test drive afterwards, my friend was pleased by the improved ride and absence of evil noises.
However, the rear shocks, which should have been a piece of cake, presented a problem. The shocks are attached to a strut mount which is bolted to the top of the fender liner. No problem there. The bottom of the shock slips over a threaded stud, and is held in place with a large washer and nut, allowing the shock to pivot slightly on the stud. So to remove the shock, one should be able to unbolt the top mount, remove the nut and washer on the bottom, and then just push the bottom of the shock off the stud. No problem at all removing the top mount, or removing the nut and washer from the bottom.
However, the lower part of the shock is rusted onto the stud. I checked out a few forums, including a Hyundai-specific one, and some YouTube videos, and it looks like this is a common problem. There's a steel bushing, mounted in a rubber isolator, on the bottom of the shock. The rubber isolator absorbs much of the force as one pounds on the shock. Even with the top of the shock free, there's not enough room to bend or twist the shock much.
Here are a few videos - a picture and 10^3 words and all that ... these fellows were able to pry the strut off, with the isolator bushing and steel bushing staying in place. With that access, they torched the rubber off and then used a grinding wheel to cut the bushing enough to free it:
https://www.youtube.com/watch?v=uMlsGqqpJ0Y
https://www.youtube.com/watch?v=wrlr_tT01lM
This seems to be what most people in the rust belt had to resort to. Penetrating oil was not the answer. (We did apply a lot of penetrating oil yesterday, and based on past experience it might work in over several days, but we had no results yesterday.)
Anyway, a lot of you are way more experienced than I am - any clever alternatives to the brute-force method? Someone on a forum mentioned being successful using a puller. I could see it helping if the rust wasn't too bad.
And of course, I have done for decades now, I asked rhetorically why they couldn't have applied a dab of anti-seize compound at the factory.
Thanks in advance!
Thanks in advance!
