Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
Shopping for New Generator
by doolah02 - 06/01/20 12:02 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
24 registered members (E365, blufeb95, bachman, brslds, bourne, Doktor_Bert, 1 invisible), 1,294 guests, and 78 spiders.
Topics306,045
Posts5,286,348
Members71,593
Ethanol And Fuels Questions #5420070 05/03/20 03:11 PM
Propflux01 Offline OP
Here in the mid south, we seem to have two types of gas stations. Those who sell the 87/89/91, and those that sell 87/89/93.
Am I wrong is assuming that:
87 is 85 w/ethanol, the 89 is pure (no ethanol), and the 91 is 89 w/ethanol
and
87 is 85 w/ethanol, the 89 is max allowable ethanol, and the 93 is pure (no ethanol)?
2014 Hyundai Elantra
2014 Hyundai Elantra GT
Re: Ethanol And Fuels Questions [Re: Propflux01] #5420077 05/03/20 03:26 PM
A
ammolab Offline
A
Yes you are wrong. Different octanes can be sourced with OR without ethanol. Look at the pumps carefully. If a gasoline contains Ethanol they will be labeled, “contains x% Ethanol, and any Ethanol free gas these days will have a premium price over same octane rated gas containing ethanol.
1998 Jeep Cherokee
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: Ethanol And Fuels Questions [Re: Propflux01] #5420079 05/03/20 03:31 PM
samven Offline
I dont believe so. 87 is mostly 84-85 w/10% ethanol and 93 is what the marine industry calls Rec 90 with 10% ethanol and 89 is an at the pump blend of 87 and 93. Most stations dont want 3 tanks for gas so its easier to just get premium and reg and blend them. I dont know where the 91 comes from unless its mostly for high altitude stations that also sell 85 which have largely started to disappear since variable timing fuel injected engines.
Re: Ethanol And Fuels Questions [Re: Propflux01] #5420099 05/03/20 04:23 PM
Biggest thing I have noticed is that the stations that sell the 91 have a strong ethanol smell. the 93, not so much at all.
Re: Ethanol And Fuels Questions [Re: Propflux01] #5420111 05/03/20 04:51 PM
T
TmanP Offline
T
This really, really depends on the state. I'd say, generally, you are not correct with that assumption.
Some states require gas WITH ethanol to be labeled, others only label gas withOUT ethanol.
If I remember correctly, Arkansas is a state that doesn't require labeling gas with ethanol. I'd assume that any gas you pump has it in unless you can confirm otherwise. Oh, and 93 would probably be the least likely to be pure from ethanol, with 91 being more likely (pure 91 + 10% ethanol = 93 octane)
For example, in MN we have:
-stations that are: 87/89/91, all with ethanol (HyVee, some Shell, Holiday, and Speedway come to mind)
-stations that are E-10 87/ E-10 89/ ethanol free 91 (with the 91 being labeled as ethanol-free) (usually Kwik Trip and/or stations near lake areas)
-stations with 87/89/92 or 93, all with ethanol (BP and Fleet Farm come to mind)
(as well as stations like Casey's or independents that may only sell 87)
From the stations I've gotten gas at in Arkansas (Exxon in Hope, Sunoco in Alma and a Murphy Express in Little Rock come to mind), I didn't remember seeing any sticker indicating the presence of ethanol at all. I assumed all of it was 10%; this would be like Minnesota. Stations in Iowa and Nebraska, on the other hand, usually label if the gas does or does not contain ethanol. Oftentimes there you'll see the following: non-ethanol 87, E10 87 (cheapest), and premium with or without ethanol (this is at many Kum and Gos, most HyVee's I've seen, some Casey's, some Shells, etc.) Other stations (e.g. Pilot/Love's, some Phillips 66, many BPs) have E-10 87/ 8-10 89/ usually E-0 91). Notable exceptions are certain stations (Sioux City Murphy USA comes to mind) where the midgrade is actually 91 E-10 and premium is 91 E-10.
The moral of the story: it really depends. Assume it probably has ethanol in it if it's not labeled. Hope that helps!
2012 Toyota Camry 2.5 60,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 50,000 mi
2010 Toyota Sienna 3.5 V6 200,000 mi
Re: Ethanol And Fuels Questions [Re: Propflux01] #5420126 05/03/20 05:19 PM
T
The_Nuke Offline
T
and
Here in Texas, DFW especially, the 87 and 93 have 10% ethanol like is advertised on the pumps.
I haven’t tested any 89 or 91 yet, mostly 93 and some 87, and they definitely have the 10% ethanol.
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 3.07 (215mm)
Re: Ethanol And Fuels Questions [Re: Propflux01] #5420141 05/03/20 05:41 PM
J
JohnG Offline
J
Let's simplify it even more. Maybe you (Midstream) only want to have TWO tanks.
Let's also assume that 10% ethanol will add 3 octane numbers.
Now you can have 84 and 90 (or 91) octane tanks. Then 84 + eth = 87, 84+ 20%91 + 10% eth = 89, 90 +10 eth = 93. Done.
So maybe everybody is wrong?
Re: Ethanol And Fuels Questions [Re: Propflux01] #5420145 05/03/20 05:50 PM
J
JohnG Offline
J
Oh, I forgot. You can also "downgrade" 93 (NON-ETHANOL) with 84 so the blend for 91 might be a little different as might the 93 WITH 10% ethanol.
This is seen at the pumps that carry 93 octane non-ethanol fuel for recreational (boats) here in Florida. Using only two grades + Ethanol and the possibilities are nearly endless.
Re: Ethanol And Fuels Questions [Re: samven] #5420193 05/03/20 06:52 PM
Y
y_p_w Offline
Y
It would be a precise blend to achieve the final result with a specified concentration of oxygenate (typically ethanol). The most common base fuel on the commodity market is RBOB (reformulated blendstock for oxygenate blending). Whether or 89 is blended from on-site tanks or delivered as such depends on the site. I have never seen a Costco with midgrade. I guess they opted not to use a blending pump.
There was a time (a long time ago) when something like 87 octane at the pump would actually be 87 octane without ethanol and then have ethanol (or MTBE) blended which would boost the octane rating. Apparently this was called "octane giveaway".
Re: Ethanol And Fuels Questions [Re: Propflux01] #5420484 05/04/20 05:19 AM
Skippy722 Offline
The octane ratings on the pumps are minimums, it could very well be 87 octane with 10% ethanol which means there could also be 0%, and I believe that is the case, as the signs here all say “may contain up to 10% ethanol.”
I’ll have to get a graduated cylinder and actually test though. My 4am “let’s use a pop bottle” method didn’t work as good as I thought it would.
2019 Ram 1500 Classic
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Ethanol And Fuels Questions [Re: Skippy722] #5420637 05/04/20 10:00 AM
Y
y_p_w Offline
Y
Unlikely though. There is a much higher demand for higher octane fuels these days. Even a lot of econoboxes specify "premium". It's hard enough meeting the demand for this with oxygenate to boost the octane rating. The ethanol may be optional, but the octane rating isn't. Ethanol is probably the most cost effective octane rating booster on the market - except maybe for lead which a nonstarter.
It may vary depending on the price of base gas, but fuel grade denatured ethanol is often cheaper than gasoline. It isn't now, but the current prices aren't likely to be long term. Even if it's slightly more expensive, some sort of oxygenate would likely be used simply because it's needed to boost the octane rating. MTBE would be ideal if it didn't make water taste foul. MTBE is superior to ethanol in many ways. It doesn't attract as much water and can be transported by pipeline. It does phase separate more easily because it doesn't have that affinity for water.
Re: Ethanol And Fuels Questions [Re: Propflux01] #5420657 05/04/20 10:24 AM
ChrisD46 Offline
My southern state supplies all with 10% ethanol or 87 octane without ethanol .
'17 Hyundai Sonata 2.4L GDI 5W30 PUP / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: Ethanol And Fuels Questions [Re: Propflux01] #5421909 05/05/20 06:04 PM
J
JohnG Offline
J
Quote
In my MTBE days, I hated that stuff. It would eat and swell VITON seals!
My friend used to transport it by tanker truck out in Colorado. Every delivery would end up short, missing several gallons of product. The investigation revealed that the stuff was seeping right through the sides of the aluminum trailer and evaporating!
He was driving along one day with a tailwind and passed out at the wheel of the tanker! No, I don't want to see that stuff ever again!
Re: Ethanol And Fuels Questions [Re: Propflux01] #5428683 05/13/20 11:08 PM
Y
y_p_w Offline
Y
Just to add to this discussion, it is possible to up the average octane rating of fuel to be increased via a chemical process. There are limits though, which is why there will almost always be some sort of oxygenate added to some/most of the fuel produced.
https://en.wikipedia.org/wiki/Catalytic_reforming
Re: Ethanol And Fuels Questions [Re: Propflux01] #5432031 05/18/20 05:44 AM
RTexasF Offline
I have not seen gasoline without 10% ethanol since 2008 or so. I'd say your assumptions are totally wrong.
