GTX Ultraclean now in 0W-20
by wemay - 06/05/20 08:38 AM
Glassware for bevarages
by Duffyjr - 06/05/20 08:24 AM
New Permatex Orange Threadlocker
by Snagglefoot - 06/05/20 07:39 AM
Peak Blue 64oz Diesel Cetane Booster $14.49
by Bighorn2500 - 06/05/20 07:22 AM
OTC Stinger 3 Ton Jack Stands, no good
by michaelluscher - 06/05/20 06:44 AM
$900 + a lot of shipping/fees electric car
by madRiver - 06/05/20 06:44 AM
PUP SP
by Koncrete_Cam - 06/05/20 05:52 AM
Hailstorm Yesterday
by Delta - 06/05/20 04:47 AM
Date code on Mighty Engine Guard II? Air Filter
by blufeb95 - 06/05/20 01:01 AM
My poor Jetta can't catch a break.
by FordBroncoVWJeta - 06/05/20 12:22 AM
Bought a truck finally, warning no Ford content
by bdcardinal - 06/04/20 11:31 PM
Got a septoplasty today....
by daves66nova - 06/04/20 10:44 PM
2020 330i xDrive Loaner
by MCompact - 06/04/20 10:02 PM
Appliance repair?
by motor_oil_madman - 06/04/20 09:44 PM
Glad we got a seasonal RV site
by Pat in Speedway - 06/04/20 09:19 PM
Mobil 1 AP Clearance at Wal-Mart
by KeithS_NW_Ohio - 06/04/20 09:07 PM
Recent experience with a Michelin Defender
by FordSVTGuy - 06/04/20 08:46 PM
music quality of speakers in the 70's vs now
by raaizin - 06/04/20 08:15 PM
Jettero, TinyHouseTruck, stubby73, Polkaman, Ramboagain
71610 Registered Users
96 registered members (Ag76, aquariuscsm, amblerman, 14Accent, 440Magnum, 1911CHAMPION, 8 invisible), 1,691 guests, and 73 spiders.
Topics306,238
Posts5,288,792
Members71,610
Gasoline sans alcohol #5419883 05/03/20 10:53 AM
J
Jarpin Offline OP
J
Hello guys,
I've been away from this forum for almost 10 years,
Instead following forums for my individual vehicles.
Lately, since the price of gas came down, I've been taking advantage of NO ethanol gas (90 octane) at Quiktrip gas stations in both my old 1999 Toyota (263k), and my 2001 Subaru (167k). Now granted, it comes at a hefty premium, which means it costs even more than premium gas per gallon.
BUT.....
Do you guys think that my really older engines could avoid costly fuel system problems in the future if I stuck with this grade gas even after fuel prices go back up again?
Re: Gasoline sans alcohol [Re: Jarpin] #5419908 05/03/20 11:26 AM
skyactiv Online Content
Online Content
I think the only issue you could have is if you let the car sit for months at a time if it has E10 in it. You will get slightly better fuel economy with E0 gas vs E10 gas. Enough to offset the increased price? Probably not.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Gasoline sans alcohol [Re: Jarpin] #5419928 05/03/20 11:53 AM
T
TmanP Offline
T
I'd say no in those cars. By that point (1999) cars were designed with ethanol in mind. You'll be spending at least a couple hundred bucks a year extra to run it, maybe more depending on cost and how much you drive.
For example... 20,000 miles a year / 20 mpg = 1,000 gallons of gas; an extra 50 cents a gallon would cost you $500 extra a year - not insignificant by any means, especially for little tangible benefit.
Me, I'd save the money, run the regular (QT is Top Tier and good gas), and just buy the non-ethanol stuff for small engines. That's what I do. If you had classics not designed for ethanol, that would make sense. But for a 20 year old Toyota? Run the cheap stuff and sleep well.
2012 Toyota Camry 2.5 60,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 50,000 mi
2010 Toyota Sienna 3.5 V6 200,000 mi
Re: Gasoline sans alcohol [Re: Jarpin] #5419945 05/03/20 12:14 PM
J
Jarpin Offline OP
J
Ok....thanks guys. That helps. I think I'll just save the cash and run a can of 44K once a year. Maybe I'll just switch to midgrade instead of no ethanol. Paying more than the cost of premium was bothering me in the back of my mind. I guess that's why corn farmer subsidies help the consumer at the pump too.
Re: Gasoline sans alcohol [Re: Jarpin] #5419951 05/03/20 12:23 PM
T
TmanP Offline
T
BITOG wisdom would be to use Techron, Gumout Regane or another product with PEA in it for best cleaning results, but I'm sure that 44k is a good option too (don't know if it has PEA in it).
Also, unless your owners' manuals recommend midgrade gas or your engines ping/knock, running it probably will serve to do nothing but lighten your wallet. YMMV of course, but odds are your car won't know a difference. Plus, regular has the advantage of being the freshest "flavor" of gas; I was at our Kwik Trip last night (different from your QT), and they said that they get a fuel truck every single night. (Regular every time, and other grades as needed.) If you feel you get some benefit from running a more expensive gas then why not, but for the vast majority of cars on the road that spec regular, that is exactly what they need. If they spec premium or midgrade, then that's probably what they need (though even then many people will run regular).
Re: Gasoline sans alcohol [Re: Jarpin] #5420050 05/03/20 02:45 PM
J
Jarpin Offline OP
J
Ok, cool. So I'll save the no ethanol gas for the pressure washer and the lawnmower. Good knowledge base here. Thanks. Probably still a good idea to use the fuel stabilizer in the gas can, right?
Re: Gasoline sans alcohol [Re: Jarpin] #5420198 05/03/20 06:56 PM
caprice_2nv Offline
I just installed my 3rd set of rubber fuel hoses in my 84 Cutlass in 13 years. The last set with fuel injection hose (even though my car is carbureted), supposed to be better hose and it still cracked. It would have been leaking if I'd left it much longer. Last time it did leak before I realized.
I'm on carburetor number 2 which is still working good except a bit of a weak accelerator pump, which is on the way.
It's always parked with e0 and stabilizer and only runs e10 when I'm daily driving it. A tank of gas never lasts longer than a couple weeks.
I can't afford to run premium e0 because of the price difference so I just have to keep fixing the damage caused by ethanol as it happens. I'm running only top tier hoping that reduces issues.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
05 Silverado 1500 4wd - 4.8/4L60E
79 Honda CX500
Re: Gasoline sans alcohol [Re: Jarpin] #5420474 05/04/20 04:33 AM
Skippy722 Offline
I run E10 in my lawn tractor, 2 stroke weed eater, and snow blower. Never “winterized” anything, just added some sta-bil and they’ve always fired up without a fuss. Never any issues with water or the ethanol separating.
2019 Ram 1500 Classic
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Gasoline sans alcohol [Re: Skippy722] #5420496 05/04/20 06:13 AM
caprice_2nv Offline
You should buy a lottery ticket.
79 Honda CX500
Re: Gasoline sans alcohol [Re: caprice_2nv] #5420510 05/04/20 06:36 AM
Skippy722 Offline
My grandfather and my father never winterized anything either, that 15 year old craftsman lawn tractor is STILL going! shrug
Though I did run the weed eater out of fuel and let it sit this last winter... I hope that fires up.
Re: Gasoline sans alcohol [Re: Skippy722] #5420515 05/04/20 06:45 AM
caprice_2nv Offline
My father in law ran e10 in his stuff up until last summer when I showed him the inside of the old carburetor on his nearly new lawnmower. It couldn't be saved, I had to order a new one for it. Last summer he had almost every one of his part time use stuff fail (a couple lawnmowers, a couple snowblowers and his motorcycle all had carb issues). I was able to clean out one lawnmower and the bike shop cleaned out his motorcycle carb.
He's not the only one either, it happens all the time. My ope has had a lot better track record than a lot of people so I'm not going to gamble with ethanol in the gas when it's easy enough to buy e0 for them. It just doesn't make any sense to do otherwise unless you have no problem buying new equipment.
79 Honda CX500
Re: Gasoline sans alcohol [Re: Jarpin] #5424997 05/09/20 07:14 PM
L
LubricatusObsess Offline
L
I worked for Onan Corporation before Cummins bought it. We had all sorts of problems with alcohol gas blends - quick degradation in storage (even with stabilizer), corrosion of small engine fuel system parts, etc. With constant AFR fixed jetting, it creates artificially lean conditions and tends to burn exhaust valves as well.
It's corporate welfare at its finest. If you can find straight gas, use it. Be sure you add stabilizer at the pump whatever you use.
Elastohydrodynamic Lubrication makes the world go 'round!
2017 Ram 2500 - PUP 0W-40, Fram XG
2011 Chev Traverse - PUP 5W-30, Fram XG
2005 Chev Kodiak C5500 - PUP 10W-30, Fram XG
Re: Gasoline sans alcohol [Re: Jarpin] #5424998 05/09/20 07:15 PM
L
L
Re: Gasoline sans alcohol [Re: LubricatusObsess] #5426273 05/11/20 11:05 AM
K
kschachn Offline
K
The only conclusion one can draw from these types of posts is that some manufacturers use clearly inferior construction materials in their fuel systems. None of my old vehicles (even my 26 year-old BMW) have these issues, why don't small engine manufacturers use better materials?
It's not like E10 just appeared on the market in the past few years. There are numerous individuals like myself (and many others in large metropolitan areas) where we cannot purchase E0 at any station. Why don't small engine manufacturers help us out by acknowledging this and utilize appropriate materials in their engines?
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Gasoline sans alcohol [Re: kschachn] #5426374 05/11/20 12:44 PM
Y
y_p_w Offline
Y
I guess that's one of life's little mysteries. As with many things, it probably settles down to how much it would cost. Cars are expensive and different metals, seals, etc are going to be expensive. And there's probably no way that vented tanks are going away.
Still - some seem to do pretty well on E10. Kohler says it's OK and I haven't heard of many problems. But they're pretty expensive.
