Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
95 registered members (3turbodiesels, AbbyMaster, aaronc7, 86cutlass307, 53' Stude, 830Lee, 4 invisible), 2,199 guests, and 37 spiders.
Topics306,053
Posts5,286,541
Members71,593
Sonata 2017 , 77K miles. Burning engine oil. #5419508 05/02/20 10:54 PM
M
MikeHeal Offline OP
M
Hello guys,
Thanks for having me here.
I have a question related to my Hyundai Sonata 2017 (77500 mostly Highway miles).
My vehicle is consuming engine oil (comparatively more on freeways than in city). The oil level dropped from level F to mid in ~800 mile range , gosh.
I was just wondering that will it be a good choice to get it repaired or should I start looking for another vehicle!?
How much will be the repair cost!?
Also, will the dealership do any justice to me as I am the first owner of the vehicle and I use it for personal purposes only.
Thanks a ton. smile
Re: Sonata 2017 , 77K miles. Burning engine oil. [Re: MikeHeal] #5419511 05/02/20 10:58 PM
P
PetitFrereArmada Offline
P
Are you a member of the Sonata forum?
If not, you should post this question there to get more specific information to your Hyundai Sonata.
Also, you could do a search on that forum and will see possible causes of your problem from other members who may have already experienced it and found a solution.
2012 Infiniti QX56. 156,000 miles. Shell Rotella 5w30 truck with Fram XG oil filter.
2008 Nissan Maxima. 265,000 miles. Using 5w30 with stock filter.
Re: Sonata 2017 , 77K miles. Burning engine oil. [Re: MikeHeal] #5419512 05/02/20 10:59 PM
L
Lolvoguy Offline
L
Isn't that still under warranty?
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Sonata 2017 , 77K miles. Burning engine oil. [Re: Lolvoguy] #5419515 05/02/20 11:06 PM
R
Reddy45 Offline
R
Not sure what Hyundai says, but you'd be surprised what some mfrs consider "normal oil consumption". A friend once told me his VW consumed 1qt in 1000 miles and VW told him this was acceptable.
Re: Sonata 2017 , 77K miles. Burning engine oil. [Re: Lolvoguy] #5419525 05/02/20 11:23 PM
M
MikeHeal Offline OP
M
Yes , as per the norms it is still in warranty.
The Hyundai dealership told me that 2-3 quarts within service-to-service is normal.. lolz
I’ll try posting the question to a sonata forum, good idea smile
Re: Sonata 2017 , 77K miles. Burning engine oil. [Re: MikeHeal] #5419545 05/03/20 12:06 AM
P
PowerSurge Offline
P
If you’re positive it’s consuming and not leaking, now is a great time to trade it on a better quality car. Hyundai is hit or miss with their mechanicals. Good luck.
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
Re: Sonata 2017 , 77K miles. Burning engine oil. [Re: MikeHeal] #5419560 05/03/20 12:45 AM
M
Mainia Offline
M
If it was me would run an oil change of Redline "High Performance " oil and NOT their Professional Series, 5w-30 oil, to get some cleaning ester's in there. Or even better and the best choice do an oil change of Valvoline Restore 10w-30.($70gallon plus delivery)that is made specifically for cleaning coked ring lands.
2018 Lowered Hyundai Kona AWD 1.6T
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: Sonata 2017 , 77K miles. Burning engine oil. [Re: MikeHeal] #5419562 05/03/20 12:55 AM
Nick1994 Offline
Don't top it off, see how many miles it takes to get to the add line for an accurate point.
I had a 15' Sonata 2.4L I traded in last December, had 108k miles and always consumed 1 quart per 5k miles which isn't bad.
2015 Hyundai Genesis 5.0L 61k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Rotella Gas Truck 5w30 & Wix
Re: Sonata 2017 , 77K miles. Burning engine oil. [Re: MikeHeal] #5419589 05/03/20 03:23 AM
Char Baby Offline
How about:
*What engine is this; 2.4L, 2.0T, 1.6 eco?
*Check the PCV system...AND
*Did you change grade of oil, such as going from 5W30/10W30 to a 0W20?
*Did you all of a sudden go from conventional oil to synthetic?
*Get as much documentation as possible including from others with the same engine as yours.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Sonata 2017 , 77K miles. Burning engine oil. [Re: Mainia] #5419602 05/03/20 04:36 AM
dave1251 Offline
How much ester is there in Red Line? Not much.
don't use.
Re: Sonata 2017 , 77K miles. Burning engine oil. [Re: MikeHeal] #5419603 05/03/20 04:37 AM
PimTac Offline
Originally Posted by MikeHeal
Hello guys,
Thanks a ton. smile
Dropped to mid what? Halfway to the add mark? We need to know the consumption ratio in quarts per mile ( like one quart in 1000 miles)
Have you checked for leaks?
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Sonata 2017 , 77K miles. Burning engine oil. [Re: MikeHeal] #5419615 05/03/20 05:36 AM
E
earlyre Offline
E
I Used to have a 2000 Sonata w/ the old 2.4l...in the 8 yrs, and 100k mi I had it, it almost ALWAYS burned 1 qt/1k mi. the manual called for 5w20, but, I always ran Valvoline 10w30.(vwb until it hit 75Kmi, then maxlife) .
heck I JUST found out(10 years after selling it) that that car had a Cabin Filter...oops! never changed that in 8 years/100k mi...
Mine:
13 Ford C-MAX hybrid: Bulk Maxlife Full Syn 5w20,& Valvoline Jobber Filter
( I was Lazy and had a Groupon)
Re: Sonata 2017 , 77K miles. Burning engine oil. [Re: MikeHeal] #5419645 05/03/20 06:40 AM
P
philipp10 Offline
P
1600 miles per quart is high. I have a 2008 RAV 4 been drinking oil at a rate of 1200 miles per quart for 5 years now. Unless your Sonata is getting worse, I think you will have to live with it.
On the good side, if your replacing a quart every 1600, after about 7000 miles, you have basically replaced the entire crankcase of oil, so no reason to do oil changes near as often.
Re: Sonata 2017 , 77K miles. Burning engine oil. [Re: dave1251] #5419662 05/03/20 06:58 AM
M
Mainia Offline
M
Oxidation #s are in the 90s last time I looked.
2005 Honda Civic
Re: Sonata 2017 , 77K miles. Burning engine oil. [Re: MikeHeal] #5419682 05/03/20 07:30 AM
R
Robster Offline
R
Short answer. . . . let the oil level come down to about the midway between "full" and "low" marks on the dipstick and see if it stays there before topping it off. Hyundai recently changed the dipsticks on these engines causing overfilling that WILL cause the "excess" oil to be consumed. --Rob
2017 RAM 1500 Big Horn 5.7L:Valvoline AFS 5w-20, Fram TG10060
2019 Hyundai Santa Fe Ultimate AWD 2.4L:Valvoline AFS 5w-20 / OEM filter
2013 Victory Cross Country:Valvoline 4T syn 10w-40, NAPA Gold
