Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
16 registered members (Char Baby, blufeb95, BlakeB, bbhero, bachman, 1 invisible), 1,104 guests, and 45 spiders.
Topics306,047
Posts5,286,360
Members71,593
Micro guard MGL57356 major baseplate defect #5419440 05/02/20 09:08 PM
Samrsnow Offline OP
Customer brought in this filter to change on a Honda Pilot this morning. As I was threading it on, it went on completely crooked, like FUBAR level bad. First tome seeing something like this.
1987 BMW e28 535is - mystery mileage (300,000+) Chevron 20w50 - Wix 51732
Re: Micro guard MGL57356 major baseplate defect [Re: Samrsnow] #5419444 05/02/20 09:10 PM
O
oldhp Offline
O
It got machine threaded wrong when built. I've seen a couple before.
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: Micro guard MGL57356 major baseplate defect [Re: Samrsnow] #5419449 05/02/20 09:18 PM
I
Imp4 Offline
I
What's wrong with it?
Re: Micro guard MGL57356 major baseplate defect [Re: Imp4] #5419475 05/02/20 09:47 PM
Samrsnow Offline OP
Threads are not straight, leading to it going on the filter housing, but sideways and does not come anywhere near sealing.
Re: Micro guard MGL57356 major baseplate defect [Re: Samrsnow] #5419480 05/02/20 09:58 PM
Chris142 Offline
Made by purolater isn't it?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Micro guard MGL57356 major baseplate defect [Re: Samrsnow] #5419482 05/02/20 10:00 PM
blupupher Offline
Looks like the threads do not go all the way to the opening.
[Linked Image]
It just ends up cross threading since the threads on the car side will try to grab onto something.
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/ProGuard
'12 xB: M1 EP 0W-20/CQ Blue
'10 Santa Fe: Synpower 5W-30/D+
'04 F150: Magnatec 10W-30/ST
'02 F150: PP 0W-20/M1
'94 VT1100: Peak 15W-40/Wix
Re: Micro guard MGL57356 major baseplate defect [Re: Samrsnow] #5419810 05/03/20 09:32 AM
Samrsnow Offline OP
I believe MG is made by Wix actually.
Re: Micro guard MGL57356 major baseplate defect [Re: Samrsnow] #5419817 05/03/20 09:36 AM
PimTac Offline
Same company.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Micro guard MGL57356 major baseplate defect [Re: Samrsnow] #5419923 05/03/20 11:44 AM
F
Farnsworth Offline
F
Wix, which has their own factory separate from any other company.
Since there is no evidence what has happened with this filter before it was brought in to use there is no one to blame. It could very well have been a store return and some yahoo was trying to make it fit on something. There is that score on the base like it was tightened down on something it shouldn’t have been. Jumping to conclusions Is so easy.
Re: Micro guard MGL57356 major baseplate defect [Re: Farnsworth] #5420040 05/03/20 02:24 PM
Z
ZeeOSix Offline
Z
The score on the base plate was most likely from the OP from installing the filter and then discovering the problem he's describing.
Re: Micro guard MGL57356 major baseplate defect [Re: ZeeOSix] #5420554 05/04/20 07:59 AM
Samrsnow Offline OP
Yes, thank you. It would thread on normal, but completely sideways which threw me off. The filter was untouched until I took it out the box. Definitely a problem from the manufacturer.
Re: Micro guard MGL57356 major baseplate defect [Re: Samrsnow] #5420596 05/04/20 09:06 AM
F
Farnsworth Offline
F
What made the circular score mark? So the filter looked fine out of the box is a bit of a change to the story. That's fine, Someone mangled the thread and scored the base though. I assume if the thread was made tilted the someone tried to force it on straight? It would have been better to put another filter on.
Re: Micro guard MGL57356 major baseplate defect [Re: Samrsnow] #5420605 05/04/20 09:13 AM
PimTac Offline
It’s a old habit I have. I inspect any filter before it goes on the car, preferably at the place where I buy it. I do the same with most things I purchase.
2017 Mazda CX5
Roki OEM filter.
Re: Micro guard MGL57356 major baseplate defect [Re: Farnsworth] #5420887 05/04/20 03:14 PM
Z
ZeeOSix Offline
Z
I'd bet the mounting spud on the engine.
Re: Micro guard MGL57356 major baseplate defect [Re: ZeeOSix] #5421260 05/04/20 10:40 PM
B
bbhero Online Content
Online Content
B
I agree Zee.... That's what I thought as well.
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
