Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
77 registered members (AndyB, 1978elcamino, ARCOgraphite, akh, 53' Stude, 1foxracing, 7 invisible), 1,887 guests, and 42 spiders.
Topics306,053
Posts5,286,471
Members71,593
Did a Stupid Thing #5419418 05/02/20 08:43 PM
J
jkasch Offline OP
J
I have what was a meticulously maintained Craftsman 23 V-twin Intek lawn tractor. 15 years old didn't use a bit of oil. Today I rolled through some dog $hi* and hosed off the front tire before the engine cooled. I knew I shouldn't do that, but figured the water wasn't hitting the engine block. Apparently it was, because it started leaking oil after I started it.
I'm assuming the is block cracked, but wonder if it could be anything else. If you can think of anything else to check, I'd appreciate it.
Re: Did a Stupid Thing [Re: jkasch] #5419430 05/02/20 08:52 PM
W
walterjay Offline
W
Look carefully for where the oil is coming from. It may not be a cracked block. That would be unusual.
Re: Did a Stupid Thing [Re: jkasch] #5419433 05/02/20 08:54 PM
I
Imp4 Offline
I
Pictures of the leaking location???
Re: Did a Stupid Thing [Re: jkasch] #5419439 05/02/20 09:08 PM
Z
Zaedock Offline
Z
I don't know man. My son has washed our tractor down after use and I doubt he let the thing cool.
Maybe the water cleaned off part of the block and dripped down? Kind of a steam clean effect?
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Did a Stupid Thing [Re: jkasch] #5419446 05/02/20 09:13 PM
spasm3 Offline
As suggested above, is it really leaking oil? Did the oil level drop? I don't really think hosing off the front wheel will cause an oil leak.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Did a Stupid Thing [Re: Zaedock] #5419450 05/02/20 09:18 PM
J
jkasch Offline OP
J
That's what I thought, but the oil is clean and fresh. It pools here before dripping off the frame. Can't see any other place.
[Linked Image]
Re: Did a Stupid Thing [Re: jkasch] #5419451 05/02/20 09:19 PM
Z
zrxkawboy Offline
Z
I'd be really surprised if the block cracked because you washed the front tire.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Did a Stupid Thing [Re: zrxkawboy] #5419454 05/02/20 09:21 PM
J
jkasch Offline OP
J
Me too! Didn't leak a drop before. Oil level stayed the same the whole season.
Re: Did a Stupid Thing [Re: jkasch] #5419457 05/02/20 09:25 PM
Z
Zaedock Offline
Z
I have one, and I think you can get one at Advance or Napa, a UV dye kit would be helpful in this scenario where you can't clearly see the block.
Re: Did a Stupid Thing [Re: jkasch] #5419460 05/02/20 09:31 PM
danez_yoda Offline
Make sure that FRAMer DAMMER isn't squirtin oil over there.
Re: Did a Stupid Thing [Re: danez_yoda] #5419463 05/02/20 09:36 PM
J
jkasch Offline OP
J
Thanks. I'll check that again tomorrow. I watched that while it was running. It would have to be a fine mist for me not to notice, though.
Re: Did a Stupid Thing [Re: jkasch] #5419467 05/02/20 09:40 PM
G
gman2304 Offline
G
I’ve had to do the same thing to my mower with never a problem. Take that tin covering the head off and take a look around.
Re: Did a Stupid Thing [Re: jkasch] #5419469 05/02/20 09:41 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
Does this have an aluminum block? Those aren't as prone to quench cracking as iron blocks are.
Re: Did a Stupid Thing [Re: Kestas] #5419473 05/02/20 09:45 PM
J
jkasch Offline OP
J
It's aluminum.
Re: Did a Stupid Thing [Re: jkasch] #5419483 05/02/20 10:06 PM
O
ondarvr Offline
O
I have one, it started leaking oil and I thought it was the seal on the bottom.
After several months I thoroughly cleaned everything to look for it.
The crankcase halves bolt together, the bolts had come a bit loose. Tightened all of them and it stopped leaking, a couple years later I needed to do it again.
