Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
78 registered members (55hambone, 4WD, 555, 1978elcamino, 2015_PSD, 64bawagon, 8 invisible), 2,144 guests, and 76 spiders.
Topics306,053
Posts5,286,506
Members71,593
Purolator one used cartridge oil filter. #5419351 05/02/20 06:33 PM
M
Micahmcmeen Offline OP
M
I have to say I'm rather disappointed. I had higher expectations for the filter. Its only been about 3,200 miles. Ran with PPHM in my 2008 Mazda 5. This has done the worst so far out of the cartridge filters I have purchased to spite it being the most expensive.
20200502_170848.jpg20200502_170850.jpg20200502_170858.jpg20200502_170855.jpg20200502_170912.jpg
Re: Purolator one used cartridge oil filter. [Re: Micahmcmeen] #5419358 05/02/20 06:43 PM
N
NormanBuntz Offline
N
I see those wavy pleats are still made in the USA.
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 12K, 2nd owner
2007 Honda Ridgeline RTS, 97K, original owner
2007 Infiniti M35, 115K, original owner
Re: Purolator one used cartridge oil filter. [Re: Micahmcmeen] #5419359 05/02/20 06:46 PM
53' Stude Offline
Looks ok, made August 17, 2017 in Fayetteville North Carolina smile
2009 Toyota Camry LE
Re: Purolator one used cartridge oil filter. [Re: 53' Stude] #5419361 05/02/20 06:49 PM
M
M
I agree it's not horrible. I think they are a bit twisted for 3k though. The stp in I had before was better than this. I replaced with wix xp than after that k&n.
Re: Purolator one used cartridge oil filter. [Re: Micahmcmeen] #5419373 05/02/20 07:15 PM
T
tig1 Offline
T
My 2007 Fusion has the same type of filter your Mazda uses. I tried 2-3 cartridge filters(Fram, M1) when I first bought the car and had the same experience as you. So I settled on the MC FL2017B cartridge and they are great with my 10K OCI I do. Here is a pic.. [Linked Image]
2007 Ford Fusion 258,000 miles
M1 5-20HM
2017 Ford Fusion 91K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: Purolator one used cartridge oil filter. [Re: tig1] #5419387 05/02/20 07:34 PM
M
M
I just bought a ton of wix xp on sale and have 2 k&n as well or I would try it.
Re: Purolator one used cartridge oil filter. [Re: Micahmcmeen] #5419392 05/02/20 07:45 PM
U
UG_Passat Offline
U
When I was using cartridge filters on my VW's... when FRAM switched to Made-in-China ones (Instead of German ones), I stopped using FRAMS, due to the crushed filters after using them (when new, the pleats were nice and straight). the Chinese FRAM cartridges has the same construction as the Purolator above.
Maybe a Mahle filter is of proper length?
https://www.rockauto.com/en/moreinfo.php?pk=3066870&cc=1441857&jsn=413
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Purolator one used cartridge oil filter. [Re: Micahmcmeen] #5419417 05/02/20 08:43 PM
W
walterjay Offline
W
Pretty disappointing for such low mileage on that filter. I would run Hyundai and Fram cartridge filters on my 07 SantaFe double that mileage and they would look almost new.
Re: Purolator one used cartridge oil filter. [Re: Micahmcmeen] #5419474 05/02/20 09:47 PM
B
blufeb95 Offline
B
If you want to be able to use a fancy filter, you could look into converting to a spin on I believe the Ford BS4Z-6881-F oil filter adapter(spin-on mount) and ford 1S7Z-6840-AA or FEL-PRO 72949 gasket would work the Ford parts places seemed to be trying to get rid of them online it's only like $30 shipped to get the Filter mount and gasket.
Re: Purolator one used cartridge oil filter. [Re: UG_Passat] #5419542 05/02/20 11:56 PM
CR94 Offline
Originally Posted by UG_Passat
... Maybe a Mahle filter is of proper length? ...
The length shouldn't need to be held to a tight tolerance, as long as it's roughly correct and there's a spring in the housing to compensate for minor variations in length.
None of my cartridges have come out twisted or buckled like that.
2011 Toyota Prius now at 110K
Re: Purolator one used cartridge oil filter. [Re: Micahmcmeen] #5419631 05/03/20 06:17 AM
K
Kira Online Content
Online Content
K
So it's just too long a filter?
blufeb95: Are you saying the Ford adapter will fit the OP's Mazda engine?
Re: Purolator one used cartridge oil filter. [Re: Micahmcmeen] #5419684 05/03/20 07:32 AM
J
joekingcorvette Online Content
Online Content
J
I just changed the oil on the Jeep and the filter was a Mobil 1 and it looked great. I would try a different filter.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: Purolator one used cartridge oil filter. [Re: Kira] #5419702 05/03/20 07:52 AM
K
Kruse Offline
K
The Fords and Mazdas of that era could have either a spin-on or cartridge filter. It's pretty simple to remove the cartridge system and replace it with a spin-on.
Re: Purolator one used cartridge oil filter. [Re: Kira] #5419704 05/03/20 07:55 AM
M
M
The filter wasn't too long. Has the same height as the others. I know they sell adapter kits. I just have no real reason to. Uy one.
Re: Purolator one used cartridge oil filter. [Re: Micahmcmeen] #5419717 05/03/20 08:12 AM
A
adamsoil Offline
A
Looks like incorrect fitment to me
