Horsepower in Various Modes
by Al - 06/01/20 11:39 AM
ATF Flush vs Drain and Fill
by diyjake - 06/01/20 11:24 AM
Is Your Vehicle Deadly?
by SubLGT - 06/01/20 11:02 AM
Question on the bottom of bottle with Penz Platinum
by babyivan - 06/01/20 10:55 AM
Used Mitsubishi Lancer prices
by 97prizm - 06/01/20 10:32 AM
Which oil is the better quality
by galaxy333 - 06/01/20 09:57 AM
"Boutique" Brands
by buster - 06/01/20 09:15 AM
CASTROL Edge 5w20 or EP 5w20
by 53' Stude - 06/01/20 09:09 AM
BT Oil
by js1956 - 06/01/20 09:00 AM
How to Properly Read a Dipstick
by Gebo - 06/01/20 07:59 AM
Why did some older cars have + grounded systems?
by JLawrence08648 - 06/01/20 07:39 AM
Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
C6H8O7, Jcvjr, Haywood, ToOliwer, AbbeyRoad
71588 Registered Users
103 registered members (Al, ABN_CBT_ENGR, Arcoril, aquariuscsm, 830Lee, ArrestMeRedZ, 10 invisible), 2,271 guests, and 39 spiders.
Topics306,121
Posts5,286,869
Members71,588
Replacing themostat, radiator cap, and waterpump at a regular interval #5419043 05/02/20 10:18 AM
P
Paul_Siu Offline OP
P
I was watching this video of some youtuber who suggest that we should considered replacing the radiator cap, thermostat, and water pump at some interval. He was suggesting that may be every 60K the radiator cap and thermostat should be replaced. The radiator cap because the seal breaks down and it no longer holds the pressure it used to. The thermostat may eventually failed. The water pump should be replace when you change timing belt.
I do recall that in my first car, my thermostat seems to fail often resulting in overheat of the car and probably contributed to its demise. In the past, I always replace the water pump every timing belt change, but the Subaru dealer suggested that it wasn't really necessary since the water pump is quite robust. What do you think?
Paul
Re: Replacing themostat, radiator cap, and waterpump at a regular interval [Re: Paul_Siu] #5419051 05/02/20 10:29 AM
Z
Zaedock Offline
Z
I think it depends on the use of the vehicle. I drive to Boston and inside 95/128 almost every day. The thermostat and cap would have to be replaced every two years, which is not realistic. I don't believe the cooling system is even in the regular maintenance book. Just oil and filter and rotations. I'd have to check the frequency in the owners manual.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Replacing themostat, radiator cap, and waterpump at a regular interval [Re: Paul_Siu] #5419055 05/02/20 10:33 AM
H
HowAboutThis Offline
H
Paul
60k seems too often to me. But I am not fully against preemptive replacement. However, if I have an OEM water pump doing fine I probably wouldn't preemptively replace with aftermarket. Just my opinion.
Re: Replacing themostat, radiator cap, and waterpump at a regular interval [Re: Paul_Siu] #5419060 05/02/20 10:38 AM
ABN_CBT_ENGR Online Content
Online Content
Paul
Not so much vehicle specific but in reality a car is no different than any other machine in terms of your question.
Assuming a properly assembled part ( whatever it is) and properly matched function ( part specifications are within range of the actual application it has to function in regardless of the parent machine) then there is no legitimate "engineering" answer to this.
Boiled down there are 2 basic reasons for this.
Since the parts are different in construction, design and purpose ( and often exposed to different areas of a machine which means the exposed stresses are different as well)- their "wear" cant be correlated in any legitimate manner.
Then is the scale to determine the frequency.. In reality most scales ( hour meter, odometer etc.) are measuring a frequency which is seldom directly relative to the stressors that contribute to the degradation of the component. ( more of a scheduling tool rather than an indicator of loss of performance)
It boils down to risk ( actual, perceived or set value) the individual sets for his equipment based on his circumstances on what level is acceptable.
Then that risk is qualified as to the skills, level of maintenance and so forth that specific individual has or is willing to invest in.
Its really in the eye of the beholder.
Personally when I repair something ( mine or client machinery) I always propose at a minimum to inspect/repair the entire function ( or system) to the proper level because I have often found that introducing a "new' part in a uniformly worn system will often become the failure mechanism for the next weakest link.
Re: Replacing themostat, radiator cap, and waterpump at a regular interval [Re: Paul_Siu] #5419066 05/02/20 10:42 AM
P
painfx Offline
P
Has anyone notice when you drain and refill coolant and dont change the thermostat, the coolant temperature gauge will show the temperature is slightly lower than before?
Re: Replacing themostat, radiator cap, and waterpump at a regular interval [Re: Paul_Siu] #5419071 05/02/20 10:50 AM
Snagglefoot Offline
I prefer to keep a close watch drips indicating a seal failure and also keep an eye on the temp. An infra red temp gun is a useful devise to check it. Once past 200,000 miles it is tempting to do a proactive change but so far I have not done it. smile
If you want the job done right......do it yourself.
Re: Replacing themostat, radiator cap, and waterpump at a regular interval [Re: painfx] #5419082 05/02/20 11:07 AM
H
H
No.
Re: Replacing themostat, radiator cap, and waterpump at a regular interval [Re: HowAboutThis] #5419085 05/02/20 11:11 AM
gathermewool Offline
No.
+1 No.
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (2nd OFI) (77,760mi, 3/7/20)
15 Legacy Premium FB25
Magnatec 0W-20 D1G2+ FU filter (2nd OFI) (54,621mi, 3/4/20)
Re: Replacing themostat, radiator cap, and waterpump at a regular interval [Re: painfx] #5419092 05/02/20 11:19 AM
K
kschachn Offline
K
Considering how most temperature gauges operate and also how the thermostat is constructed to a specific set point, no.
How's New Jersey?
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Replacing themostat, radiator cap, and waterpump at a regular interval [Re: Paul_Siu] #5419102 05/02/20 11:35 AM
M
mk378 Online Content
Online Content
M
Most likely explanation is that it wasn't completely full to work at its best before draining.
Re: Replacing themostat, radiator cap, and waterpump at a regular interval [Re: Paul_Siu] #5419116 05/02/20 11:51 AM
slacktide_bitog Offline
They do not have to be replaced at regular intervals, but if your car has a timing belt, you should replace the water pump along with it since the WP is often driven by the TB
I'd replace the radiator cap when replacing the radiator.
Re: Replacing themostat, radiator cap, and waterpump at a regular interval [Re: Paul_Siu] #5419126 05/02/20 11:59 AM
Chris142 Offline
Since I work at a radiator and ac shop we see lots of defective radiator caps.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Replacing themostat, radiator cap, and waterpump at a regular interval [Re: Paul_Siu] #5419144 05/02/20 12:29 PM
P
Pelican Offline
P
I think that replacing the T-stat every 60K miles is a preemptive move and IMO a wise one, as just to test it you have to remove it, so one might just as well change it.
The rad cap can be tested easily enough and changed when needed.
The water pump, depending on location, but it ought to be changed either when one changes the timing belt or, if a chain, whenever it states so in the owner's manual.
Re: Replacing themostat, radiator cap, and waterpump at a regular interval [Re: Paul_Siu] #5419160 05/02/20 12:50 PM
H
hallstevenson Offline
H
Where do you draw the line with preventative maintenance (replacement of working parts) ? Replace the starter at 100k miles ? All four wheel bearings at "x" miles ?
Re: Replacing themostat, radiator cap, and waterpump at a regular interval [Re: Paul_Siu] #5419161 05/02/20 12:50 PM
K
Kansas_Ron Offline
K
Change your coolant at the correct time (perhaps a little bit early) and you most likely won't need to replace parts. At least not at 60,000 miles.
2000 Chevy Prizm
2015 Honda Civic
2017 Hyundai Elantra
