Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
Two Motorcraft FL400S Filters Cut Open
by HX520W - 06/05/20 04:36 PM
VIN character that designates engine
by grampi - 06/05/20 04:35 PM
Two WIX 57356XP Filters Cut Open
by HX520W - 06/05/20 04:17 PM
Blue lights on Uber vehicles
by John_Conrad - 06/05/20 04:08 PM
2015 RAM EcoDiesel 3.0L, 5,354mi, M1 TDT 5w40
by SavagePatch - 06/05/20 03:18 PM
2014 5.7 Charger UOA
by Bob D - 06/05/20 02:42 PM
Mazda 3 1.6 DV6C UOA Low TBN Qeustion
by mossietheno1 - 06/05/20 01:59 PM
CRJ-550
by dja4260 - 06/05/20 01:46 PM
Aluminum Welding Question
by George7941 - 06/05/20 01:21 PM
Will 0w40 be good for next winter?
by mahanddeem - 06/05/20 01:21 PM
Motor Oil Saver less than 10.00 shipped
by cknight49090 - 06/05/20 12:27 PM
Taking my kid fishing
by Quattro Pete - 06/05/20 12:22 PM
How to rebuilt a starter
by LazyDog - 06/05/20 12:11 PM
LouK2, Michael328i, tyman, Knot_A_Mekanik, Matts59
71615 Registered Users
91 registered members (Astro_Guy, 830Lee, bbhero, 4WD, 2whlgeezer, 77GrandPrix, 11 invisible), 1,882 guests, and 89 spiders.
Topics306,264
Posts5,289,235
Members71,615
Cab and Chassis rear shock ford F350 #5418980 05/02/20 09:11 AM
G
GON Offline OP
G
RockAuto had a clearance on KYB 555053 shocks for a RWD F350 MY 2005-2010.
The KYB shocks were listed as a replacement for RWD, cab and chassis. The were $25 each on RockAuto, $52 on Amazon. I purchased the shocks from RockAuto.
Later I discovered the shocks are specifically for a cab and chassis- KYB does not specify these shocks for a F350 with a bed. I went to KYB website, they specify 345072 for a 2007 F350, XLT standard cab, rwd. KYB specifies 555053 for a 2007 F350, XLT, cab and chassis.
Question is- can I run the 555053 cab and chassis shock on my standard cab, without a safety or performance concern?
Re: Cab and Chassis rear shock ford F350 [Re: GON] #5419000 05/02/20 09:36 AM
Z
Zaedock Offline
Z
They will likely physically fit. I would run them and see how they ride.
They are designed to dampen a C&C with a large stake or other bed, but it's still a 350 chassis.
Worst case, you're only out $50, no biggie. Throw them on craigslist or FB marketplace for $50 and get your money back.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Cab and Chassis rear shock ford F350 [Re: GON] #5419148 05/02/20 12:33 PM
R
ripcord Offline
R
The 345072 part is an Exel-G line shock which is a conventional twin tube design. The 555053 part is a Gas-a-Just line shock which is a mono-tube design. Mono-tubes are considered to be a superior shock but may give a harsher ride. I would try them and see if I like them or not. The handling and safety will likely be improved, though possibly at the expense of a little comfort.
Re: Cab and Chassis rear shock ford F350 [Re: GON] #5420600 05/04/20 09:09 AM
G
GON Offline OP
G
Gents,
Thanks for the comments. I wrote KYB- this is their reply:
Both part numbers would mount up on the vehicle the same, but you would run into an issue with shock length. The cab and chassis shock is about 4" shorter than the shock for the standard cab, so you would likely be topping out in normal driving and we would not recommend doing this.
Instead, you will be better off returning 555053 to the original place of purchase and swapping it out for 554366 for your truck.
Re: Cab and Chassis rear shock ford F350 [Re: GON] #5420709 05/04/20 11:34 AM
bdcardinal Offline
Also the chassis-cabs are called "narrow frame" in our catalogs while the pickups are "wide frame" because, you guessed it, the frames are different.
And yes, the chassis-cabs are shorter to accommodate service bodies. I didn't really realize this until we measured them at work because a sales person couldn't understand why Ford recommended ordering a chassis-cab for a customer who wanted a service body and not taking the bed off a pickup.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
