Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
rorty, Ghosty, zmann96, yetti96, weekendwally
71602 Registered Users
41 registered members (carlprop, billpace1956, blufeb95, ArrestMeRedZ, BTLew81, Aero540T, 2 invisible), 1,028 guests, and 52 spiders.
Topics306,113
Posts5,287,783
Members71,602
Ford 4.2L V6 water pump question #5418957 05/02/20 08:43 AM
civhatch90 Offline OP
Coming back to this awesome resource as my very amateur skills assemble this back together.
Questions:
1. Do I need to apply any silicone based gasket maker to any of the mating surfaces if there is a gasket already included? Attached picture for reference of what the gasket looks like.
2. Recommended torque specs are 15-22 ft/lbs. But what if there is fluid on the threads such as oil or whatever else may be around? Should the torque spec be lower?
Thanks for the help!
Re: Ford 4.2L V6 water pump question [Re: civhatch90] #5418965 05/02/20 08:58 AM
J
Jimzz Offline
J
I use a very thin layer of Ultra RTV to both sides. Holds the gasket in place when bolting up and will fill in any micro damage to the metals the gasket may not fill in well.
A small half oz package is more than enough to do the job.
https://smile.amazon.com/Permatex-82180-Maximum-Resistance-Silicone/dp/B000HBIBOY?th=1
or
https://smile.amazon.com/Permatex-22071-Thermostat-Silicone-Gasket/dp/B0007TQW60
yup
Re: Ford 4.2L V6 water pump question [Re: civhatch90] #5418970 05/02/20 09:03 AM
W
WyrTwister Offline
W
I know nothing about that make & model engine , but I have installed my share of water pumps over , maybe 50 years .
Have never used a torque wrench on a coolant pump . Just tighten it until it is tight .
I commonly use non hardening Permatex to " glue " the gasket to the removable part . Let it " dry " long enough to hold the gasket in place while getting everything lined up & then start installing fasteners .
If you ever have to replace it again , you throw away the old pump and do not have to scrape sealant from the engine .
Wyr
God bless
Re: Ford 4.2L V6 water pump question [Re: civhatch90] #5418991 05/02/20 09:25 AM
Chris142 Online Content
Online Content
Make sure to clean all the old gasket off the timing cover being carefull not to gouge it. Nobody torques that stuff. Snug by hand.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Ford 4.2L V6 water pump question [Re: civhatch90] #5419007 05/02/20 09:44 AM
N
nobb Offline
N
All manufacturers never recommend any RTV on top of gaskets as that could cause sealing issues. They can even deny warranty claims because of it. So just make sure the surfaces are clean with no pitting, and install dry.
It also takes almost no time to get a torque wrench so why not do it property. Clean the threads as best as you can and torque to spec.
Re: Ford 4.2L V6 water pump question [Re: civhatch90] #5419030 05/02/20 10:08 AM
K
kschachn Offline
K
Yes, install it exactly as the manufacturer tells you to do so. Do you have a service manual? You may be able to find the information online, perhaps on Autozone's website.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
