Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
98 registered members (ABN_CBT_ENGR, Alfred_B, amblerman, AlienBug, 2015_PSD, aray, 7 invisible), 1,865 guests, and 51 spiders.
Topics306,087
Posts5,287,152
Members71,596
Box fan motor grease #5418821 05/01/20 11:21 PM
R
Rgbraun1 Offline OP
R
Took apart a box fan down to separating the motor. The bearings/bushings on both ends of the shaft are packed in with some dried out yellowish brown stuff. I assume is grease. Everywhere else online folks say just live shaft with a drop of oil. No one had an opinion on the grease part. Any suggestions?
Picture shows the brass cap, star goes inside the cap as does the silver bearing/bushing. The brown junk was packed all around in the inside of the brass cap once assembled. There is two of these cap assemblies on both ends of the motor.
Re: Box fan motor grease [Re: Rgbraun1] #5418846 05/02/20 12:13 AM
9
928 Offline
9
The yellow stuff is packing meant to hold the oil looks like it could be reused & add a little- no grease in the motor, fractional hp motors don't like the drag
Re: Box fan motor grease [Re: Rgbraun1] #5418943 05/02/20 08:16 AM
P
pcoxe Offline
P
I re-oil those with Amsoil synthetic ATF. A few drops salvaged from an "empty" jug. Go years without needing oil again.
Re: Box fan motor grease [Re: Rgbraun1] #5418944 05/02/20 08:25 AM
V
vwmaniaman Offline
V
That looks like dried up lubriplate. Put a saturated felt pad in there soaked with 3 in1 oil.
Don't waste your time on a slipshod repair.
Re: Box fan motor grease [Re: Rgbraun1] #5418967 05/02/20 09:00 AM
CatCam2 Offline
My "repurposed" box fan -- custom made from an old house fan. This is from an early 1950's Phil Rich Fan Co. house fan (before central AC). Stripped everything down and repainted in LSU colors! Roll it around on casters that are lockable. Original AC motor and bearings! This is back when they built fans to last, it moves an incredible amount of air very quietly!
[Linked Image]
Re: Box fan motor grease [Re: Rgbraun1] #5419122 05/02/20 11:57 AM
R
ripcord Offline
R
The radius-ed edge on the baffle is a nice touch!
Re: Box fan motor grease [Re: CatCam2] #5419154 05/02/20 12:41 PM
B
bcossa2001 Offline
B
As a Bama fan (who cheered for LSU in the Natty) Iā€™m gritting my teeth to hold back the jokes about how much air LSU fans are capable of producing šŸ˜ŽšŸ˜Ž
"Facts are pesky things"
2003 Town & Country--143 k
2016 Fusion 8 k
2016 Fusion 40 k
2017 Santa Fe 8k
Re: Box fan motor grease [Re: bcossa2001] #5419255 05/02/20 03:19 PM
CatCam2 Offline
well played bcossa2001!! I'm sure I set myself up for some jokes!
Re: Box fan motor grease [Re: Rgbraun1] #5419650 05/03/20 06:42 AM
L
Lubener Offline
L
Box fans are super cheap in price. Myself, I wouldn't waste my time on it and buy a new one.
The "thinking" man's friend.
Re: Box fan motor grease [Re: Rgbraun1] #5419950 05/03/20 12:21 PM
K
kc8adu Offline
K
there should be felt in that area.
it must be in contact with the oilite bushing to supply it with oil.
20w nd or zoom spout "turbine oil"
as for cheap if its an oldie its worth rehabbing.
if its $10 at the dollar general then no.
those seem to be done after 1 season.
i have a lau made in the 40's thats still perfect.
it was free on trash day 30 years ago.
i cleaned it up and 2 drops of oil in each bearing at the start of the season.
you cannot buy that sort of quality any more.
Re: Box fan motor grease [Re: Rgbraun1] #5420651 05/04/20 10:20 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Felt packing. Believe that bearings and motors like that should have some sparing amount of detergent free oil (e.g. turbine or compressor oil), which wicks into the felt and/or the bronze bearing, which is porous.
Others can clarify my info here to be more accurate, but that's my understanding.
Over-oiling isnt great either...
