Temporary Viscosity Loss
SD
I have a CAPS era Cummins ISL 8.9L in my motorhome. It's pushing 35,000 - 36,000 pounds down the road. I ran Chevron Delo 400 LE 15-40 before but now I'm using Chevron Delo 15-40 SDE. This is a CK4 oil. I haven't done anything else different. What I'm noticing is that under high load - i.e. pulling a long, steep grade - the oil pressure falls below what I previously experience before using CK4. It seems to be a temporary viscosity loss as the oil pressure rises again after the engine load decreases and operating temperature drops.
Yesterday in 100 degree ambient temperature going up grades to Payson, Arizona my coolant temperature reached 205 degrees and the oil pressure at 1,500 RPM dropped to 30 - 35 PSI. At the top of a long grade at a stop light the pressure fell below 10 PSI at idle. When the coolant was at the normal operating temperature of around 182 degrees, the oil pressure at 1,500 RPM was back to 40 - 45 PSI and at idle it was 14 - 15 PSI. Is this normal? The older LE formula never dropped this low. It has happened since changing to CK4 two oil changes ago and has happened repeatedly with CK4.
Yep, the old stuff was thicker with a KV110C of around 15.6 and HTHS of 4.3-4.4 @ 150C. Many of the new 15W40s have lowered their KV100C to the mid 14s. Maybe it's a fuel economy thing.
I've been known to spike my 15W40s in hot weather with 20% SAE 50. History tells us that back in the day, 15W40 was a wildcat grade. Truckers mixed SAE 50 with 10W30 to get a thick multi-grade.
Originally Posted by ripcord
Do you have an oil temp gauge?
Unfortunately, no.
The Cummins is an expensive engine I would first contact Cummins rather than a use forums opinion.?
I always thought that oil pressure followed the bulk oil (sump) viscosity. As the temperature rises, the oil pressure goes down.
On a cold winter morning, the oil pressure is off the chart.
OMG - the "CAPS" system! Cummins Accumulator Pump System. Cummins quickly got rid of that thing. Hope it is hanging in there for you. Don't know Delo oils, but sure seems to be a temp / vis thing with CAFE fuel economy. Have you checked the other major supplier's vis / temp data?
Yeah, the lift pump is definitely a weakness in CAPS, but otherwise the engine is solid. No EGR or other crap. Thanks guys for the responses, I'm still trying to get my head around HTHS and why this oil performs differently than the previous CJ-4 Delo 400 LE. I haven't been able to find a HTHS spec for the CJ-4.
I've also noticed a slight drop in oil pressure with the Series 60 Detroit in my Semi while I'm loaded heavy and pulling a grade. Once my engine is no longer pulling the grade, and the coolant temperature and the oil temperature cool back down to normal temperatures, my oil pressure gauge reads the same as it was reading before I pulled the grade. I'm guesstimating I see maybe a drop of 2 to 4 pounds on the gauge when pulling a grade.
I've seen this regularly using the following 15W40 motor oils: Mobil Delvac 1300 Super CJ4 and CK4, Chevron Delo 400 LE CJ4, Chevron Delo 400 SDE CK4, and Chevron Delo 400 XLE CK4. I've never been overly concerned about it, I've always assumed the slight oil pressure drop is in relation to the hotter engine oil temperature while the engine is working a bit harder, pulling a grade.
And for what it's worth, I didn't notice this change in oil pressure nearly as much when I used Phillips 66 Guardol ECT 15W40 in my engine. That oil really seemed to keep a consistent oil pressure, even when I was climbing a grade.
I definitely see exactly what you describe in your post with my Series 60 Detroit. My oil pressure gauge regularly shows different readings in regards to different engine temperatures.
Is this a debate between % viscosity loss between high temp and high shear? Both can be temporary and permanent. Temporary is self-explanatory (vis thins with temp, vis thins with stretching of VII additive in journal bearings).
Permanent shear down can be due to high temp volatility evaporation, shear breaking down the VII additive. Does the fact these users see return to normal temp & pressure mean both viscosity loss types are all temporary?
Every now and then I put SAE40 in my 2011 6.6L Duramax. HTHS around 4.3. The oil pressure does act differently than 15W40 with the same HTHS
When worked hard up mountain grades in hot weather, both oil pressures are the same despite the higher KV100C of the 15w40. 15.7 vs 14.4
Oil pressure junkies like me keep bottles of SAE 50 around for top ups and juice boosting.
Thanks for the anecdotes. There doesn't seem to be anything special about the Phillips 66 Guardol ECT 15W-40 CK-4, and it has more VII and a thinner base oil than other 15W-40's.
Estimated base-oil viscosity at 150 °C (BO DV150) and VII content of selected oils
So if I'm understanding this correctly, the temporary viscosity loss is design feature of the CK 4 oil. I have a hard time understanding how this viscosity loss is providing better bearing protection than the CJ 4 which didn't have as much of an oil pressure drop.
No, it has nothing to do with CJ-4 or CK-4. All oils get thinner at higher temperatures, resulting in a lower oil pressure. This is normal behavior.
Thanks for this chart. Is this the: "A-Harman Base Oil Quality Index" that I've heard a bunch of people here talk about?
Does this pertain only to the finished oil's base, or does it also detail the finished oil's additive pack, along with the base oil?
Thank you in advance!
