Exploded view needed: 2014 Infinity qx60 Middle row Passenger Side Seat
Dallas, Texas
The seat will not fold up anymore.
It will scoot forward and backward and will recline, but it appears that the cable that disconnected it from the tracks has somehow come loose and when that lever is pulled it only inclines forward a bit but the tracks don't unlock.
It makes loading and unloading kiddos interesting.
Any diagrams or exploded views you can find I would be grateful.
Thank you!
This is what I could find on AllData
Thank you,
It has to deal with the second diagram, part #11 the Track Tilt Release Cable
Now to figure out how to re-attach it so that it works.
Removal
1.Remove the seat seatback.
NOTE:
It is not necessary to separate the seatback trim from the seatback pad.
2.Release (Black arrow) the track tilt release cable (1) from the seat frame assembly.
CAUTION:
Note the cable routing for correct installation.
3.Remove the track tilt release cable (1) from the seat frame assembly (2) and release cable ends (A).
4.Remove the track tilt release cable (1).
