2 cycle with catalyst - carb settings?
by cjolson140 - 06/02/20 01:22 PM
Scam: Ghana $+2 - US $-2
by pandus13 - 06/02/20 01:09 PM
Motorcycle rear shock rebuild
by Reddy45 - 06/02/20 12:45 PM
2016 Lexus RX350 Oil Change change
by Toros - 06/02/20 12:43 PM
Tire Mobility Kits
by wings&wheels - 06/02/20 12:06 PM
Worst accident you've witnessed
by Dave Sherman - 06/02/20 12:04 PM
Shock Fluid
by splinter - 06/02/20 11:21 AM
Michelin X-Ice 4 North for Canada ...
by odie - 06/02/20 11:03 AM
Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
96 registered members (4WD, 97prizm, ammolab, 55hambone, ABCarr, alarmguy, 10 invisible), 2,593 guests, and 38 spiders.
Topics306,061
Posts5,286,646
Members71,593
Rotors turned at Oreillys today #5418371 05/01/20 02:56 PM
E
Electromotive Offline OP
E
Took my 2003 Accord front rotors to Oreillys today to see if they could be turned. They measured them and said they were within limits to be turned and it would be a couple of hours. 45 mins. later they called and said they were ready. They look great and price was $10 per rotor. That's what I call great service.
Re: Rotors turned at Oreillys today [Re: Electromotive] #5418379 05/01/20 03:03 PM
The Critic Online Crying
Online Crying
$10/rotor is cheap.
Make sure you measure the lateral runout of those rotors after install. You may be in for a nasty surprise - a lot of them are out-of-spec after they are turned on a bench lathe. You should see .002" or less, preferably .001" or less.
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Rotors turned at Oreillys today [Re: The Critic] #5418389 05/01/20 03:10 PM
Donald Offline
Originally Posted by The Critic
$10/rotor is cheap.
What causes that? Operator error? Lathe out of tolerance?
2015 Ford F-250 w/Powerstroke
Re: Rotors turned at Oreillys today [Re: The Critic] #5418429 05/01/20 03:41 PM
Chris Meutsch Online Content
Online Content
$10/rotor is cheap.
I agree, I used to pay more than that in the 90's.
2016 Toyota 4Runner Trail Premium, 58k
*RIP* 2005 Honda CR-V EX, 284k
Re: Rotors turned at Oreillys today [Re: Electromotive] #5418454 05/01/20 04:06 PM
E
eljefino Offline
E
Had one turned for my grand marquis due to "lot rot". New part (rear) was $50 for some reason. $12 later and I was happy.
Re: Rotors turned at Oreillys today [Re: Donald] #5418503 05/01/20 04:53 PM
bdcardinal Offline
$10/rotor is cheap.
All of the above. Also any out of round on the hub will be magnified on the rotor.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Rotors turned at Oreillys today [Re: bdcardinal] #5418515 05/01/20 05:08 PM
Online Crying
$10/rotor is cheap.
+1, and adapters in poor condition are a large contributor.
Re: Rotors turned at Oreillys today [Re: Electromotive] #5418543 05/01/20 05:31 PM
W
WhyMe Offline
W
none of the O's do it in my area . machine shops charge about $15 to $20 per rotor. most of the time its cheaper to just by a new one.
Re: Rotors turned at Oreillys today [Re: Electromotive] #5418611 05/01/20 06:20 PM
CKN Offline
So for another 20 bucks you could have bought NEW ONES......
Re: Rotors turned at Oreillys today [Re: CKN] #5418714 05/01/20 08:14 PM
H
hallstevenson Offline
H
If the rotors could be re-machined, they are probably high-quality rotors to begin with. Good luck turning a $30 rotor. Those are throwaway rotors.
Re: Rotors turned at Oreillys today [Re: Electromotive] #5418716 05/01/20 08:16 PM
A
aquariuscsm Online Content
Online Content
A
I bet Honda oem (which would be the only ones I'd buy) are pretty expensive.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
Re: Rotors turned at Oreillys today [Re: Electromotive] #5418769 05/01/20 09:24 PM
Chris142 Offline
I sand blast the adapters and rotor insides before I turn them as to not get them mounted crooked. You can also turn the adapters if need be.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Rotors turned at Oreillys today [Re: Electromotive] #5418827 05/01/20 11:30 PM
P
painfx Offline
P
Thought it has been $10/rotor for quite a while now...
Re: Rotors turned at Oreillys today [Re: Electromotive] #5418982 05/02/20 09:13 AM
W
WyrTwister Offline
W
In 50 years , I do not think I have ever had a drum / rotor turned . If I am driving it , I run them until they are worn out .
If it is the car Wife drives , no longer have much problem with them , once I finally convinced her to not continue driving it , after it went metal to metal .
Before that , I would replace drums / rotors on her car , if they looked bad .
I am amazed . She drives a 2015 Chevy Sonic with 70,000 + miles on the clock . I have yet to do anything to the brakes . Cross my fingers and knock on wood .
Wyr
God bless
Re: Rotors turned at Oreillys today [Re: Electromotive] #5419238 05/02/20 03:01 PM
bdcardinal Offline
One of my neighbors comes over whenever I work on one of the cars and tries to ask me about what I am doing. When I was doing the brake pads and rotors on my Mustang he couldn't understand why I didn't get them machined. I already had new Ford ones, but if I had to have them machined I would have had to drive another car to either a place to have them done or bring them to my work and do it myself on our lathe. Instead I just slammed on new rotors and called it a day. I was going to save the old ones, but left them outside and now they are a giant rust pile.
