Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
93 registered members (53' Stude, 830Lee, Alfred_B, akh, 97prizm, ABN_CBT_ENGR, 4 invisible), 2,180 guests, and 70 spiders.
Topics306,053
Posts5,286,527
Members71,593
Page 1 of 6 1 2 6
CK-4 Diesel Oil for old 6.0l PowerStroke? #5418257 05/01/20 01:16 PM
L
LubricatusObsess Online Content OP
OP Online Content
L
My son is still in college and bought a used truck: 2004 Ford Super Duty F350 with the Navistar "PowerStroke" 6.0 liter V8 engine. Modern diesel oils were developed for the latest diesel engines, of course, so I'm having trouble finding which would be best for this older engine. Would appreciate BITOGer wisdom on this one. Detail below for reference.
I was with Cummins for 22 years, retiring in 2016. I researched the old Navistar 6.0l PowerStroke engine and found it uses Gen II HEUI Fuel Injectors. The HEUI of course is "Hydraulically-Actuated, Electronically-Controlled, Unit Injector", developed with Caterpillar. It was an interim EPA emissions reduction strategy prior to HPCR (High Pressure Common Rail Electronically Control AND Actuation). The problem with the HEUI was using dirty engine oil as a hydraulic fluid often caused sticky injector pintles, requiring injector replacement. Cummins used "HPI" that used fuel as a hydraulic fluid, varying the length of the injection plunger. It still used a mechanical cam to inject. CAT also had this on their bigger engines and called it "MEUI".
Anyway, the boy's truck was a farm truck that was dealer-maintained, so a pretty good deal despite the other problems with the Navistar 6.0l engine. Being a 2004, Navistar had already addressed some of the problems from the 2003 launch. It "only" has 113,00 miles on it and is in good shape. Still, he had it diagnosed and it already had 2 sticky HEUI injectors, so he's having all 8 injectors replaced with rebuilt.
He wants the correct engine oil for the new injectors to keep them as clean as possible for maximum service life. He should be able to get another 100,000 miles from this engine. The other problem with these injectors is oil flow. We live in the far north US, so cold start is problematic with a mineral oil. For this reason, I recommend using only synthetic year around. Synthetic also retards base stock oxidation breakdown - critical for HEUI injectors
Finally, the higher pressure required to use engine oil as the hydraulic actuation for the injectors required a higher pressure oil pump, which made antiwear far more important than would otherwise be with standard engine lubricating oil pressure (40-60 psi @ rating). I don't know what the injector oil pressure is, just that Ford made a big stink about to the point when the oils went to API CK-4, they tested a bunch and found them "insufficient" antiwear because the newer engines took the ZDDP out and lowered the phos so as to not poison the new SCR EPA TIer IV exhaust catalysts.
So Ford created an engine oil spec to demand the antiwear back, via new formulations. The spec is wss-m2c171-f1. I visited their approved oil list. The only 3 available in my region are:
- Motorcraft Full Synthetic Diesel (of course), only available at the dealer (unknown price), Amazon $53 / gallon, and O'Reilly's $40 / gallon.
A pretty ridiculous price for an API Group III engine oil, that Ford insists must be changed every 5,000 miles to prevent injector problems.
- Valvoline Premium Blue Extreme, available from Amazon, Walmart, O'Reilly's for ~ $29 / gallon. That's within the range of acceptable pricing.
- Shell Rotella T6, available all over the place around $22 / gallon.
None of the Mobil Oils are approved except Delvac 1 ESP 0W-40. Mostly only available in Canada - I can't find it anywhere online.
Which of those 3 above have the better recipe for the older HEUI engine? And please, no Amsoil diatribes about Signature Series API Group IV PAO being the best. Need to change every 5,000 miles to dump the soot from sticking the injectors.
Ready, set, GO!!!
Elastohydrodynamic Lubrication makes the world go 'round!
2017 Ram 2500 - PUP 0W-40, Fram XG
2011 Chev Traverse - PUP 5W-30, Fram XG
2005 Chev Kodiak C5500 - PUP 10W-30, Fram XG
Re: CK-4 Diesel Oil for old 6.0l PowerStroke? [Re: LubricatusObsess] #5418264 05/01/20 01:20 PM
M
mattd Offline
M
MC 10w30 and be done with it. Use OEM filters only. I’ve worked on the 6.0 since 2007.
Is it an early or late 04? ICP sensor on pass oil rail or under turbo?
The injection system uses up to 4000 psi oil pressure.
If you have tech questions feel free to PM me
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: CK-4 Diesel Oil for old 6.0l PowerStroke? [Re: LubricatusObsess] #5418344 05/01/20 02:36 PM
Donald Offline
If you can find some CJ-4 oil that will be fine. If not then would go with a Rotella T6 5W40.
2015 Ford F-250 w/Powerstroke
Re: CK-4 Diesel Oil for old 6.0l PowerStroke? [Re: LubricatusObsess] #5418374 05/01/20 02:59 PM
JohnnyJohnson Offline
My old Ford PowerStroke did just fine on Rotella.
2004 Corolla 140116
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77077
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: CK-4 Diesel Oil for old 6.0l PowerStroke? [Re: LubricatusObsess] #5418453 05/01/20 04:05 PM
J
JMJNet Offline
J
Your son can use any Diesel rated motor oil for his Ford PS Diesel.
Check the Owner's manual for viscosity requirement but I suspect, it needs xW-40 where x can be 15 (mostly Dino) or 5 (Synthetic) depending on the usage and climate.
  • 2017 Toyota Sienna
Re: CK-4 Diesel Oil for old 6.0l PowerStroke? [Re: LubricatusObsess] #5418461 05/01/20 04:15 PM
M
mattwithcats Offline
M
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: CK-4 Diesel Oil for old 6.0l PowerStroke? [Re: mattd] #5418462 05/01/20 04:16 PM
L
OP Online Content
L
Thanks mattd. Don't know what build sequence the truck was made in - just that it is model year 2004.
MC 10W-30 nonsyn? Recall I'm in mid-Minnesota, and MC is difficult to source + very expensive?
Re: CK-4 Diesel Oil for old 6.0l PowerStroke? [Re: Donald] #5418464 05/01/20 04:16 PM
L
OP Online Content
L
Yeah, they're all CK-4 now. That's the problem. Even Mobil 1 TDT went to CK-4. Surprised me.
Re: CK-4 Diesel Oil for old 6.0l PowerStroke? [Re: JohnnyJohnson] #5418466 05/01/20 04:18 PM
L
OP Online Content
L
Thanks. Why'd you boot out T6 and go to mineral? Not cold where you are? No deposit concerns?
Re: CK-4 Diesel Oil for old 6.0l PowerStroke? [Re: JMJNet] #5418467 05/01/20 04:20 PM
L
OP Online Content
L
Ford is still hard-a$$ on meeting their oil spec. I understand this truck is out of warranty, but still don't want to mess around guessing if everybody's oil meets it when only 3 are on Ford's approval list per my OP.
Re: CK-4 Diesel Oil for old 6.0l PowerStroke? [Re: mattwithcats] #5418470 05/01/20 04:27 PM
L
OP Online Content
L
Thanks mattwithcats, but I said I can get T6 5W-40 here, less $ than 0W-40. I'm looking for compare between T6, Premium Blue Extreme, and Motocraft, thx.
Re: CK-4 Diesel Oil for old 6.0l PowerStroke? [Re: LubricatusObsess] #5418471 05/01/20 04:27 PM
4WD Offline
Re: CK-4 Diesel Oil for old 6.0l PowerStroke? [Re: 4WD] #5418523 05/01/20 05:18 PM
M
mattd Offline
M
Motorcraft 10w30 is 18$ for 5 quart jug at local WM. It should be still CJ4
ASE Master, L1, L2
Re: CK-4 Diesel Oil for old 6.0l PowerStroke? [Re: LubricatusObsess] #5418617 05/01/20 06:23 PM
B
Bighorn2500 Offline
B
T6 5w40 is easy to come by these days and Valvoline premium blue extreme is available at NAPA on sale for $21 a gallon a few times a year. You can also get either on Amazon for around $60 for a 3 pack of gallon jugs.
I use either when found on sale for my Cummins.
2012 Ram 2500 SLT 6.7L Cummins 4x4
2018 Dodge Durango GT 3.6L 4x4
Re: CK-4 Diesel Oil for old 6.0l PowerStroke? [Re: LubricatusObsess] #5418655 05/01/20 07:15 PM
M
maineiac Offline
M
Just curious, has the engine been "bulletproofed"?
Page 1 of 6 1 2 6
