Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
55 registered members (Best F100, ABN_CBT_ENGR, Blueskies123, A_Harman, BigGeo, 4 invisible), 1,040 guests, and 86 spiders.
Topics306,117
Posts5,287,833
Members71,604
07 Accord 2500rpm shudder #5418138 05/01/20 10:38 AM
A
aquariuscsm Offline OP
A
My brother just sent me this video and said his car is doing this exact same thing. Shudders at 2500 rpm and doesn’t want to rev higher. It’s an 07 Accord EX-L with the 2.4 engine. 167,000 miles. Check engine light is on.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
Re: 07 Accord 2500rpm shudder [Re: aquariuscsm] #5418145 05/01/20 10:45 AM
Z
zfasts03 Offline
Z
Step 1: Read codes with scan tool.
Step 2: Reset codes
Drive. If it persist or returns go to step 3.
It may be a rev limiter that is imposed by the computer due to the fault.
Step 3: Research code, evaluate what failed (part, wire, etc.)
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
Re: 07 Accord 2500rpm shudder [Re: aquariuscsm] #5418146 05/01/20 10:46 AM
B
Brybo86 Offline
B
Cel code would be a place to start......
Did you read YouTube comments ?
OP of video says air filter was completely plugged
He changed it and problem hasn't come back.......
12 Honda Odyssey 112k
09 Kymco Super8
08 Honda Accord 2.4L 164k
01 Kymco People 50
95 Yamaha Jog
Re: 07 Accord 2500rpm shudder [Re: aquariuscsm] #5418147 05/01/20 10:47 AM
M
mk378 Offline
M
Whenever a check engine light is on, get the code.
On the older models with timing belts, if the belt skips back a tooth it won't rev over about 3000, but that is unlikely with a chain.
Re: 07 Accord 2500rpm shudder [Re: aquariuscsm] #5418151 05/01/20 10:53 AM
A
A
I told him to run to AutoZone and have them read the codes for him.
Re: 07 Accord 2500rpm shudder [Re: aquariuscsm] #5418152 05/01/20 10:54 AM
B
Brybo86 Offline
B
Tell him to look at the air filter
09 Kymco Super8
01 Kymco People 50
95 Yamaha Jog
Re: 07 Accord 2500rpm shudder [Re: Brybo86] #5418153 05/01/20 10:54 AM
A
A
Will do,thanks!
Re: 07 Accord 2500rpm shudder [Re: aquariuscsm] #5418157 05/01/20 11:00 AM
simple_gifts Offline
Of course if it is the AF, OP will have to endure being beaten with a wet noodle on BITOG.
Any chance it could be a VTEC issue like a solenoid? I'm not a honda guy.
2004 Prius; 131K; ATM
2007 Yaris 108K ATM
2006 B2300;137K;ALM
Re: 07 Accord 2500rpm shudder [Re: aquariuscsm] #5418158 05/01/20 11:00 AM
M
MParr Offline
M
My guess is something is wrong with the throttle body. The fuse or relay for the throttle body or the throttle position sensor. My bet would be the throttle position sensor. This needs to be confirmed by scanning the codes. Check the air filter.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Pro OE LL IV 0W20 & OE VW
2020 F-150 STX Super Cab 2WD 2.7 Ecoboost. FF & OE filter
Re: 07 Accord 2500rpm shudder [Re: mk378] #5418161 05/01/20 11:07 AM
M
mightymousetech Offline
M
It is very common on these K series motor with the chain to jump teeth. Normally happens on cars that burn oil and the oil level is allowed to run low.
Mighty Mouse Tech
BMW Diagnostic and Alignment Tech
2013 BMW 135i M Sport Edition PPE 5W40 MTL/MT-LV
2010 BMW 328i X-Drive, PPE 5W40 MT-LV
Re: 07 Accord 2500rpm shudder [Re: mightymousetech] #5418164 05/01/20 11:17 AM
Chris Meutsch Offline
This most likely is it. I'm at 285K but my oil levels are normally never below 1/2 quart low.
My mechanic friend told me two years ago to "take care of that timing chain."
2016 Toyota 4Runner Trail Premium, 58k
*RIP* 2005 Honda CR-V EX, 284k
Re: 07 Accord 2500rpm shudder [Re: MParr] #5418172 05/01/20 11:33 AM
B
Bjornviken Offline
B
This i would check first
Re: 07 Accord 2500rpm shudder [Re: aquariuscsm] #5418175 05/01/20 11:38 AM
stockrex Offline
Clogged EGR? I had similar shudder at lower RPM due to clogged EGR.
Ridgeline, Dmax, Ford 3.5
Oil Whisperer!*Fear the DINO*
Re: 07 Accord 2500rpm shudder [Re: aquariuscsm] #5418183 05/01/20 11:46 AM
A
A
When he eventually gets back with me,I’ll post what he found out.
Re: 07 Accord 2500rpm shudder [Re: aquariuscsm] #5418215 05/01/20 12:14 PM
M
mattd Offline
M
Is this a trick question? Have the codes read and go from there
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
