Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
BMW N55 Recommendations
by BSchmidt25 - 05/29/20 10:21 AM
Castrol / Mobil 1 blend?
by mbres2000 - 05/29/20 09:40 AM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
55 registered members (928, Arcoril, AZjeff, 77GrandPrix, 4WD, 2003f7, 7 invisible), 1,556 guests, and 37 spiders.
Topics306,029
Posts5,285,221
Members71,566
Washer/Dryer Tuneup #5417531 04/30/20 04:32 PM
coopns Offline OP
On year two of our washer/dryer. We didn't get the warranty. No problems but does or do you recommend getting them serviced?
I had cheap ones for a lot of years and they charge 125 for a visit so I figured I could get 3 / 4 years out of them and buy another.
Ones I have now are decent.
Probably just like everything, they could use some tightening/adjusting?
Just chattin' here.
Coop
Re: Washer/Dryer Tuneup [Re: coopns] #5417538 04/30/20 04:44 PM
Malo83 Online Content
Online Content
We have Sear Home Service for warranty protection on both washer and dryer, in the 12 years of service we've had 2 calls on the dryer and 1 call on the washer, pay once a year with no additional charges.
https://www.searshomeservices.com/
Re: Washer/Dryer Tuneup [Re: coopns] #5417539 04/30/20 04:44 PM
Colt Offline
I just leave the machines alone.
'19 Lincoln MKC Reserve Factory 5w30 Motorcraft Synthetic Blend
'19 Ford Ranger Lariat Crew Cab 5w30 Motorcraft Full Synthetic
Re: Washer/Dryer Tuneup [Re: coopns] #5417542 04/30/20 04:46 PM
CT8 Offline
What would be serviced on a washer and dryer ?
2015 F150 2.7
2018 F350 6.2
Re: Washer/Dryer Tuneup [Re: coopns] #5417546 04/30/20 04:50 PM
P
PandaBear Offline
P
For newer machine with fancy water saving features or front loader, just throw it away when it die.
For old fashion top loader build in the 90s and earlier, repair as needed by yourself. Calling someone and then tell you it is not fixable or cost more to fix is not a good idea.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Washer/Dryer Tuneup [Re: CT8] #5417547 04/30/20 04:51 PM
P
PandaBear Offline
P
Seals that leak, pump that leaks, bearing that got worn through, switch that broke, timer that broke, fuse that burnt out, etc. When I tore apart my dryer to fix the stuck bearing I replaced all wearable parts like the plastic glide, bearing, belt, etc.
Only use OE or FSP parts, not the no name Chinese parts (they barely last 1 year).
Re: Washer/Dryer Tuneup [Re: coopns] #5417576 04/30/20 05:39 PM
B
BISCUT Offline
B
I built my home 16 years go. The original washer and dryer were Whirlpool front loaders. The dryer is still going strong. Washer is on #2. So far so good. It's me with 3 kids. We do about 6 loads a week. I do have gas for the dryer. I have nothing to do with Whirlpool. Hope this helps.
2015 F150 Lariat M1 5-30 EP FRAM Ultra(46k)
2017 Sub OB M1 5-30 EP FRAM Ultra(76k)
Re: Washer/Dryer Tuneup [Re: coopns] #5417586 04/30/20 05:49 PM
M
mclasser Offline
M
Had a 15 yr old Maytag front load washer crap out once. Other than that, had to replace a heating element on a Kenmore dryer. Only maintenance we do is clean out the lint screen.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Washer/Dryer Tuneup [Re: coopns] #5417610 04/30/20 06:12 PM
B
BAJA_05 Offline
B
Never heard of a tune up on a washer/dryer -- I must be way to old school. LOL
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (42K)
2008 Acura TL 3.2L PPHM 0W20 & FU (117K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: Washer/Dryer Tuneup [Re: coopns] #5417613 04/30/20 06:16 PM
A
Aredeeem Offline
A
Coop I’ve never done pm on any washer/dryer I’ve had. Just repairs on a as needed basis. On a washer I would scrap the hoses that come with the unit and upgrade to braided ones. The dryer needs a clean lint filter before each use and the exhaust ductwork needs to be cleaned periodically. It’s just my wife and I now. It’s amazing how long appliances last when you have don’t have kids around.
Re: Washer/Dryer Tuneup [Re: coopns] #5417637 04/30/20 06:45 PM
A
Alfred_B Offline
A
Follow the maintenance schedule in the owner's manual.
Re: Washer/Dryer Tuneup [Re: coopns] #5417640 04/30/20 06:45 PM
samven Offline
Go buy one of the long flexible dryer vent brushes, clean the vent filter and run the brush through the vent tube. Check to see if your washer has a filter, usually at the bottom behind a small door. If it does open that drain and clean the filter with some white vinegar and rinse in clean water. Check your hoses to the washer if they are the bare rubber type or do yourself a big favor and replace them with the type that have the metal mesh around them. Thats about all there is to it. Other than going out to pick up the hoses and brush it should take about 15-30 min. and cost less with new hoses than the call out fee for a service tech.
Re: Washer/Dryer Tuneup [Re: PandaBear] #5417667 04/30/20 07:16 PM
H
hallstevenson Offline
H
Those are repairs, not "service". The OP means servicing as in 'preventative maintenance'. Unless you are suggesting that people should replace seals, bearings, switches, etc on a routine basis "just in case".
Re: Washer/Dryer Tuneup [Re: coopns] #5417678 04/30/20 07:25 PM
J
JeffKeryk Offline
J
Plugs points and condenser. Air filter. All good.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Washer/Dryer Tuneup [Re: coopns] #5417701 04/30/20 07:41 PM
CatCam2 Offline
Laughable ho many people throw away front load washers when it is an easy $40-$50 fix. Front loaders don't have a transmission they have a rotor assembley and the rotor gear strips after years of use - easy fix, takes about 20 minutes IF you DON"T know what you are doing and follow a YouTube video!
