Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
rorty, Ghosty, zmann96, yetti96, weekendwally
71602 Registered Users
51 registered members (BLND1, bsmithwins, Aero540T, BrianF, BlakeB, 3 invisible), 1,372 guests, and 31 spiders.
Topics306,113
Posts5,287,769
Members71,602
Nissan Sentra - 2 different caliper bolts? #5417370 04/30/20 01:50 PM
F
Fitz98 Offline OP
F
I did a pad and rotor change on the front of my 2004 Nissan Sentra 1.8L. Pretty easy and straight forward, but I did find it a little unusual that there were 2 different caliper bolts (one of each on each side).
1 has a rubber insert on the shaft of the slide pin and the other has just a plain steel shaft with a flat surface machined on part of the shaft.
Anyone have any idea why they are different?
Does it matter whether the one with the rubber insert goes on the top or the bottom of the caliper
[Linked Image]
Re: Nissan Sentra - 2 different caliper bolts? [Re: Fitz98] #5417400 04/30/20 02:11 PM
T
Trav Offline
T
The rubber is a vibration damper, it goes on top from what I can tell. That bottom pin looks like crap, replace it and lube the new one(s) with silicone based lube.
Re: Nissan Sentra - 2 different caliper bolts? [Re: Fitz98] #5417455 04/30/20 03:04 PM
M
Miller88 Offline
M
I had to do brake pads on my Subaru and noticed the same thing. The scary thing is I had everything apart when I first got the car and didn't notice that. Oh well.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Nissan Sentra - 2 different caliper bolts? [Re: Fitz98] #5417474 04/30/20 03:30 PM
Z
zzyzzx Offline
Z
I have also seen this before. Not sure if it was a Ford, Toyota, or Dodge though.
Re: Nissan Sentra - 2 different caliper bolts? [Re: Fitz98] #5417495 04/30/20 03:58 PM
Donald Offline
Put it back in the hole it was in. Clean out the holes and wipe the pins clean. Any rust or pitting replace. Don't go overboard with Syl-guide grease.
The pin with the rubber sleeve may not slide in easily. I assume between rubber and grease there is air locked at the bottom of the hole. I put the caliper bracket in a vise and slowly use the vise to push in the pin with rubber sleeve.
2015 Ford F-250 w/Powerstroke
Re: Nissan Sentra - 2 different caliper bolts? [Re: Fitz98] #5417502 04/30/20 04:09 PM
J
JeffKeryk Offline
J
On Hondas the rubber tipped slider goes on the bottom.
The bad one goes in the trash.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Nissan Sentra - 2 different caliper bolts? [Re: Fitz98] #5417512 04/30/20 04:16 PM
J
JTK Offline
J
Yeah, the Hondas, Subarus and I thought Nissans I've had, the rubber grommet one went in the lower hole. You probably wouldn't notice the difference if it went in the wrong hole. shocked
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Nissan Sentra - 2 different caliper bolts? [Re: Fitz98] #5417518 04/30/20 04:20 PM
R
Rand Offline
R
on my subaru(s) the rubber one is on bottom.
Re: Nissan Sentra - 2 different caliper bolts? [Re: Fitz98] #5417651 04/30/20 06:54 PM
R
ragtoplvr Offline
R
If you look at the hole with a strong light you should see witness marks from the rubber.
Rod
Re: Nissan Sentra - 2 different caliper bolts? [Re: JeffKeryk] #5417671 04/30/20 07:22 PM
H
hallstevenson Offline
H
Yes, it matters (well, sorta). If you want to put it where it belongs, you'll probably need to consult a factory service manual. On '08-'10 Accords, Honda put out a tech document reiterating which position the rubber bushed pin goes because in the wrong position, it was causing excessive brake pad wear.
That presumes it was in the correct position when the OP removed it.
That's not correct across the board. I checked for various Hondas we have or have had and it varies across models, if it's the front or rear brakes, etc.
Re: Nissan Sentra - 2 different caliper bolts? [Re: JTK] #5417752 04/30/20 08:43 PM
Carbuff Offline
I mixed up the ones in the rear of our '06 CR-V when the car was one year old.
So, I put the rubber one on the bottom on one side, and on the top, on the other side.
The V has 188,000 miles on it now, still stops fine.
crazy
Atwell Haines
NJ
Re: Nissan Sentra - 2 different caliper bolts? [Re: Fitz98] #5417901 05/01/20 02:55 AM
Char Baby Offline
I noticed that when I removed my factory caliper bracket bolts, the rubber grommet was at either the top or the bottom. So, I don't think it matters where they go. They didn't seem to care at the factory where they put'em.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Nissan Sentra - 2 different caliper bolts? [Re: Carbuff] #5418000 05/01/20 07:32 AM
supton Offline
crazy
Trav said it was for vibration dampening, so it's not a critical part of the braking system.
IMO this is one of those cases where they should have used a different thread pitch or hole diam, so that it'd be impossible to install wrong. When it matters, just make it impossible to screw up--I get it, ya should go by the manual, but some things are not rocket science, we'd expect to have to RTFM when assembly an engine, but not for a plain jane caliper.
Then again, as Carbuff points out, swapping is probably of little consequence, so shrug
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: Nissan Sentra - 2 different caliper bolts? [Re: Fitz98] #5418056 05/01/20 09:10 AM
J
JeffKeryk Offline
J
I suggest referring to the service manual. That's what I did when I mixed 'em up while cleaning the old grease.
2018 Lexus RX450h
2006 Acura TSX
Re: Nissan Sentra - 2 different caliper bolts? [Re: Fitz98] #5418224 05/01/20 12:24 PM
F
Fitz98 Offline OP
F
I downloaded a manual online.
It does not differentiate between the 2 pins or the location.
I called the dealer and they have the same part number for both pins (22.00 each), which would mean they are both the same.
For lubrication, the manual shows silicone based grease on the shims and rubber grease on both pins. I just used Permatex synthetic green brake grease on all sliding parts.
I think at this point, I will just have to assume the location of the one with the rubber does not matter.
I had the brakes serviced by someone else previously, so no guarantee the position is as it was from the factory.
I did not pay attention to driver's side, so it is a 50/50 chance it is in the same position as removed. The passenger side pin with the rubber sleeve was removed from top and reinstalled in same position.
