Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
Two Motorcraft FL400S Filters Cut Open
by HX520W - 06/05/20 04:36 PM
VIN character that designates engine
by grampi - 06/05/20 04:35 PM
Two WIX 57356XP Filters Cut Open
by HX520W - 06/05/20 04:17 PM
Blue lights on Uber vehicles
by John_Conrad - 06/05/20 04:08 PM
2015 RAM EcoDiesel 3.0L, 5,354mi, M1 TDT 5w40
by SavagePatch - 06/05/20 03:18 PM
2014 5.7 Charger UOA
by Bob D - 06/05/20 02:42 PM
Mazda 3 1.6 DV6C UOA Low TBN Qeustion
by mossietheno1 - 06/05/20 01:59 PM
CRJ-550
by dja4260 - 06/05/20 01:46 PM
Aluminum Welding Question
by George7941 - 06/05/20 01:21 PM
Will 0w40 be good for next winter?
by mahanddeem - 06/05/20 01:21 PM
Motor Oil Saver less than 10.00 shipped
by cknight49090 - 06/05/20 12:27 PM
Taking my kid fishing
by Quattro Pete - 06/05/20 12:22 PM
LouK2, Michael328i, tyman, Knot_A_Mekanik, Matts59
71615 Registered Users
99 registered members (4WD, 830Lee, 28oz, 01rangerxl, 2010Civic, 2004tdigls, 15 invisible), 1,821 guests, and 25 spiders.
Topics306,264
Posts5,289,254
Members71,615
Chrysler a904 fluid type #5417206 04/30/20 10:46 AM
M
mpack88 Offline OP
M
So I'm noticing ON various forums by many people using different fluids for a Chrysler A904 tranny. Mine is a model with a lockup converter. They dipstick says use Dexron. I know many people argue on this some say use the ATF+4 some says you can use Dexron 6 some people even use type f for a firmer feel. Heck I might just stick some MerconV in it. I'm probably just going to use a DEX Merc mix and call it a day but what other fluids have y'all use in these things?
Re: Chrysler a904 fluid type [Re: mpack88] #5417210 04/30/20 10:50 AM
R
ragtoplvr Offline
R
Type f will normally chatter on lock up. Dex 3 works well. If you have some chatter, put in some lube guard red. only brand I trust.
Rod
Re: Chrysler a904 fluid type [Re: mpack88] #5417212 04/30/20 10:54 AM
Z
zrxkawboy Offline
Z
I would use any name brand Dex/Merc.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Chrysler a904 fluid type [Re: mpack88] #5417232 04/30/20 11:13 AM
O
oilboy123 Offline
O
I have used Amsoil ATF which is universal, in Ford Mercon, Mercon V, Dexron II, and Chrysler ATF+4 with good results.
“Loyalty to country ALWAYS. Loyalty to government, when it deserves it.”
― Mark Twain
Re: Chrysler a904 fluid type [Re: oilboy123] #5417236 04/30/20 11:19 AM
M
mpack88 Offline OP
M
Should I do a complete flush if I was to say use atf+4? Will it mix with whatever is in the converter?
Re: Chrysler a904 fluid type [Re: mpack88] #5417334 04/30/20 01:02 PM
sloinker Offline
A904 is a Torqueflite derivative and they plain don't care what kind of fluid is used. Dexron is suggested but in cold climates you can use up to 50% kerosene according to my owners manual for a '60s torqueflite. Buy what's on sale and don't worry about mixing.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Chrysler a904 fluid type [Re: sloinker] #5417386 04/30/20 02:04 PM
M
mpack88 Offline OP
M
I would think with synthetic lubricants kerosene wouldn't be neccessary. Lol thata crazy. I guess if it works. I think I'm sticking with dex/merc. Now I need to learn how to adjust the bands.
Re: Chrysler a904 fluid type [Re: mpack88] #5419250 05/02/20 03:14 PM
Scuder Offline
Factory service manuals are available for free download at mymopar.com.
There may not be one new enough to cover your exact application of a lockup, but I'm certain you can find one that details the band adjustment of a A904.
http://www.mymopar.com/index.php?pid=109
2019 Jeep Compass
2009 Pontiac Vibe
1968 Barracuda Formula S 340
Re: Chrysler a904 fluid type [Re: Scuder] #5419827 05/03/20 09:41 AM
M
mpack88 Offline OP
M
Thank you sir. coffee
Re: Chrysler a904 fluid type [Re: mpack88] #5419904 05/03/20 11:23 AM
Scuder Offline
You're welcome. If you find the illustrations too dark, send me a PM, and I'll send you the pages from the 1968 manual.
2019 Jeep Compass
2009 Pontiac Vibe
Re: Chrysler a904 fluid type [Re: mpack88] #5420463 05/04/20 03:57 AM
L
Lubener Offline
L
ATF+4 is specified for your A904 transmission, not DEX 6.
The "thinking" man's friend.
Re: Chrysler a904 fluid type [Re: Lubener] #5420830 05/04/20 01:56 PM
M
mpack88 Offline OP
M
I understand that. Understand when my a904 was made, it was using Dex3. In general motors world DeX 6 supersedes all previous DeX specifications (saturn the one exception). So I dont think it would be incorrect or harmful to put DeX 6 in my a904. I bet dex6 and atf+4 are probably similar but I'm not a chemist or want to spend the money to find out. Seems to me from what I've read a904s and a727 can take about anything.
Re: Chrysler a904 fluid type [Re: mpack88] #5421412 05/05/20 07:49 AM
L
Lubener Offline
L
Your A904 likely saw Dex 2 as its original fill. Chrysler had a TSB indicating to use ATF+4 to replace Dexron and AFT+3 in its transmissions as it was backward compatible for older transmissions. Dex 6 is thinner than most fluids and may create harsh shifts. I would research and go with what Chrysler says not what GM is suggesting, which would apply to their transmissions.
Re: Chrysler a904 fluid type [Re: mpack88] #5422081 05/05/20 09:09 PM
M
mpack88 Offline OP
M
True that. Since it is a thinner fluid, couldn't it create hard shift in GM transmissions that was superceded by dex6? I'm probably going to use dex/merc since its tried and true and closer to what the factory fill was. If it shutters I'll put a shutter fix in it. If the trans was a new unit, I'll put atf+4 in it.
