Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
rorty, Ghosty, zmann96, yetti96, weekendwally
71602 Registered Users
50 registered members (bdcardinal, Ag76, 10WSmuckers, BlakeB, BLND1, 4 invisible), 1,285 guests, and 40 spiders.
Topics306,113
Posts5,287,775
Members71,602
Best adhesive to attach back panel to peninsula cabinets? #5417063 04/30/20 07:57 AM
J
JLawrence08648 Offline OP
J
I've just installed 3 peninsula base cabinets with doors on one side. The other side is thin material that I have glued 1/2" plywood in between the screw stringers using Fuze-It.
I have a thin, 4-4.5mm, matching panel, looks like compressed paper, that I need to adhere then this will have 3 door panels glued and tacked. The door I was thinking of using Fuze-It or a H.D. Construction tube adhesive. The panel I was thinking rolling on contact cement. Googling, some use 3M High Strength spray adhesive. I was going to use long strips of 3/4" plywood screwed through the back panel in to the plywood filler where the doors would go to help adhere the back panel. there's going to be one piece of corner moulding along the corner edge so I was going to tack it down there also.
Comments? Suggestions?
2019 Hyundai Santa Fe SEL Plus, 2.4
1992 Acura Vigor GS, 2.5
Re: Best adhesive to attach back panel to peninsula cabinets? [Re: JLawrence08648] #5417202 04/30/20 10:45 AM
P
PowerSurge Offline
P
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
Re: Best adhesive to attach back panel to peninsula cabinets? [Re: JLawrence08648] #5417211 04/30/20 10:54 AM
K
Kawiguy454 Offline
K
With lots of surface area anything will work well.
Re: Best adhesive to attach back panel to peninsula cabinets? [Re: JLawrence08648] #5417290 04/30/20 12:36 PM
Dave9 Offline
A picture might help, but it is unlikely that you need "best" just some cost effective construction adhesive, and any spray or slow set brush on for any paper thin faux.
Re: Best adhesive to attach back panel to peninsula cabinets? [Re: JLawrence08648] #5417344 04/30/20 01:24 PM
samven Offline
Avoid the 3M spray adhesive. I have used it on cork panels and it worked great for about a year, then corners started to let go and even after retacking them they would slowly start to separate. It is great for paper thickness stuff to hardboard but not anything that can apply even the smallest pull over time.
