Which oil is the better quality
by galaxy333 - 06/01/20 09:57 AM
"Boutique" Brands
by buster - 06/01/20 09:15 AM
CASTROL Edge 5w20 or EP 5w20
by 53' Stude - 06/01/20 09:09 AM
BT Oil
by js1956 - 06/01/20 09:00 AM
How to Properly Read a Dipstick
by Gebo - 06/01/20 07:59 AM
Why did some older cars have + grounded systems?
by JLawrence08648 - 06/01/20 07:39 AM
Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
C6H8O7, Jcvjr, Haywood, ToOliwer, AbbeyRoad
71588 Registered Users
103 registered members (330indy, 1978elcamino, 00celicagt, 830Lee, 87sammy, 14Accent, 7 invisible), 2,185 guests, and 20 spiders.
Topics306,118
Posts5,286,833
Members71,588
Page 1 of 3 1 2 3
Timing Belt Change Intervals #5417054 04/30/20 07:45 AM
G
Gebo Offline OP
G
Cars have a mileage and a time interval for changing timing belts on our older cars. 90k or 10 years, 80k or 7 years, etc.
With, what I am understanding, this new fangled rubber compounding has there been any change in these intervals?
"Originally Posted by Boomer
Looks like it is made from hydrogenated nitrile butadiene rubber....very oxygen and oil resistant material."
My understanding is more timing belts break due to time versus mileage. If that is the case,
how long do you go before changing your timing belts? Time wise.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Timing Belt Change Intervals [Re: Gebo] #5417066 04/30/20 08:01 AM
paulri Offline
The manual often will have something. If not, I posted this hear a while back and was directed to the OE for the belt itself. Gates had big text on the manual that i downloaded, saying 6 years was it for every belt. But my mechanic & Honda also IIRC said 7 years.
To see what others say about the composition of belts, I'll definitely follow this thread.
2005 Toyota Sienna LE; 171,000 miles
2006 Toyota Highlander Hybrid 136,000 miles
Re: Timing Belt Change Intervals [Re: Gebo] #5417067 04/30/20 08:06 AM
G
Gebo Offline OP
G
Please note that my understanding is they are now making belts with a much "tougher" rubber. IDK???? shrug
Not being a smarty pants, but to stave off potential sniper attacks, I do have all my manuals and they all have mileage and time change intervals.
I am wondering if things have changed since 1998.
Thanks Paulri, I'll search your posts.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Re: Timing Belt Change Intervals [Re: Gebo] #5417078 04/30/20 08:23 AM
B
benjy Offline
B
extending timing belt + related parts can cost thousands, diy prolly 3 to 5 hundred, "do you feel lucky punk" many owners are penny wise but dollar foolish IMO!!!
Re: Timing Belt Change Intervals [Re: benjy] #5417082 04/30/20 08:29 AM
G
Gebo Offline OP
G
That’s not what I am trying to do. I assure you. grin
I’m a 3-5k OCI guy. Just wondering....
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Re: Timing Belt Change Intervals [Re: Gebo] #5417095 04/30/20 08:45 AM
supton Online Content
Online Content
I go by the book. Nothing I own is that old; nothing I own sits that much that it'd time out. Well, pre-pandemic that is.
I know the materials have gotten better but the change interval seems stuck. I'm not sure why. I don't know if it's
-belts actually haven't gotten any more "durable" in the last 20 years
-the items around them, like rollers, tensioners, etc are actually the failing points
-the items have gotten better but the loading (from more camshafts with more aggressive lift, or similar problems) has also gone up, leading to a sum zero game
-the OEM's have tracked this and have found that as a system, random failures happen just too often, and with too much expense on the line, that it's just better to be conservative on an item that is probably only ever going to be done once (on the majority of vehicles)
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: Timing Belt Change Intervals [Re: Gebo] #5417104 04/30/20 09:04 AM
N
nobb Offline
N
On my Toyota 4Runner with a non interference 3.4L engine, the interval is 100,000 kms. However, last time I did it, the belt still looked mint. No cracks, no major wear, it looked amazing. I really have no problems delaying it to 200,000 km. I would use OEM parts and replace all surrounding components such as the water pump, seals, idlers, etc... However since this is already an old truck I don't see myself keeping it long enough for the next change.
Re: Timing Belt Change Intervals [Re: Gebo] #5417110 04/30/20 09:09 AM
B
BigCahuna Offline
B
I've had a belt break on my wife's old Kia Sportage. It was not the belts fault, it was ours. The owners manual said to change it at 60k miles. When it broke, our car has about 104k on it. We probably forgot about changing it, I'm sure were not the only ones. Luckily, our's was NOT a interference motor. We replaced the belt ( $40), and fired it up before we put it all back together, and it ran fine. We were going down the highway at about 65 mph when it just stopped running. I'm sure the mfgrs know how long these belts will last, but figure they will not always be changed on time, so some fudge time is built in. And they don't want a rep for building time bombs if not changed on time.,,,
Re: Timing Belt Change Intervals [Re: Gebo] #5417113 04/30/20 09:11 AM
svhanc Offline
On an interference engine it probably isnt worth squeezing an extra year out of it unless the car is at the point of diminishing returns.
2010 Toyota Tacoma 4x4 2.7 5spd ([email protected]&Fram [email protected])
2001 Jeep Cherokee XJ 4.0 Auto ([email protected]&Fram [email protected])
2007 Suzuki SV650N
Re: Timing Belt Change Intervals [Re: BigCahuna] #5417132 04/30/20 09:30 AM
paulri Offline
Do you remember how old the car/belt was, at 104K?
Re: Timing Belt Change Intervals [Re: nobb] #5417134 04/30/20 09:31 AM
B
Bottom_Feeder Online Content
Online Content
B
My 2001 Impreza was the same way. I believe the manual said the change interval was something like 7 years or 105k miles, and mine was done around 12 years and 90k miles. I had visions of the original belt being cracked and shredded and worn, and I was hoping to Xenu that it wasn't going to grenade the next time I was on the highway in the middle of nowhere. Well, come replacement time the OEM Mitsuboshi-made belt looked great. I know timing belts wear out more on the 'inside' but I would have felt fine going another 2-3 years on it had I no already bought the timing kit.
Re: Timing Belt Change Intervals [Re: Gebo] #5417177 04/30/20 10:19 AM
sohccammer427 Offline
The interval has really increased over the years. I remember when 100,000 miles was considered a long interval. Now...
2015 VW Passat Tdi 130,000 mile interval
2017 Colorado 2.8l Durmax 150,000 interval
2015 VW Passat TDi 6 Speed Manual
2017 Colorado Duramax
Re: Timing Belt Change Intervals [Re: Gebo] #5417182 04/30/20 10:28 AM
SubieRubyRoo Offline
Subaru is 105,000 miles or 105 months on the EJ25s, which works out to 8.75 years. Which is part of the reason almost every used Subaru is sold just short of 105k mile intervals, i.e. 95-100k, or 195-200k. 100k for the change interval is a nice, safe, easily remembered interval.
De omnibus dubitandum.
Re: Timing Belt Change Intervals [Re: Gebo] #5417184 04/30/20 10:28 AM
PimTac Offline
It’s not new. It’s been around for quite some time. 🙄
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Timing Belt Change Intervals [Re: Gebo] #5417187 04/30/20 10:31 AM
G
Gebo Offline OP
G
What do you mean”quite some time”?
I’m thinking more than 10 years. Is that what you are saying?
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Page 1 of 3 1 2 3
