Hailstorm Yesterday
by Delta - 06/05/20 04:47 AM
Date code on Mighty Engine Guard II? Air Filter
by blufeb95 - 06/05/20 01:01 AM
My poor Jetta can't catch a break.
by FordBroncoVWJeta - 06/05/20 12:22 AM
Bought a truck finally, warning no Ford content
by bdcardinal - 06/04/20 11:31 PM
Got a septoplasty today....
by daves66nova - 06/04/20 10:44 PM
2020 330i xDrive Loaner
by MCompact - 06/04/20 10:02 PM
Appliance repair?
by motor_oil_madman - 06/04/20 09:44 PM
Glad we got a seasonal RV site
by Pat in Speedway - 06/04/20 09:19 PM
Mobil 1 AP Clearance at Wal-Mart
by KeithS_NW_Ohio - 06/04/20 09:07 PM
Recent experience with a Michelin Defender
by FordSVTGuy - 06/04/20 08:46 PM
music quality of speakers in the 70's vs now
by raaizin - 06/04/20 08:15 PM
pressure washer care
by raaizin - 06/04/20 08:06 PM
Watch Forums?
by maverickfhs - 06/04/20 07:53 PM
Who has a media/sand blast cabinet?
by spasm3 - 06/04/20 07:39 PM
Why isn't Polyethylene Glycol standard?
by RamFan - 06/04/20 06:37 PM
Motorcraft GF-6 at Quick Lane.
by Gene K - 06/04/20 06:29 PM
OEM Honda wiper blade curvature
by mclasser - 06/04/20 06:24 PM
GDI vs. MPFI OCI's
by LubricatusObsess - 06/04/20 06:19 PM
Mobil “full synthetic”
by 53' Stude - 06/04/20 06:01 PM
1992 Ford Ranger Brake Fluid Type
by yeehaw1960 - 06/04/20 04:21 PM
Jettero, stubby73, Polkaman, Ramboagain, tekfire07
71609 Registered Users
35 registered members (bullwinkle, Amkeer, BBC_bias, 1911CHAMPION, bachman, CB900F2, 5 invisible), 763 guests, and 28 spiders.
Topics306,229
Posts5,288,659
Members71,609
Page 1 of 7 1 2 7
Does the sulfated ash (SA) level really matter for intake-valve deposits (IVD)? #5417037 04/30/20 07:09 AM
G
Gokhan Offline OP
G
I will argue that the sulfated ash (SA) level -- that is the metal content of an oil -- does not matter for intake valve deposits (IVD) in gasoline direct-injection engines.
The IVD is mostly composed of coked base oil with ash (metal) additives that doesn't evaporate. It also contains some exhaust particulates (from EGR) etc.
However, since the primary building block of the IVD is coked base oil, how much would the SA level really make a difference? The base oil makes roughly 80% of the oil, whereas the ash is only about 1%. Therefore, I will argue that since the IVD is mostly coked base oil, the ash level has a small effect.
In order to combat the IVD, the following all help:
(1) Higher-quality base oils, such as PAO and POE, or the poor-man's higher-quality base oils such Group III+ and GTL.
(2) More antioxidant to reduce the oil coking.
(3) More or better detergent and dispersant to keep things clean.
(4) More POE or AN to increase the solvency of the oil, which could loosen up some of the coked oil.
There doesn't seem to be any research on this other than a faulty Lubrizol field study that compared a superior (Euro IV) low-SAPS oil to an inferior (Euro III) full-SAPS oil, which obviously favored the Euro IV oil, regardless of the SAPS. Any thoughts?
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 65 mpg on regular gasoline, ~ 5,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: Does the sulfated ash (SA) level really matter for intake-valve deposits (IVD)? [Re: Gokhan] #5417038 04/30/20 07:17 AM
B
buster Offline
B
Those are good points. The oil that ends up coming in contact with the valve, has to be able to resist coking on to the valve. The (4) things you listed would all help that. I'm not aware of any testing for IVD's at this point.
Your top tier oils will likely be the best choices. Driven DI oils are mostly PAO, some Group III and a little bit of ester. Amsoil is PAO with what appears to be a good slug of V. Mobil 1 is majority PAO/AN (EP/AP). I'm surprised by the Driven oils base oil composition. However, I don't know the %'s so I'm not sure. I do know the SA is .722 for that oil line. Driven still mentions Noack as being important, but their 0w20 is 11% where as M1 AP is 8.9% and Amsoil is 8.5%.
Would the ExxonMobil High Temp Oxidation test be indicative of what would happen on an intake valve?
[Linked Image]
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: Does the sulfated ash (SA) level really matter for intake-valve deposits (IVD)? [Re: Gokhan] #5417041 04/30/20 07:20 AM
spasm3 Offline
So how important do you see noack? Is that a good measure of the base oil?
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Does the sulfated ash (SA) level really matter for intake-valve deposits (IVD)? [Re: Gokhan] #5417047 04/30/20 07:32 AM
B
BMWTurboDzl Offline
B
On what basis is the 10-15 yr old Lubrizol study faulty based upon the technology available at the time?
What do you continue to believe that intake deposits are a problem across the entire population?
Does this question really matter at ALL?
No. Frankly it's entirely irrelevant because the ACEA Cx spec was designed for emissions compliance (TWC Gas, DPF Diesel, and later GPF Gas).
435i
Re: Does the sulfated ash (SA) level really matter for intake-valve deposits (IVD)? [Re: Gokhan] #5417051 04/30/20 07:40 AM
sloinker Offline
I may be wrong but I always thought the oil chemistry for sulfated ash was to keep the particulate filter healthy.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Does the sulfated ash (SA) level really matter for intake-valve deposits (IVD)? [Re: Gokhan] #5417052 04/30/20 07:41 AM
K
ka9mnx Offline
K
I didn't find the Lubrizol study flawed. Their study was mostly centered on after treatment emissions components which is what happens above the piston and not below it. IVD is, mostly, what happens to oil below the piston. Lowering SAP's started in the 90's to mitigate polluting cat converters.
It was proven in a study, which I failed to download and save and cannot seem to find, that the majority of IVD was caused by drivers going too long on oil change intervals and low quality oil not specified by the manufacturer.
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Does the sulfated ash (SA) level really matter for intake-valve deposits (IVD)? [Re: Gokhan] #5417070 04/30/20 08:10 AM
N
NYSteve Offline
N
Gokhan and Buster or anyone else...what are your thoughts on Redline 5w-30 Euro Series?
Link: https://www.redlineoil.com/euro-series-5w30-motor-oil
Specs:
TYPICAL PROPERTIES
ACEA Service Class C3
API Service Class SN/SM/SL/CF
SAE Viscosity Grade (Motor Oil) 5W30
Vis @ 100°C, CSt 11.6
Vis @ 40°C, CSt 69
Viscosity Index 164
CCS Viscosity, Poise, @ °C [email protected]
Pour Point, °C -45
Pour Point, °F -49
NOACK Evaporation Loss,1hr @ 482°F (250°C), % 6
HTHS Vis, CP @150°C, ASTM D4741 3.7
Re: Does the sulfated ash (SA) level really matter for intake-valve deposits (IVD)? [Re: Gokhan] #5417072 04/30/20 08:12 AM
B
buster Offline
B
^that's a nice oil. I actually forgot RL made a Euro oil with lower SA. If only they made their PCMO line like this. Their top tier oils still contain high amounts of Ca which isn't good for LSPI, although some say esters and moly counter that.
Re: Does the sulfated ash (SA) level really matter for intake-valve deposits (IVD)? [Re: ka9mnx] #5417121 04/30/20 09:21 AM
G
Gokhan Offline OP
G
The part about claiming low-SAPS reduces IVD over full-SAPS is flawed because they are comparing an inferior Euro III full-SAPS oil to a superior Euro IV low-SAPS oils. They are supposed to have a controlled experiment to make such a claim, in which they keep everything except SAPS constant.
I agree with the oil quality and OCI being important for IVD, as higher base-oil quality, higher base-oil solvency, higher antioxidant content, better/more detergent and dispersant, and shorter OCI all reduce oil coking and hence IVD.
Re: Does the sulfated ash (SA) level really matter for intake-valve deposits (IVD)? [Re: Gokhan] #5417135 04/30/20 09:33 AM
K
ka9mnx Offline
K
While true about the base oils in the test, again, they were not testing for IVD.E
EDIT: They did mention valve deposits briefly.
Re: Does the sulfated ash (SA) level really matter for intake-valve deposits (IVD)? [Re: Gokhan] #5417136 04/30/20 09:34 AM
4WD Offline
Well got a bunch of M1 AP, VME, and RGT at the AZ clearance … so hope you are right …
I could of bought Costco ‘synthetic’ for the same price … but I suspect they slip some EHC in that and still meet Dexos minimum standards …
Re: Does the sulfated ash (SA) level really matter for intake-valve deposits (IVD)? [Re: Gokhan] #5417160 04/30/20 09:58 AM
B
buster Offline
B
Quote
Agree. Quite surprised they did that.
Re: Does the sulfated ash (SA) level really matter for intake-valve deposits (IVD)? [Re: buster] #5417188 04/30/20 10:32 AM
B
BMWTurboDzl Offline
B
Originally Posted by buster
Quote
Proof?
Again, based upon what? What's this "inferior Euro 3"? Euro 4 oils are by definition lower SAPs no?
435i
Re: Does the sulfated ash (SA) level really matter for intake-valve deposits (IVD)? [Re: 4WD] #5417192 04/30/20 10:35 AM
B
BMWTurboDzl Offline
B
Don't take Gokhan's comment too seriously. He's straining to draw some sort of conclusion partly off what he deems a flawed study published essentially a generation ago (2006).
435i
Re: Does the sulfated ash (SA) level really matter for intake-valve deposits (IVD)? [Re: Gokhan] #5417193 04/30/20 10:35 AM
J
Jimmy_Russells Offline
J
My evidence is anectodal but after using 502 oil for twelve years in two different VW's, and now using 504 in an Audi for over two, the difference in tailpipe soot and oil color over time is huge.
Page 1 of 7 1 2 7
