Forums Migration
Please read this thread
Interesting article on "Best oil filters."
by 97prizm - 07/11/20 03:46 AM
Seafoam fuel injector cleaner
by hardcore302 - 07/11/20 01:02 AM
EP additive?
by CCI - 07/10/20 11:06 PM
Kawa FR600V Oil
by Propflux01 - 07/10/20 10:34 PM
Dexron VI for 700R4.
by jakewells - 07/10/20 10:22 PM
Picked Up the DeWalt Mid Range Impact
by Fringe - 07/10/20 09:42 PM
Checking out neighbours lawn mower
by Snagglefoot - 07/10/20 09:19 PM
TV help needed
by ffhdriver - 07/10/20 09:00 PM
FS Solar panels PU only 250w $80
by BeerCan - 07/10/20 08:29 PM
Ford Easy Fuel
by buck91 - 07/10/20 08:27 PM
Oil for the track
by lowon - 07/10/20 07:34 PM
Bought a grapple
by Ausfahrt - 07/10/20 06:30 PM
What is this charger for?
by CharlieJ - 07/10/20 05:58 PM
World War II movie Greyhound
by skyactiv - 07/10/20 05:48 PM
GC for Fuel Dilution - Accuracy
by Gene K - 07/10/20 05:21 PM
How Do I Get This On?
by Gebo - 07/10/20 05:08 PM
Creativity Suggestions?
by maverickfhs - 07/10/20 03:18 PM
3.5 Ecoboost Oil, I've decided.
by Gene K - 07/10/20 02:07 PM
SUmeme22, DaveCaddell, SharkNC, Puckster02, TurbodogTodd
71907 Registered Users
24 registered members (97prizm, Black_Thunder, farrarfan1, bmod305, alchargo, FirstNissan, 1 invisible), 588 guests, and 32 spiders.
Topics307,710
Posts5,316,221
Members71,907
What is a standard tune-up these days? #5416929 04/29/20 10:57 PM
B
bowlofturtle Offline OP
B
Let's just say standard 10-year-old car. Honda Accord and Ford Fusion. If someone asks for a 100k tune-up, what do you recommend?
- spark plugs
- serp belt
- brake and coolant flush, coolant at the very least
- A timing belt (if it has one) (Honda V6s)
I often get asked, "get my car is coming up 100k or 10 years old now, what should i get done", obviously assuming its running decent and doesn't need brakes, wheels bearings, control arms, ball joints and etc. I wanna throw the valve cover gasket in there as well. For the most part its easy simple work, i don't mind getting paid to help them do it. Other than no timing belt jobs, too much risk on my end.
Cars these days don't exactly need much to keep on running, other than just replace what is broken. But i only started driving in the early 2000s but my parent's car didn't need much work either, they had like a 88 corolla and a 94 Camry. Just oil changes every 3k.
My toys
-05 Infiniti G35x 140k
-03 Suzuki SV650N 8.5k
Maintaining
-16 Jetta 1.4T 20k
-98 Nissan Maxima 160k
-09 Toyota Camry V6 96k
Re: What is a standard tune-up these days? [Re: bowlofturtle] #5416932 04/29/20 10:59 PM
O
ondarvr Offline
O
Its typically all in the manual and addresses the exact needs for the specific vehicle.
Re: What is a standard tune-up these days? [Re: bowlofturtle] #5416935 04/29/20 11:07 PM
Dave9 Offline
I recommend that you be honest and say that cars don't need tune-ups and haven't for decades, BUT that you will do all the items that are scheduled maintenance, and anything that was already past due at a prior mileage, within their acceptance of the cost. Then it is up to you to prioritize things if they don't want to pay enough to "catch up".
No, do not throw a valve cover gasket in, that's excessive unless they are complaining about excessive leakage/smoke or you are 100% certain that there is too much oil loss there to make it reasonable to top off between oil changes.
Re: What is a standard tune-up these days? [Re: Dave9] #5416941 04/29/20 11:17 PM
B
B
Most owners manuals state things like "inspect and replace if necessary"
And I have been honest with them. Get things done when they break. But they normally ask for a small list of things/ maybe preventative maintenance items. I think the common driver feels they need to do something at the magical 100k or 10year mark other than oil changes.
My toys
Maintaining
-16 Jetta 1.4T 20k
Re: What is a standard tune-up these days? [Re: bowlofturtle] #5416947 04/29/20 11:26 PM
Dave9 Offline
I should also add that it depends on the value of the vehicle. If it's worth $20K, a bit more work is justified to keeps its value up, mitigate losses from a failure, compared to a value of $2K, etc.
Re: What is a standard tune-up these days? [Re: bowlofturtle] #5416950 04/29/20 11:42 PM
U
UG_Passat Offline
U
- spark plugs
- serp belt
100K miles, you may not require a tune-up, since spark plugs may not be due. That's why you refer to the maintenance schedule for the car, not some arbitrary internet recommendations. Yes, there is a lot of "inspections" to do.
Is a brake flush really necessary? See the VW thread on brake flushing. It may be time-based, and depends if the 100K coincides with the time or not. Coolant flush may not be needed yet. Timing belt may be at 120,000 miles, or before 100,000 miles--- again check the owner's manual not some random internet recommendation.
2016 VW Tiguan
Re: What is a standard tune-up these days? [Re: UG_Passat] #5416959 04/30/20 12:11 AM
Malo83 Offline
On my 83 Silverado with the 305 it's cap and rotor, plugs, wires if do, air filters, pcv valve, timing with computer disconnected and O2 sensor. Qjet gets sprayed over with Gumout carb cleaner and sprayed down the throats at high idle. oil and filter change. This is done every 2 yrs in order to pass the dreaded Cali smog test. crzy
Re: What is a standard tune-up these days? [Re: bowlofturtle] #5416967 04/30/20 01:16 AM
Nick1994 Offline
Modern cars don't need a tune up, things are scheduled and 100k is kind of irrelevant, as spark plugs might be due every 60k miles (so nothing due until 120k) or the coolant is every 120k miles, brake fluid every 30k etc.
I traded my 15' Sonata in last December at 108k. I didn't do a single thing to it at 100k miles, it didn't need anything.
2015 Hyundai Genesis 5.0L 63k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Rotella Gas Truck 5w30 & Wix
Re: What is a standard tune-up these days? [Re: bowlofturtle] #5416988 04/30/20 04:25 AM
PimTac Offline
Tuneups died when distributor systems went the way of the dinosaurs.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: What is a standard tune-up these days? [Re: bowlofturtle] #5417003 04/30/20 05:55 AM
K
ka9mnx Offline
K
On a 10 year old vehicle spark plus are usually 60 to 120k miles. Timing belts are usually 90 to 120k miles. Coolant can be 150k miles. My manual for the Ranger says change front wheel bearings at 120k miles. Some manuals recommend trans fluid at a certain mileage. Everything else is filled for life or inspect. This is, of course, not including severe service or driving through high water. Manufacturers are all over the place so best to check the manual. My lifetime experience dictates a schedule different from the owners manual.
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: What is a standard tune-up these days? [Re: bowlofturtle] #5417059 04/30/20 07:51 AM
sloinker Offline
100k may be time for fluid exchange in the differential(s)/transmission/transfer case, check the manual.
Re: What is a standard tune-up these days? [Re: bowlofturtle] #5417073 04/30/20 08:13 AM
caprice_2nv Offline
- spark plugs
- serp belt
I used to get asked the same thing when I was a service advisor at the garage still. The answer was always basically that spark plugs are the only real tune up item, besides possibly a throttle body cleaning if it's needed. We always recommended them by 80k-100k miles only because if you leave them in too long time wise, they can seize into the aluminum heads.
As far as the throttle body, it probably depends on the vehicle. I cleaned it on my 05 Silverado at 192k miles for the first time and it looked pretty clean prior to that. I did notice that after the cleaning the throttle percent commanded (on my torque pro app) went down from like 10% to 5%.
Wires can be considered tune up, but I wouldn't recommend them until they have a problem. My 2005 Silverado and a 2002 GMC Sierra our company had both are on the original wires with no issues.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
05 Silverado 1500 4wd - 4.8/4L60E
79 Honda CX500
Re: What is a standard tune-up these days? [Re: PimTac] #5417167 04/30/20 10:06 AM
W
Whimsey Offline
W
Darn! I miss those 12,000 mile spark plug, points, rotor, capacitor and possibly distributor cap changes. Not to mention using the dwell meter and tachometer to set the point gap and a vacuum gauge for the idle/low speed mixture wink.
Whimsey
Re: What is a standard tune-up these days? [Re: bowlofturtle] #5417190 04/30/20 10:33 AM
Z
zzyzzx Offline
Z
[Linked Image from i.redd.it]
Re: What is a standard tune-up these days? [Re: bowlofturtle] #5417311 04/30/20 12:45 PM
Y
Y_K Offline
Y
Thank you smile
“This disease making us more cruel to one another than if we are doggs.” -- Samuel Pepys 1666
