2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
Two Motorcraft FL400S Filters Cut Open
by HX520W - 06/05/20 04:36 PM
VIN character that designates engine
by grampi - 06/05/20 04:35 PM
Two WIX 57356XP Filters Cut Open
by HX520W - 06/05/20 04:17 PM
Blue lights on Uber vehicles
by John_Conrad - 06/05/20 04:08 PM
2015 RAM EcoDiesel 3.0L, 5,354mi, M1 TDT 5w40
by SavagePatch - 06/05/20 03:18 PM
2014 5.7 Charger UOA
by Bob D - 06/05/20 02:42 PM
Mazda 3 1.6 DV6C UOA Low TBN Qeustion
by mossietheno1 - 06/05/20 01:59 PM
CRJ-550
by dja4260 - 06/05/20 01:46 PM
Aluminum Welding Question
by George7941 - 06/05/20 01:21 PM
Will 0w40 be good for next winter?
by mahanddeem - 06/05/20 01:21 PM
Motor Oil Saver less than 10.00 shipped
by cknight49090 - 06/05/20 12:27 PM
Taking my kid fishing
by Quattro Pete - 06/05/20 12:22 PM
How to rebuilt a starter
by LazyDog - 06/05/20 12:11 PM
Back to work on Monday!!
by Bfrost99 - 06/05/20 11:56 AM
LouK2, Michael328i, tyman, Knot_A_Mekanik, Matts59
71615 Registered Users
94 registered members (Astro_Guy, 4WD, 2whlgeezer, 77GrandPrix, amblerman, Avery4, 10 invisible), 1,867 guests, and 70 spiders.
Topics306,263
Posts5,289,230
Members71,615
Mopar AW-1 autotrans fluid Fiat 500 #5416911 04/29/20 10:25 PM
A
awguy Offline OP
A
Anyone know of a full synthetic replacement? Can't find the spec on this Mopar AW-1 fluid and it's about $17 a quart at the dealer. I don't believe in the filled for life at the factory that Fiat claims. I'm at 65,000 miles and would like to change out several times some of the fluid. It's well over 100 degrees here and the OBDII port on the car says I'm getting up to 94*C on trans temperature. This is a 2013 Fiat 500 Sport with an engine and trans tune---autotrans.
I was thinking Mobil 1. I'm also seeing Valvoline Max-Life and LubeGard.
Confused about what's compatible for the extremely hot temps we get here.
Re: Mopar AW-1 autotrans fluid Fiat 500 [Re: awguy] #5416917 04/29/20 10:32 PM
slacktide_bitog Offline
welcome
You can use Maxlife with no problem smile
Castrol Full Synthetic is also a good choice
The Aisin transmission doesn't require anything special
If your transmission doesn't have a drain plug, get an aftermarket pan that has one. This will make future fluid changes much easier smile
Re: Mopar AW-1 autotrans fluid Fiat 500 [Re: awguy] #5416925 04/29/20 10:52 PM
CT8 Online Content
Online Content
i didn't know Fiats lasted long enough to need oil changes.
2015 F150 2.7
2018 F350 6.2
Re: Mopar AW-1 autotrans fluid Fiat 500 [Re: slacktide_bitog] #5416951 04/29/20 11:46 PM
A
awguy Offline OP
A
There’s no pan or filter but there is a drain plug (which has a small plug in that). Top of trans has a plug that uses a Torx T-55.
Okay, thought trans was special. A lot of manufacturers are not showing Mopar AW-1 on their compatibility list. A Google search doesn’t help much. Understood that only a couple quarts come out each time so I’m planning on at least two changes over a few days.
All cars last a long time if you do normal maintenance; even your Ford F-150.
Re: Mopar AW-1 autotrans fluid Fiat 500 [Re: CT8] #5417002 04/30/20 05:50 AM
I
incognito_2u Offline
I
laugh
My Brothers 2012 Fiat 500 (his DD) is well North of 140,000 miles and still pulling strong on just routine maintenance and Oil Changes!
2006 Jeep Commander 3.7 V6 -116k (M1EP5W30/XG3600)
2006 Toyota Corolla 1.8 VVTi -88k (M1EP5W30/XG3600)
1999 Toyota Corolla 1.8 -92k (PUP5W30/XG4386)
1998 Toyota Corolla 1.8 -68k (VME5W30/XG3600)
Re: Mopar AW-1 autotrans fluid Fiat 500 [Re: awguy] #5417480 04/30/20 03:39 PM
B
Bailes1992 Offline
B
Sounds like an Aisin gearbox. Any ATF that meets JWS 3324, Aisin AW-1 or Toyota WS will suffice!
19 Volvo V40 D3 - 19 Jeep Renegade eTorq - 03 Ford Mondeo 3.0 V6 - 96 LR Defender 90 300TDi
Castrol Edge 5w30 LL
Valvoline Maxlife ATF
Fuchs Sintofluid 75w80
Fuchs Sintopoid 75w90
Re: Mopar AW-1 autotrans fluid Fiat 500 [Re: awguy] #5417896 05/01/20 01:57 AM
A
awguy Offline OP
A
Ok. Thanks for the help. I’m thinking of using Valvoline Max Life. Mobil 1 ATF doesn’t give much information and hasn’t responded to my email. I’ll look into Castrol.
Re: Mopar AW-1 autotrans fluid Fiat 500 [Re: CT8] #5419397 05/02/20 07:58 PM
N
nascarnation Offline
N
A dealer tech on JRITS reddit told me if you keep up with the oil changes (to keep the Multi-Air valve mechanisms working correctly) 150,000 is quite do-able on these.
