Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
Two Motorcraft FL400S Filters Cut Open
by HX520W - 06/05/20 04:36 PM
VIN character that designates engine
by grampi - 06/05/20 04:35 PM
Two WIX 57356XP Filters Cut Open
by HX520W - 06/05/20 04:17 PM
Blue lights on Uber vehicles
by John_Conrad - 06/05/20 04:08 PM
2015 RAM EcoDiesel 3.0L, 5,354mi, M1 TDT 5w40
by SavagePatch - 06/05/20 03:18 PM
2014 5.7 Charger UOA
by Bob D - 06/05/20 02:42 PM
Mazda 3 1.6 DV6C UOA Low TBN Qeustion
by mossietheno1 - 06/05/20 01:59 PM
CRJ-550
by dja4260 - 06/05/20 01:46 PM
Aluminum Welding Question
by George7941 - 06/05/20 01:21 PM
Will 0w40 be good for next winter?
by mahanddeem - 06/05/20 01:21 PM
Motor Oil Saver less than 10.00 shipped
by cknight49090 - 06/05/20 12:27 PM
Taking my kid fishing
by Quattro Pete - 06/05/20 12:22 PM
LouK2, Michael328i, tyman, Knot_A_Mekanik, Matts59
71615 Registered Users
103 registered members (01rangerxl, 10WSmuckers, 2K2AcuraTL, 28oz, 4WD, 830Lee, 18 invisible), 1,804 guests, and 58 spiders.
Topics306,265
Posts5,289,272
Members71,615
Woohoo free snowblower! #5416711 04/29/20 06:22 PM
5
55Test Offline OP
5
Picked up a free older 26 inch Mastercraft 8hp snowblower earlier tonight. It was advertised as not running but as soon as I got it home I tried it and it will start and run for about 5 seconds then stall out. I'm guessing what happened since we had a mild winter this past season, the machine sat in someone's garage all year with E10 fuel and the carb just got gummed up. Would old-fashoined carb cleaner spray help? The machine will need some going over, the gear selector doesn't seem to want to pull back all the way and the muffler despite looking solid sounds like it's burned right out
If anyone is interested I can take pics of it tomorrow
The total sum of everything I have learned from this website: ...Oil in engine, good!
Re: Woohoo free snowblower! [Re: 55Test] #5416737 04/29/20 06:52 PM
J
JC1 Offline
J
Carb cleaning will help. I would try to drain out and old gas and put fresh gas in it with some fuel injector cleaner in it.
The gear selector probably needs some greasing. Check youtube for Donyboy's videos. He's got a lot of helpful information.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Woohoo free snowblower! [Re: 55Test] #5416768 04/29/20 07:17 PM
R
RyanY Offline
R
I have resurrected several older 4 stroke engines over the past decade (oldest was a B&S 3 hp from 1973) and all of them started after carb rebuild. Therefore, as JC1 said, start with carb cleaning and/or rebuild, or just buy an imported replacement carb if easier/cheaper. If it doesn't run well after the cleaning, then further work may be needed but at least this will be a starting point with little or no $ spent. Also, clean/reset the points if it has them.
2007 Cadillac CTS 3.6L >130k miles; mix of PUP/Magnatec 5W-30 + ACDelco PF2129G
2012 Honda Odyssey EX-L >108k miles; QSUD 0W20 + STP S6607XL
Re: Woohoo free snowblower! [Re: 55Test] #5416898 04/29/20 10:11 PM
Chris142 Online Content
Online Content
I have not had luck with addatives
Always had to poke wire through the jets
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Woohoo free snowblower! [Re: 55Test] #5416956 04/30/20 12:07 AM
djb Offline
A quick search suggests that most of those used Tecumseh HM80 engines.
I recently repaired a long-neglected chipper shredder with that engine, and have a bit of experience.
I wouldn't even bother checking out the carb. Just buy a new one from Amazon or FleaBay for $10-$12. It will take about 10 minutes to install.
A rebuild kit shipped from the U.S. is barely less expensive. If the float has a leak or the bowl is rusted, you'll end up paying far more.
I suggest getting a carb with a mixture adjustment screw on the bowl nut, rather than fixed mixture. I bought one with a fixed mixture and it's annoyingly rich.
I also bought a rebuild kit, planning to rebuild the original carb. It got a few rounds of ChemDip and lots of manual cleaning. But it had so many issues, including a snapped-off bowl nut and rusted in place float pin, that I had to concede defeat after a few hours.
Re: Woohoo free snowblower! [Re: djb] #5417014 04/30/20 06:15 AM
Z
Zaedock Offline
Z
Great advice right here. I just did two of them last Fall (I have 4 snowblowers for my property), both with 8HPTecumseh engines, and it was plug and play.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Woohoo free snowblower! [Re: 55Test] #5417043 04/30/20 07:22 AM
J
JLawrence08648 Offline
J
I don't know what you know about snowblower carbs but they are different than mower carbs. Best to remove, disassemble, soak in Berryman Chem Dip 3-4 hours, then spray with carb cleaner, however you need to remove the side Welch plug. There are several small opening passageways that affect the smoothness and prevent surging. Buy a welding tip cleaner.
The Chinese carbs are good, they work well, but cheaply made, steel fuel bowls.
2019 Hyundai Santa Fe SEL Plus, 2.4
1992 Acura Vigor GS, 2.5
Re: Woohoo free snowblower! [Re: 55Test] #5417094 04/30/20 08:45 AM
J
JTK Offline
J
That Tecumseh snowking should have the plastic gas tank, so no worries of rust in there, but it still could have a tank full of crud.
Like the above, I'd put a mail-order replacement carb on it, but I always hang on to the OEM carb just in case.
If she's worth working on, check the friction disk and belts. Hopefully it's the single shaft tecumseh and not the dual counter rotating shafts.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
