Forums Migration
Please read this thread
2002 Silverado sold in less than 24hrs
by Rat407 - 07/08/20 05:18 AM
2017 CR-V Next Oil
by Ruby2013Elantra - 07/08/20 02:31 AM
Silver Windshield Sun Shades
by rrretiree7 - 07/08/20 02:04 AM
Castrol Edge PIck-Up
by Gene K - 07/08/20 01:51 AM
Safety kleen seals.
by Chris142 - 07/07/20 10:58 PM
I do a full detail everything 2 or 3 years.
by SLO_Town - 07/07/20 09:59 PM
Oil Recommendation 2020 GR Supra
by afree - 07/07/20 09:51 PM
I need to drive it more...
by SLO_Town - 07/07/20 09:43 PM
Pennzoil
by BlueOvalFitter - 07/07/20 09:07 PM
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
32 registered members (4WD, 1960Elco, 53' Stude, 77GrandPrix, afree, Amkeer, 3 invisible), 785 guests, and 30 spiders.
Topics307,585
Posts5,313,593
Members71,876
OBD MX Link + #5416614 04/29/20 04:15 PM
P
painfx Offline OP
P
Re: OBD MX Link + [Re: painfx] #5416632 04/29/20 04:40 PM
W
Wolf359 Offline
W
I got one years ago and it was fine. But I'm not sure what's the point of getting this now when you can get scanners that do manufacturer specific codes like the Autel Diaglink for less money.
https://www.amazon.com/Autel-Diaglink-Systems-Diagnostic-Transmission/dp/B07QS9VH8V
Re: OBD MX Link + [Re: painfx] #5416664 04/29/20 05:15 PM
Propflux01 Offline
Pretty much a glorified code reader, set of limited gauges. I mean, neat and all, but limited by the apps used with it.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
Re: OBD MX Link + [Re: painfx] #5416681 04/29/20 05:41 PM
I
itguy08 Offline
I
I have one. Bought it direct from them (I don't do Amazon). It's one of the better adapters that will access a lot of the manufacturer specific functions. I use it with the FORScan app for Ford. Works well
Re: OBD MX Link + [Re: painfx] #5416690 04/29/20 05:54 PM
J
JMJNet Offline
J
I have this one:
https://www.amazon.com/gp/product/B073XKQQQW
It was on sale for about $10 cheaper than the current price.
  • 2017 Toyota Sienna
Re: OBD MX Link + [Re: painfx] #5416714 04/29/20 06:26 PM
5
55Test Offline
5
My brother has one. He was using one of those cheap Chinese bluetooth adapters with the Torque app. The cheap OBD2 adapter would sometimes fail during driving and the numbers it spat back were hard to believe. The MX+ doesn't seem to autoconnect to his 2008 Sonata as it should be, being that he has to manually connect the adapter in the app each time he goes to use it. I wonder if a firmware update would help. At least it doesn't randomly disconnect or fail like the Chinese adapter did.
The total sum of everything I have learned from this website: ...Oil in engine, good!
Re: OBD MX Link + [Re: painfx] #5416765 04/29/20 07:17 PM
DuckRyder Offline
I have the older one (its red), I use it primarily with FORscan Lite. It works fine with that. I have used the included app to read codes and it works too. I don’t use it to monitor gauges.
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: OBD MX Link + [Re: 55Test] #5416841 04/29/20 08:44 PM
W
Wolf359 Offline
W
The cheap Chinese ones do that, but you don't have to spend this much to get a decent one. The BAFX one gets good reviews too and its much cheaper at $23.
https://www.amazon.com/Products-Bluetooth-Herramienta-escaneo-dispositivos/dp/B005NLQAHS
Re: OBD MX Link + [Re: Wolf359] #5417805 04/30/20 10:02 PM
P
painfx Offline OP
P
I've heard good things about BAFX. However, OBD Link MX+ is much upscale.
Re: OBD MX Link + [Re: painfx] #5418694 05/01/20 07:53 PM
W
Wolf359 Offline
W
While I agree it's a nice tool, it's pretty limited in that it doesn't do advanced stuff and you can get the Autel mentioned earlier for less money. It's way overpriced for what it is. It was a nice product years ago when you didn't have products like the Autel that did manufacturer specific codes.
Re: OBD MX Link + [Re: painfx] #5421265 05/04/20 10:58 PM
Y
Y_K Offline
Y
I have the older one without the Plus. Use it with Forscan. Reprogrammed a few keys and keypad master codes on 3 Lincolns with it. No Autel will do that for you. They run up to 30% specials from time to time on them. The chip is legit and fast.
“This disease making us more cruel to one another than if we are doggs.” -- Samuel Pepys 1666
Re: OBD MX Link + [Re: Y_K] #5421292 05/05/20 12:32 AM
W
Wolf359 Offline
W
It's really the Forscan that does the programming and I believe the BAFX one will work with it which is much cheaper.
Re: OBD MX Link + [Re: Wolf359] #5431253 05/17/20 09:56 AM
DuckRyder Offline
Forscan needs a ELM327 compatible chip, which OBD LINK uses. Clones have varying success.
I’m not saying the BAFX won’t work, but would encourage someone to check it out if they were considering purchase for use with Forscan.
Robert
