Forums Migration
Please read this thread
2017 CR-V Next Oil
by Ruby2013Elantra - 07/08/20 02:31 AM
Silver Windshield Sun Shades
by rrretiree7 - 07/08/20 02:04 AM
Castrol Edge PIck-Up
by Gene K - 07/08/20 01:51 AM
Safety kleen seals.
by Chris142 - 07/07/20 10:58 PM
I do a full detail everything 2 or 3 years.
by SLO_Town - 07/07/20 09:59 PM
Oil Recommendation 2020 GR Supra
by afree - 07/07/20 09:51 PM
I need to drive it more...
by SLO_Town - 07/07/20 09:43 PM
Pennzoil
by BlueOvalFitter - 07/07/20 09:07 PM
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
28 registered members (ArrestMeRedZ, Astro14, Bjornviken, alcyon, AnthemBassMan, blingo, 2 invisible), 772 guests, and 25 spiders.
Topics307,584
Posts5,313,584
Members71,876
Harley main shaft seal (pics) #5414095 04/26/20 09:41 PM
F
fonecord2 Offline OP
F
Bike was leaking on side stand after riding. Has anyone seen a seal in this condition? What is a possible cause! [Linked Image]
[Linked Image]
5FBDCBA3-2A18-4A17-BD22-AA27254F61FD.jpegDC04F55E-4A20-4A4F-9EFA-7B9B56C80BD5.jpegE6EAEE8B-30FE-4A33-B4B6-F889CCCAD5B0.jpeg
2006 CTS
2003 Harley Davidson Road King
Re: Harley main shaft seal (pics) [Re: fonecord2] #5414118 04/26/20 10:27 PM
Z
ZeeOSix Offline
Z
Looks like the rubber got effected by something and distorted the lip. What kind of oil is in contact with that seal?
Re: Harley main shaft seal (pics) [Re: ZeeOSix] #5414192 04/27/20 01:44 AM
F
F
Gear oil. Usually redline heavy shockproof. Bike has over 50k and 17 years old.
2006 CTS
Re: Harley main shaft seal (pics) [Re: fonecord2] #5414307 04/27/20 07:38 AM
B
Bonz Offline
B
Is the seal distorted or is something damaging it by contact?
Re: Harley main shaft seal (pics) [Re: fonecord2] #5414331 04/27/20 08:02 AM
T
Tman220 Offline
T
Which one? There is redline heavy shockproof and then there's V-twin Shockproof? They are not created equal.
2012 Regal GS Turbo PP 5w30 90k
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30 165k
2005 GMC Sierra 1500 5.3 170k
2004 Civic LX M5 190k
2007 Camry 2.4 250k
2016 Victory Vegas
Re: Harley main shaft seal (pics) [Re: fonecord2] #5414332 04/27/20 08:04 AM
B
BigCahuna Offline
B
Age , low mileage, and drying out are probably why it's leaking. You might try a heavier oil , but it looks like you already have it torn down so now the best time to replace the seal. It won't get better by itself.,,,
Re: Harley main shaft seal (pics) [Re: Tman220] #5414435 04/27/20 09:44 AM
T
Tman220 Offline
T
I take that back, says right on Redline's website the V-twin transmission fluid with shockproof is the same fluid as Heavy shockproof
2007 Camry 2.4 250k
2016 Victory Vegas
Re: Harley main shaft seal (pics) [Re: fonecord2] #5414483 04/27/20 10:18 AM
B
Blkstanger Offline
B
I have seen Harley seals like that before. Harley Main shaft seals are known to fail. I have had them fail a few times over the years. If I remember right there was an updated seal at sometime.
99 Jeep WJ 4.7 205,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5, 81,000mi. Castrol Edge 5w30 Fram Ultra.
Re: Harley main shaft seal (pics) [Re: Bonz] #5415104 04/27/20 09:38 PM
F
F
I’m trying to figure out if the bearing made contact with the seal or something else caused it to distort. Thanks for the input.
2006 CTS
Re: Harley main shaft seal (pics) [Re: fonecord2] #5416254 04/29/20 09:16 AM
M
Mike72 Offline
M
Maybe contact with some strong cleaner from the outside.
When seals are made the rubber compounds used are cured by heat after being molded to the metal ring. These compounds are kept cool in a temperature controlled
area until ready for use. The composition of the compound ,storage temperature, curing temperature and age all have an effect on the quality of the seals produced. Are
these USA seals?
Re: Harley main shaft seal (pics) [Re: fonecord2] #5416508 04/29/20 02:17 PM
Silverado12 Offline
Don't know about your specific question but a bad bearing can take out a seal over time.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Harley main shaft seal (pics) [Re: Silverado12] #5416989 04/30/20 04:28 AM
F
F
these USA seals? It’s the stock seal from 2003. The quad seal looked like new.
Don't know about your specific question but a bad bearing can take out a seal over time.[/quote] bearing seemed fine. Isn’t marking a grinding noise.
2006 CTS
Re: Harley main shaft seal (pics) [Re: fonecord2] #5417419 04/30/20 02:28 PM
Z
ZeeOSix Offline
Z
How's the radial play? Being a roller bearing, there should be no noticeable radial play in the shaft.
