Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
Best oil on the market?
by sloinker - 05/25/20 08:47 PM
Xfinity Race in Charlotte
by kstanf150 - 05/25/20 08:12 PM
Purolator PBL14610 C&P
by FordBroncoVWJeta - 05/25/20 08:00 PM
Carquest Blue 85522 C&P
by FordBroncoVWJeta - 05/25/20 07:52 PM
2020 RAV4 Hybrid - oil options
by CELICA_XX - 05/25/20 07:44 PM
any battery charger/repair that can fix sulfation?
by apollo18 - 05/25/20 07:28 PM
Need Mice Advice
by Mr_Luke - 05/25/20 07:01 PM
pressure washer air compressor oil
by bedwards - 05/25/20 06:49 PM
2014 Elantra delayed shift 4th to 5th
by Propflux01 - 05/25/20 05:51 PM
2002 Ranger Electrical Weirdness (GEM, RAP?)
by DuckRyder - 05/25/20 05:47 PM
Oil change problems
by philipp10 - 05/25/20 05:41 PM
Denso 150 3024
by thrace - 05/25/20 04:58 PM
does ac delco warranty the replacement battery?
by apollo18 - 05/25/20 04:39 PM
Water drainage issue
by Paul_Siu - 05/25/20 04:39 PM
13 Corolla PCV
by AJB0009 - 05/25/20 04:24 PM
SpaceX Launch - Wednesday
by MasterSolenoid - 05/25/20 04:15 PM
mikespine, Typerguy, showtyme1958, rickyradit, YogiTheCat
71528 Registered Users
32 registered members (bachman, ABCarr, ammolab, AndyB, Avery4, 3 invisible), 1,459 guests, and 55 spiders.
Topics305,878
Posts5,281,953
Members71,528
push mower oil leak #5416458 04/29/20 01:30 PM
F
FT92 Offline OP
F
under a year old low end mower with a 3.5 -4.0 briggs engine got done using it today and turned it over to clean under it and when I pushed it back into garage, had a pretty good puddle of oil on the ground looks like it was coming from the carb area....could this be that I had it on its side to clean under never seen that before it was carb down when I turned it on its side
Re: push mower oil leak [Re: FT92] #5416466 04/29/20 01:37 PM
R
ragtoplvr Offline
R
The carb and the crankcase breather are on same side. Always keep carb up.
Rod
Re: push mower oil leak [Re: FT92] #5416468 04/29/20 01:42 PM
E
ecotourist Offline
E
Yes that can happen. When we moved I made the mistake of not draining the oil out of the lawn mower. The movers put it on its side and some oil ran out, apparently through the carburetor (the air filter was soaked with oil). I'm not sure how that can even happen but it did.
2000 BMW 528i 5MT M Sport
2007 Honda Accord EX-L 4Door V6 6MT
Re: push mower oil leak [Re: FT92] #5416488 04/29/20 01:59 PM
Donald Offline
You can only tip it sideways in the direction to drain oil, not the other way.
2015 Ford F-250 w/Powerstroke
Re: push mower oil leak [Re: FT92] #5416595 04/29/20 03:49 PM
SrDriver Offline
I made the same mistake once and had quite a mess to clean up.
When completely empty my walk behind mower holds 18 oz of oil.
Re: push mower oil leak [Re: FT92] #5416599 04/29/20 03:51 PM
J
jeepman3071 Offline
J
I had a customer that brought me a push mower he thought was seized since it wouldn't pull over. I noticed oil dripping from the muffler. Turns out he had stored it on a tool hanger or something in his garage with the spark plug part of the engine facing down. All of the oil ran into the cylinder.
I pulled the spark plug, cranked it over so all the oil came out, poured some in the crankcase and it fired right up. I charged him just for the oil I put in the mower and advised him on what happened.
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (61k) - Liqui Moly 5w40, MANN HU816X
Re: push mower oil leak [Re: FT92] #5416601 04/29/20 03:55 PM
M
mk378 Offline
M
There is a pipe from the crankcase to the air filter. It keeps filtered air in the crankcase and directs any blowby gasses back into the intake to be re-burned similar to the PCV system on a car.
Tipped on that side, the oil will run through the pipe and soak the air filter. Also can happen if seriously overfilled with oil.
Re: push mower oil leak [Re: jeepman3071] #5416723 04/29/20 06:40 PM
dinofish Offline
Toro manual also says that fuel tank must also be empty before tipping over to change oil, etc. If emergency, then fuel must be pumped out. This is why I change the oil first thing in spring before putting in fuel. Of course, I won't get the non-warm oil out completely.
Honest businessman! thumbsup
Re: push mower oil leak [Re: FT92] #5416969 04/30/20 01:43 AM
F
FT92 Offline OP
F
thanks guys for the info and help … I had visions of me buying another push mower ...really thought something gave out and mower was junk...I will keep the carb up from now on when I clean under the thing
