Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
Best oil on the market?
by sloinker - 05/25/20 08:47 PM
Xfinity Race in Charlotte
by kstanf150 - 05/25/20 08:12 PM
Purolator PBL14610 C&P
by FordBroncoVWJeta - 05/25/20 08:00 PM
Carquest Blue 85522 C&P
by FordBroncoVWJeta - 05/25/20 07:52 PM
2020 RAV4 Hybrid - oil options
by CELICA_XX - 05/25/20 07:44 PM
any battery charger/repair that can fix sulfation?
by apollo18 - 05/25/20 07:28 PM
Need Mice Advice
by Mr_Luke - 05/25/20 07:01 PM
pressure washer air compressor oil
by bedwards - 05/25/20 06:49 PM
2014 Elantra delayed shift 4th to 5th
by Propflux01 - 05/25/20 05:51 PM
2002 Ranger Electrical Weirdness (GEM, RAP?)
by DuckRyder - 05/25/20 05:47 PM
Oil change problems
by philipp10 - 05/25/20 05:41 PM
Denso 150 3024
by thrace - 05/25/20 04:58 PM
does ac delco warranty the replacement battery?
by apollo18 - 05/25/20 04:39 PM
Water drainage issue
by Paul_Siu - 05/25/20 04:39 PM
13 Corolla PCV
by AJB0009 - 05/25/20 04:24 PM
mikespine, Typerguy, showtyme1958, rickyradit, YogiTheCat
71528 Registered Users
27 registered members (bworley, bachman, ajchien, ArrestMeRedZ, BlakeB, 3 invisible), 1,208 guests, and 43 spiders.
Topics305,879
Posts5,281,961
Members71,528
Page 1 of 3 1 2 3
Ford 9.75 Rear Diff Cover with Drain plug recommendation #5416385 04/29/20 12:11 PM
stockrex Offline OP
I have a 2016 Ford Transit 350 SRW.
This has a Sterling 9.75 rear end from factory (??)
I need a drain and fill the rear and I want to switch out the rear diffy cover with one with a drain plug.
Will this fit?
https://shop.broncograveyard.com/Fo...over-Gray-Powdercoat/productinfo/623535/
what else is out there?
I read here on a different thread that I can tap and install a drain plug?
Ridgeline, Dmax, Ford 3.5
Oil Whisperer!*Fear the DINO*
Re: Ford 9.75 Rear Diff Cover with Drain plug recommendation [Re: stockrex] #5416446 04/29/20 01:20 PM
bdcardinal Offline
Should be a 9.75 axle. Its a little different because it is a full floater on the Transits with rear hubs. You should be ablw to get away with any diff cover for a 9.75", there is lots of room under there. Without getting into the argument over the "flat back" thing that seems to rustle feathers here, just get whatever one seems to work best for you for whatever you want to spend.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Ford 9.75 Rear Diff Cover with Drain plug recommendation [Re: stockrex] #5416521 04/29/20 02:38 PM
CT8 Offline
double click delete does not work
2015 F150 2.7
2018 F350 6.2
Re: Ford 9.75 Rear Diff Cover with Drain plug recommendation [Re: stockrex] #5416522 04/29/20 02:40 PM
CT8 Offline
9.75 inch ,,, interesting on a 350.
2015 F150 2.7
2018 F350 6.2
Re: Ford 9.75 Rear Diff Cover with Drain plug recommendation [Re: stockrex] #5416531 04/29/20 02:52 PM
K
kstanf150 Offline
K
I installed this one on my 2018 F250
So if your van has a Sterling Ford 9.75 rear end
This will work
Re: Ford 9.75 Rear Diff Cover with Drain plug recommendation [Re: kstanf150] #5416540 04/29/20 03:01 PM
CT8 Offline
This will work
I am losing it i thought the Stirling was 10.5 or something.
2015 F150 2.7
2018 F350 6.2
Re: Ford 9.75 Rear Diff Cover with Drain plug recommendation [Re: stockrex] #5416542 04/29/20 03:06 PM
stockrex Offline OP
CT
I saw the pool beneath the rings, I will clean it the first time and then do frequent drain and fill.
Gasket sounds great, when you say grease, do you mean just apply some fresh gear oil to it?
BD
Lol, Banks came out with some youtube videos on how the flatback messes with fluid flow. The banks one runs $400, cough cough.
I just want one that has a drain plug that I can have on my hand quickly. I want to avoid going to dealer...
So any 9.75 ford cover will fit? I will check the clearance again,
Re: Ford 9.75 Rear Diff Cover with Drain plug recommendation [Re: kstanf150] #5416546 04/29/20 03:09 PM
stockrex Offline OP
This will work
KStan,
Which cover is this? link please.
lol, This is my first ford and I am losing it with the tranny and diffy not having a drain plug.
Re: Ford 9.75 Rear Diff Cover with Drain plug recommendation [Re: stockrex] #5416556 04/29/20 03:23 PM
K
kstanf150 Offline
K
OP this is it
Re: Ford 9.75 Rear Diff Cover with Drain plug recommendation [Re: stockrex] #5416557 04/29/20 03:23 PM
Z
Zaedock Offline
Z
F150's get the 9.75 semi-float C-clip
F250/350's get the 10.5 full-float (the previous Sterling was the 10.25)
The Transit gets a version of the 9.75 with a full float hub that includes the studs on the face.
The rear diff cover part numbers for a 9.75 and 10.5 are not the same. Not sure what the difference is.
Was thinking about using either one in a Jeep project.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Ford 9.75 Rear Diff Cover with Drain plug recommendation [Re: CT8] #5416574 04/29/20 03:32 PM
Z
Zaedock Offline
Z
This will work
2018 F250's never came with a 9.75.
The options were Sterling 10.5 or Dana275 (HD tow).
Part Number 7092
Ford Sterling 9.75" Ring Gear
, 12 Bolt, Straight Fins
Part Number 9594
Ford Sterling 9.75" Ring Gear, 12 Bolt, Patterned Fins
Part Number 7086
Ford Sterling 10.25" & 10.5" Ring Gear
Part Number 9513
Ford Sterling 10.25" & 10.5" Ring Gear, 12 Bolt, Patterned Fins
The site you posted lists different PN's for the 9.75 vs the 10.25/10.5
Again, not sure what that difference is.
Re: Ford 9.75 Rear Diff Cover with Drain plug recommendation [Re: stockrex] #5416585 04/29/20 03:40 PM
K
kstanf150 Offline
K
Your right I’m sorry about the 9.75
The 250 is a 10.5 but looks the same
Sorry for the misled
Mine of my 250 looks just like the 9.75
Re: Ford 9.75 Rear Diff Cover with Drain plug recommendation [Re: kstanf150] #5416590 04/29/20 03:45 PM
Z
Zaedock Offline
Z
No need for apologies, just didn't want the dude to order the wrong cover.
I always wondered what the difference is as the center sections look identical. I've been looking into these more for my rock crawler build, as they are cheap and plentiful in the boneyards.
The 9.75 is 34 spline shafts and approximate strength to a Dana 60. The 10.25/10.5 is closer to a 14 bolt.
Re: Ford 9.75 Rear Diff Cover with Drain plug recommendation [Re: stockrex] #5416602 04/29/20 03:55 PM
K
kstanf150 Offline
K
Your correct those a really good rear ends. Mine has the
e-locker which is really nice when off road
Re: Ford 9.75 Rear Diff Cover with Drain plug recommendation [Re: stockrex] #5416603 04/29/20 03:56 PM
K
Kawiguy454 Offline
K
Get a big nut and matching drain Bolt and have it welded onto the stock cover for $10 and call it a day. Most aftermarket suggest usage is for additional capacity or cooling which you're not interested in.
Page 1 of 3 1 2 3
