Happy 4th of July
by 4WD - 07/04/20 09:12 AM
Collective car nouns, real and imagined
by MrHorspwer - 07/04/20 08:44 AM
Motorcraft FL-820S, ~9000 miles
by robertcope - 07/04/20 08:42 AM
FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
87 registered members (Astro14, avi1777, ABN_CBT_ENGR, aaronc7, 928, 5 invisible), 1,903 guests, and 36 spiders.
Topics307,404
Posts5,310,515
Members71,843
Page 3 of 3 1 2 3
Re: Trans flush or pan drop? [Re: tbm5690] #5416313 04/29/20 10:29 AM
P
PontiacHO Offline
P
Draw fluid out with top side with oil change pump. Replenish accordingly. Haven’t seen a drain plug in a trans pan or torque converter in years. If there’s enough stuff shucking off to clog the trans filter dropping the pan won’t help. Normal bushing wear stays in the bottom of the pan. Flushing just stirs up that wear/sediment and it gets in the valve body. Trouble then.
Interesting...my past 5 vehicles have all had drain bolts.
Good to know. What brands of vehicles? My last three trucks ( Ford - GM) didn’t.
Mazda, Toyota/Lexus, Nissan, and Acura
Well that’s the Japanese cars.
Re: Trans flush or pan drop? [Re: edyvw] #5416379 04/29/20 12:04 PM
supton Offline
Originally Posted by edyvw
Also, flush it but do not change filter? So what happens if something is stuck in the filter?
I know on mine the "filter" is really just a bit of window screen. Ok maybe a bit finer but hardly the sort of thing to get fine particles.
IMO, if you change often, like every 30k or even sooner, drain and fill is good enough. If you go 50-100k, then a full fluid exchange is "needed". All a matter of loading and breakdown--IMO if it's not getting loaded up, nor abuse, then a little but often keeps it in good enough shape, while "running to the end" makes me want to get as much as possible out.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: Trans flush or pan drop? [Re: HoosierJeeper] #5416421 04/29/20 12:47 PM
P
PontiacHO Offline
P
Sounds wasteful but I did a drain and fill (top side fluid extraction) on the last F150 I owned three times.. Each time 5 quarts was added initially and then a 10 mile drive and repeat. Did this same 2 step service at 50k intervals throughout ownership without ever dropping the pan. The trans was still functioning as designed when it was traded with 168,000 miles.
Re: Trans flush or pan drop? [Re: HoosierJeeper] #5416794 04/29/20 07:47 PM
Spector Offline
I have a 12 Lincoln MKZ Hybrid with CVT and 77,000. Fluid partially changed when a front wheel seal went at 25,000. I decided to get a drain and fill at the closer Ford dealer. (Lincoln dealer wanted close to $500 for a flush). The ford dealer did not really want to do it claiming a lifetime fluid but I convinced them to do a drain and fill ( they did not even have the machine to do a flush). Anyway, when I brought it in they had to search a while to find the Ford procedure for a drain and fill on the CVT, obviously they do not do many of these. In summary, capacity is 5.4 quarts and they claim they put in 5.1 so almost as good as a flush if they are correct. They did give me a small bottle of the old fluid as I requested so I could see the color and odor etc. Very happy with the result, cost was $191. Perhaps slightly overpriced for a drain and fill but having the dealer do it made me more comfortable. Inquired at a lot of independents and no one was really familiar with doing the job.
Re: Trans flush or pan drop? [Re: Spector] #5417153 04/30/20 09:53 AM
M
mpack88 Offline
M
A lot of shops won't even do a pan drop these days I had was tre turned down by NTB because my car was a 91 model with 80,000 miles and I want to have it serviced but they said no because they don't be responsible for any damage.
Re: Trans flush or pan drop? [Re: HoosierJeeper] #5421119 05/04/20 07:39 PM
G
Govtman Offline
G
Local big service place flushed my wifes car and the trans went out within the week. Mechanic i know said that was common. Some vehicle mfgs. will not warranty a transmission if it has been flushed.
Re: Trans flush or pan drop? [Re: HoosierJeeper] #5425722 05/10/20 05:52 PM
T
Toto Offline
T
Originally Posted by HoosierJeeper
I have about 60k on my Jeep Liberty transmission since the rebuild. I'm getting conflicting information - would it better to do a pan drop or take it do the dealer to do a flush. It's a 42RLE.
Thanks!
First of all you should have serviced the transmission sooner that is assuming you owned it the entire time, the answer is yes and yes, the best service is flush the transmission first then do a pan drop and that is the excellent way to maintain your transmission.
AMSOIL SS (10W-30)
AMSOIL SG (80W-90)
KENDALL GT-1 MAX (0W-20)
NAPA GOLD/WIX FILTERS
Re: Trans flush or pan drop? [Re: edyvw] #5425808 05/10/20 07:47 PM
dave1251 Offline
Originally Posted by Kira
Donald got it above. "...by the time people get to thinking about their transmission, it has a problem and has never been serviced." It's disheartening to side with a dealership but you can't blame 'em for wanting to distance themselves from a big, hairy situation. They can't be required to educate the customer base.
edyvw asked, "So what happens if something is stuck in the filter?". If it's a discernible piece of something-even a 1" long hunk of gasket- likely nothing will happen.
Transmission filters are rock catchers. The element in every one I've ever removed was completely clean "cloth".
WylieCoyote's tale of a plugged up filter is a rarity. I bet accumulation of such magnitude is "transmission specific".
Probably another boo on GM. There you can vilify his dealer because they didn't do what he asked for. They are lice, after all.
However, most important thig: transmission manufacturers recommend pan drop and refresh. But, maybe guy in Jiffy Lube knows better.
For the last decade my trucks don't recommend a transmission filter replacement.
don't use.
Re: Trans flush or pan drop? [Re: Govtman] #5425844 05/10/20 08:19 PM
dave1251 Offline
Most manufacturers recommend a flush.
don't use.
Re: Trans flush or pan drop? [Re: Govtman] #5425873 05/10/20 09:06 PM
W
WhizkidTN Offline
W
I had this same bad experience on a Mini-van of mine which required a rebuild shortly thereafter (and I had NO issues prior to this machine flush).
IMHO: DO NOT use a "flush machine" like the BG type so often seen. Just do the OEM factory recommended method (whatever that is for your specific car). For most modern cars today, that is a simple drain and fill with fresh ATF (using the drain bolt, no pan drops needed) as many don't have replaceable filters anymore (unless you are talking about a truck). Honda used to recommend doing this three times (with driving some miles in-between) to increase getting the newest fluid concentration in the transmission (and cleaning the magnetic drain plug of course).
I now do mine every 30K miles or so (DIY for my car, the dealership for the wife's Rogue w/CVT). Cheap insurance.
His: '12 Kia Optima SX - 2.0L GDI Twin-Scroll Turbo [Tuned] (88K)
>EDGE 0W-40, Fram XG9688
Her's: '14 Nissan Rogue SL AWD - 2.5L NA (107K)
>EDGE 0W-20, Fram XG6607/XG7317
Re: Trans flush or pan drop? [Re: WhizkidTN] #5425890 05/10/20 09:24 PM
B
bbhero Offline
B
Exactly right ↑↑↑↑↑↑↑
I just did my 4th and likely FINAL drain and refill on my 08 Nissan Altima VQ 3.5 L CVT.... I did 3 previous drain and refills starting at 283,500 miles... Definitely made the CVT quieter... Eneos CVT fluid put in last 3 drain and refills... Fluid color which was dark brown at 283k miles... After first 3 drain and refills was translucent clear... Interestingly the fluid that drained out into my drain pan actually had a bluish hue to it still after 20k miles... Surprised me. Could hardly see it on the dipstick. After this last drain and refill I just about need a seeing eye dog to see the mark on the stick LOL
Nissan Altima 3.5 Coupe
Royal Purple 10w30 Carquest red 84356
"Treat your family like your friends and treat your friends like your family."
Re: Trans flush or pan drop? [Re: HoosierJeeper] #5426643 05/11/20 05:49 PM
M
mpack88 Offline
M
If your dealing with a transmission that's got alot of varnish in it, new fluid or a flush if you will can break it lose and stopped up the filter. It happened to me after adding a quart of fluid. Changed the filter, was good for 100miles, had to change it again, was good for 3 years and 80k miles later. Now how many people had a transmission rebuilt when it was really just a stopped up filter?
Re: Trans flush or pan drop? [Re: WhizkidTN] #5426685 05/11/20 06:39 PM
dave1251 Offline
The last 6 trucks I've bought none have a drain bolts. The last 2 cars I've bought for my wife no drain bolts. The last 3 vehicles I have helped my Son. No drain bolts. And yes all the automobiles mentioned recommended flushes. I've yet to experience a issue with flushes.
don't use.
Re: Trans flush or pan drop? [Re: HoosierJeeper] #5438192 05/25/20 08:41 AM
H
HoosierJeeper Offline OP
H
Update: I did this and used the Wix rubber seal/filter. All was well until Friday, now after it sits overnight I get a half-dime sized drop on the ground. I checked the bolts with a 1/4" drive ratchet by where the leak is and they feel snug to me. Any ideas?
19 Jeep Renegade Trailhawk 1.3T
15 Jeep Cherokee Limited V6
07 Land Rover LR3 SE V8
05 Jeep Liberty Limited V6
96 Jeep Cherokee Country 4.0
Page 3 of 3 1 2 3
