I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
36 registered members (90Notch, AdRock, 2009Caraman, ArrestMeRedZ, AZjeff, Blkstanger, 3 invisible), 1,200 guests, and 41 spiders.
Topics306,032
Posts5,285,234
Members71,566
Mack Tow-Truck, truck towing truck #5416180 04/29/20 08:05 AM
Shannow Offline OP
Was out walking in a break from WfH last week, and this old Tow-truck, still in daily use drove past, barking off the valley...made some enquiries, 866 c.i. V-8, originally 375hp, upped to 480 by the owner....
Sorry not youtube vids.
https://www.facebook.com/JKThompsonHeavyTowingAndTransport/videos/933156027020455/
https://www.facebook.com/JKThompsonHeavyTowingAndTransport/videos/2012538755457469/
If it's the truth....it can handle the pressure !!!
Re: Mack Tow-Truck, truck towing truck [Re: Shannow] #5416264 04/29/20 09:25 AM
R
racin4ds Offline
R
866 c.i and only 375hp?
Heck my 6.0 PSD makes that from 365 c.i.along with over 500 lb/ft of torque. smile
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
'13 Passat TDi SE+Nav
Re: Mack Tow-Truck, truck towing truck [Re: racin4ds] #5416285 04/29/20 10:03 AM
justintendo Offline
i doubt the powerstroke has the torque that mack does.
13 escape 2.0 awd mobil 1 10w30ep
08 fusion 2.3 mtx mobil 1 5w30ep/redline mt90
96 f150 4.9 2wd mtx mobil 1 10w30hm/redline ps fluid
99 kaw zrx 1100 redline 10w40
many husqvarnas 5w40 t6 rotella
Re: Mack Tow-Truck, truck towing truck [Re: Shannow] #5416328 04/29/20 10:56 AM
SubieRubyRoo Offline
Upped to 480HP and probably 2800 ft-lbs LOL
De omnibus dubitandum.
Re: Mack Tow-Truck, truck towing truck [Re: racin4ds] #5416356 04/29/20 11:49 AM
O
OVERKILL Offline
O
The Cummins in our new Kenworth (9L, 542ci PACCAR branded as PX-9) is 350HP, 1150lb-ft. It's pretty standard for HD engines to have higher torque and lower HP. I remember even the old CAT OTR truck engines, the C16 (964ci) maxed out at 600HP in stock trim, but 2,050lb-ft though wink
Our previous Freightshakers all had 240-250HP 7L engines LOL
Re: Mack Tow-Truck, truck towing truck [Re: racin4ds] #5416377 04/29/20 12:02 PM
Chris142 Online Content
Online Content
My Peterbilt was 855CI and 250hp. Add a Turbo and it becomes a 280hp.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Mack Tow-Truck, truck towing truck [Re: SubieRubyRoo] #5416378 04/29/20 12:03 PM
Online Content
More like 1200ft lbs is all.
Re: Mack Tow-Truck, truck towing truck [Re: Shannow] #5416440 04/29/20 01:09 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Remember:
HP = Torque x RPM /5252
So if you make a ton of torque low, your HP can never be as high as if youre making it way up in the RPM band.
Re: Mack Tow-Truck, truck towing truck [Re: Shannow] #5416463 04/29/20 01:34 PM
Plus, remember industrial engines are generally reeled in a hair so that they can be rated for more continuous duty. I'm not quite sure if this applies to diesels since there is no real "consumer" market for these behemoths, but if you look at Ford and GM's HD platforms with gas engines in the F650 range (the box truck/ambulance stuff), they are usually 25-30HP shy of the F250 gas engine ratings. I won't pretend to know how it works or why they do it that way, though. You'd expect any engine with airflow across the radiator to be able to sustain max HP indefinitely, at least in my book. Otherwise it's not going to last IRL!
Re: Mack Tow-Truck, truck towing truck [Re: Chris142] #5416533 04/29/20 02:54 PM
CT8 Offline
Torque is the magic number.
Yeah I have seen broken drive shafts on semis and they are very heavy, there is lots of torque that can't be compared to the diesels in the pick ups.
2015 F150 2.7
2018 F350 6.2
Re: Mack Tow-Truck, truck towing truck [Re: Chris142] #5416669 04/29/20 05:25 PM
Shannow Offline OP
Guy who did the tune reckoned 1,900...needed for towing fully laden semi's up the hills around here.
It's apparently the setup that they used for 3 trailers 110T payload in the middle of Oz road trains...
It sounded so good barking off the valley walls when I was out walking the other day...
