Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
BMW N55 Recommendations
by BSchmidt25 - 05/29/20 10:21 AM
Castrol / Mobil 1 blend?
by mbres2000 - 05/29/20 09:40 AM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
60 registered members (2003f7, 4WD, Ag76, 10WSmuckers, 97prizm, 6 invisible), 1,650 guests, and 34 spiders.
Topics306,029
Posts5,285,211
Members71,566
Good low cost marine grease for wheel bearings. #5415990 04/28/20 08:53 PM
T
tblt44 Offline OP
T
I dont know if good and low cost should be in the same sentance.
Been using a mobile 1 (red)
Just switched to red n tacky then noticed supertech has a marine grease.
Any good.
Or does it separate like Mobil 1 ?
Suggestions for a good grease for boat wheel bearings, fresh and salt water.
2003 Avalanche Z71 5.3
2006 Tahoe 5.3
1989 Yamaha moto 4 250
2004 Key Largo w/70 Yamaha 2 stroke
Re: Good low cost marine grease for wheel bearings. [Re: tblt44] #5416007 04/28/20 09:12 PM
E
Elkins45 Online Content
Online Content
E
I use the Mystic marine wheel bearing grease. You can buy it at Academy Sports.
Re: Good low cost marine grease for wheel bearings. [Re: tblt44] #5416013 04/28/20 09:27 PM
danez_yoda Offline
Ive used supertech, its good as any,
Re: Good low cost marine grease for wheel bearings. [Re: tblt44] #5416014 04/28/20 09:29 PM
dblshock Offline
all grease is waterproof, don't sweat that claim.
05 Lexus GX470 175k
640:1 TCW-3
M1 0W40 XG-3614
Toyo Open Country H/T II
06 4Runner SR5 155k
640:1 TCW-3
M1 0W40 XG-3614
Falken Wildpeak AT3W
Re: Good low cost marine grease for wheel bearings. [Re: tblt44] #5416049 04/28/20 10:10 PM
4WD Online Confused
Online Confused
My new hubs/bearings came packed with Red N Tacky so I have stayed with that for a couple years.
Seems to stay together like the Mystik JT6 that I use for other things on the boat, lawn tractor and so on.
Re: Good low cost marine grease for wheel bearings. [Re: tblt44] #5416063 04/28/20 11:02 PM
Snagglefoot Offline
Pretty much all manufacturers make a marine grease that is enhanced for corrosion resistance in fresh and salt water. JT-6 is actually a marine grease and Red N Tacky is enhanced for corrosion resistance. They pretty much are all rated GC-LB which makes them appropriate for wheel bearings. I use Motomaster marine grease. smile
If you want the job done right......do it yourself.
Re: Good low cost marine grease for wheel bearings. [Re: tblt44] #5416087 04/29/20 01:58 AM
W
whosmatt Offline
W
I got worried by tubes of "high end" grease separating and dripping a bit when in my garage. But wheel bearings have seals. In a trailer that gets used once in a while but not submersed in water, the grease is going to separate or liquefy to some extent when sitting. But the seals keep it from leaking out, and then once you use the trailer it moves the grease around again and everything is good. Grease is just oil held in place by soap after all.
So, in a trailer that gets used once in a while AND submersed in water, just make sure your seals are good.
Re: Good low cost marine grease for wheel bearings. [Re: tblt44] #5416115 04/29/20 06:06 AM
B
Boomer Offline
B
Lots of marine grease has an aluminum soap base as the aluminum is not easily replaced by the sodium ion in sea water.
2019 VW Passat 2.0 liter gasoline DI engine, DI, 2,700 miles, Castrol Professional VW 508 0W-20
2017 VW Golf All Track 1.8 liter gas engine DI, 25,500 miles Castrol Professional VW 505 5W-40
Re: Good low cost marine grease for wheel bearings. [Re: dblshock] #5416118 04/29/20 06:14 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
Some greases do a better job of it than others. Calcium based greases are known to be better.
Re: Good low cost marine grease for wheel bearings. [Re: tblt44] #5416119 04/29/20 06:18 AM
R
Rob_Roy Offline
R
If you are going to be in salt water, I would use a calcium based grease. Here is one of the few options that you can usually buy locally in small quantities: https://www.tractorsupply.com/tsc/p...qqsGN6QIVSD0MCh2H-ge3EAQYBiABEgIm2PD_BwE
2016 Ford Expedition EL Platinum
2016 Ford Expedition XLT
1999 Ford F350, V10
Re: Good low cost marine grease for wheel bearings. [Re: tblt44] #5416131 04/29/20 06:44 AM
Donald Offline
I use a marine grease that is blue. Sta-Lube.
2015 Ford F-250 w/Powerstroke
Re: Good low cost marine grease for wheel bearings. [Re: Kestas] #5416179 04/29/20 08:04 AM
doitmyself Offline
Agreed. Take a dab of standard high temp lithium complex bearing/chassis grease on your palm and run it under the faucet while stirring the grease. It will turn milky from water mixing into it. I have some other grease (moly paste) that water will not mix in no matter how hard I try.
Picture worth a thousand words:
[Linked Image]
Re: Good low cost marine grease for wheel bearings. [Re: tblt44] #5416257 04/29/20 09:18 AM
Driz Offline
No matter what you do with a boat trailer don’t think you can avoid yanking every year to at least check them. No grease can help you if your seals leak water into the bearings. The rear always seems to get the worst of it for some reason. Take special care of those spindle s where the seal rides. Keep it nice and shiny clean so that seal won’t get ragged . Let the trailer sit a bit untill it cools before dunking it. That keeps the heat from drawing water in . If I was doing salt I’d hose the back of the wheels down well after use as well.
Bearing buddies love em or hate em help in that respect too but aren’t a way around doing the annual maintenance.
My trailer is 30 years old and had the thing 20 . My most recent trick is do the maintenance in the Fall not Spring. Yea seems backwards but if there’s any water in there at least it won’t sit all winter pitting one small spot . On each bearing and where it sits on the race. Been there done that dozens of times🥺 . How well doing my checks / repacks going into layup season works who knows, time will tell.
I just discovered the triple lip seal , something I’d never seen before. Mine aren’t on yet and of course they’re made in the awful place but they look like very good quality. Better ,who knows but every little bit helps especially with salt.
My point here as a fellow trailer sufferer is that the grease being superior isn’t so important as keeping that water out. The never ending battle.
Re: Good low cost marine grease for wheel bearings. [Re: tblt44] #5417017 04/30/20 06:20 AM
ChadHubbard Offline
I purhased a set of Vortex hubs last year. They came prepacked wiht Lucas Marine Grease. They are guaranteed for 100,00 miles as long as the Lucas Marine Grease is used. Use of any other grease voids the warranty.
Re: Good low cost marine grease for wheel bearings. [Re: tblt44] #5418996 05/02/20 09:30 AM
T
tblt44 Offline OP
T
Well I have a bad seal and will be repacking both wheels when my new seals come in.
I will do the water test with the red n tacky since I have 2 tubes of it.
If I dont like the result I,ll get a different grease.
I know you cant mix grease with a different base so all will be cleaned real good
2006 Tahoe 5.3
