The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
81 registered members (akh, 53' Stude, 1978elcamino, ARCOgraphite, 1foxracing, alarmguy, 7 invisible), 1,910 guests, and 62 spiders.
Topics306,052
Posts5,286,459
Members71,593
ML 350 oil cooler seals #5415953 04/28/20 07:48 PM
E
expat Offline OP
E
A friend has to have this done. My question is: Is this cooler an oil to coolant heat exchanger or oil to air ?
Thanks.
Re: ML 350 oil cooler seals [Re: expat] #5415963 04/28/20 07:58 PM
W
Wolf359 Offline
W
It's probably both oil to air and coolant. I have an E-350 so it's the same engine. Have to replace both gaskets. It's very common for them to go. Gaskets are cheap, basically labor to take it apart. Basically a big hunk of metal with fins on it next to the oil filter and when you take it apart some coolant comes out too so you need to refill the coolant afterwards.
Re: ML 350 oil cooler seals [Re: expat] #5416138 04/29/20 06:56 AM
R
RogerBacon Offline
R
Gas or Diesel? Big difference
Re: ML 350 oil cooler seals [Re: RogerBacon] #5416209 04/29/20 08:40 AM
A
Audios Offline
A
This, Im going to attack mine on my GL320 CDI and its 12.1 hours by the book.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: ML 350 oil cooler seals [Re: RogerBacon] #5416615 04/29/20 04:15 PM
W
Wolf359 Offline
W
Typically with a model like the ML 350, it has the 3.5 M272 engine, if it were diesel, it's usually a different model like ML 320.
Re: ML 350 oil cooler seals [Re: expat] #5416621 04/29/20 04:24 PM
A
Audios Offline
A
Any diesel with the Bluetech is a 350 as well, starting in 09.
