Pump on swamp cooler is not working. I can plug in something else into the socket (that the pump itself is plugged into) it is running on, and that something will run. I put a running hose into the tube that the pump pushes water into, to get to the spider. Water pours out immediately onto all the pads.
So that pretty much isolates the pump as the problem, doesn't it?
OK pumps are only 20-30 bucks at lowes. This unit is 10 years old, the pump has a decent amount of rust on the outside. Is there any reason to troubleshoot it and still get it to run? And if so, what could I try?
